查看: 3838|回復: 3
STM32怎么讓蜂鳴器十秒響一次并且循環(huán)呀,在下面程序哪里填?
ID:865955 發(fā)表于 2020-12-22 23:37 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "stm32f1xx_hal.h"
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
static uint8_t fac_us=0;
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
void Error_Handler(void);
static void MX_GPIO_Init(void);
/* USER CODE BEGIN PFP */
void ALIX_Delay_init(void);
void ALIX_Delay_us(uint32_t nus);
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
int main(void)
  /* USER CODE BEGIN 1 */
        uint16_t buzzercount = 6;
  /* USER CODE END 1 */
  /* MCU Configuration----------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* Configure the system clock */
  SystemClock_Config();
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  /* USER CODE BEGIN 2 */
        ALIX_Delay_init();
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
        while(--buzzercount)
                HAL_GPIO_TogglePin(GPIOC, GPIO_PIN_15);
                ALIX_Delay_us(902);
        buzzercount = 200;
                ALIX_Delay_us(804);
        buzzercount = 200;
                ALIX_Delay_us(759);
        buzzercount = 200;
                ALIX_Delay_us(716);
        buzzercount = 200;
                ALIX_Delay_us(676);
        buzzercount = 200;
                ALIX_Delay_us(602);
        buzzercount = 255;
                ALIX_Delay_us(519);
        buzzercount = 255;
                ALIX_Delay_us(506);
        buzzercount = 200;
//    for(int i=1500;i>=625;i--)
//                        while(--buzzercount)
//                                HAL_GPIO_TogglePin(GPIOC, GPIO_PIN_15);
//                                ALIX_Delay_us(i);
//                        buzzercount = 6;
//                buzzercount = 300;
//                        ALIX_Delay_us(625);
//                buzzercount = 6;
//                for(int i=625;i<=1500;i++)
//                        buzzercount = 6;
  /* USER CODE END 3 */
/** System Clock Configuration
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
    /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
    Error_Handler();
    /**Configure the Systick interrupt time
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  /* SysTick_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
/** Configure pins as
        * Analog
        * Input
        * Output
        * EVENT_OUT
        * EXTI
  GPIO_InitTypeDef GPIO_InitStruct;
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOD_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(buzzer_GPIO_Port, buzzer_Pin, GPIO_PIN_RESET);
  /*Configure GPIO pin : buzzer_Pin */
  GPIO_InitStruct.Pin = buzzer_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
  HAL_GPIO_Init(buzzer_GPIO_Port, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
void ALIX_Delay_init()
        HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK_DIV8);        //Ñ¡Ôñía2¿ê±Öó  HCLK/8
        fac_us=SystemCoreClock/8000000;                                //ÎaÏμí3ê±ÖóμÄ1/8
        uint32_t temp;
        SysTick->LOAD=nus*fac_us;                                         //ê±¼ä¼óÔØ
        SysTick->VAL=0x00;                                                //Çå¿Õ¼ÆêyÆ÷
        SysTick->CTRL|=SysTick_CTRL_ENABLE_Msk ;        //¿aê¼μ1êy
        do
                temp=SysTick->CTRL;
        }while((temp&0x01)&&!(temp&(1<<16)));                //μè′yê±¼äμ½′ï
        SysTick->CTRL&=~SysTick_CTRL_ENABLE_Msk;        //1رռÆêyÆ÷
        SysTick->VAL =0X00;                                               //Çå¿Õ¼ÆêyÆ÷
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @param  None
  * @retval None
  /* USER CODE BEGIN Error_Handler */
  /* User can add his own implementation to report the HAL error return state */
  /* USER CODE END Error_Handler */
#ifdef USE_FULL_ASSERT
   * @brief Reports the name of the source file and the source line number
   * where the assert_param error has occurred.
   * @param file: pointer to the source file name
   * @param line: assert_param error line source number
   * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
    ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
ID:278179 發(fā)表于 2020-12-23 09:22 | 只看該作者
做一個延時10秒的標志,到時間了打開蜂鳴器端口就反轉(zhuǎn)一次,標志位清除一下,等待下一次延時標志開啟,蜂鳴器是一直響10秒還是響多長時間看你關(guān)斷蜂鳴器端口反轉(zhuǎn)的延時
ID:750420 發(fā)表于 2020-12-23 10:11 | 只看該作者
看蜂鳴器類型:有源蜂鳴器只需要進行使能即可,無源的話得自己輸出波形控制發(fā)聲這是前提。剩下的內(nèi)容如樓上所說,在主函數(shù)中價格while循環(huán)寫個延時函數(shù)即可
ID:168796 發(fā)表于 2020-12-23 10:11 | 只看該作者
你開個定時器中斷,中斷里面放個標志位,然后循環(huán)里檢測這個標志,就可以了
無效樓層,該帖已經(jīng)被刪除
