查看: 2344|回復: 9
液晶模塊模擬IO口,單片機編譯的時候出現c213錯誤,有會的嗎
ID:726849 發表于 2020-12-22 20:06 | 顯示全部樓層 |閱讀模式
本帖最后由 zdcn 于 2020-12-22 20:41 編輯
#include<reg51.h>
#include<absacc.h>
sbit LCD_RST=P1^0;
sbit DI=P1^5;
sbit RW=P1^4;
sbit CSL=P1^2;
sbit CSR=P1^1;
sbit EN=P1^3;
sbit RDY=P0^7;
sbit LCD=0x80;
#define LCD_DISPON  0x3f
#define LCD_STARTROW 0xc0
#define LCD_ADDRSTRY 0xb8
#define LCD_ADDRSTRX 0x40
#define CSL 0
#define CSR 1
void LCD_WrCmd(bit port, uchar cmd)
EN=0;
CSL=port;
DI=0;
RW=0;
EN=1;
LCD=cmd;
EN=0;
void LCD_WrDat(bit port, uchar wrdata)
EN=0;
CSR=port;
DI=1;
RW=0;
EN=1;
LCD=wrdata;
EN=0;
uchar code  ASCII_TAB[480] = //0X20~0X7F之間 ASCII碼對應的點陣數據表
              { 0x00, 0x00, 0x00, 0x00, 0x00,
                            0x00, 0x00, 0x9e, 0x00, 0x00,
                0x00, 0x0e, 0x00, 0x0e, 0x00,
                0x28, 0xfe, 0x28, 0xfe, 0x28,
                0x48, 0x54, 0xfe, 0x54, 0x24,
                0x46, 0x26, 0x10, 0xc8, 0xc4,
                0x6c, 0x92, 0xaa, 0x44, 0xa0,
                0x00, 0x0a, 0x06, 0x00, 0x00,
                                 0x00, 0x38, 0x44, 0x82, 0x00,
                                 0x00, 0x82, 0x44, 0x38, 0x00,
                                 0x28, 0x10, 0x7c, 0x10, 0x28,
                                 0x10, 0x10, 0x7c, 0x10, 0x10,
                                 0x00, 0xa0, 0x60, 0x00, 0x00,
                                 0x10, 0x10, 0x10, 0x10, 0x10,
                                 0x00, 0xc0, 0xc0, 0x00, 0x00,
                                 0x40, 0x20, 0x10, 0x08, 0x04,
                        0x7C, 0xA2, 0x92, 0x8A, 0x7C,
                                0x00, 0x84, 0xFE, 0x80, 0x00,
                                0x84, 0xC2, 0xA2, 0x92, 0x8C,
                                0x42, 0x82, 0x8A, 0x96, 0x62,
                                0x30, 0x28, 0x24, 0xFE, 0x20,
                                0x4E, 0x8A, 0x8A, 0x8A, 0x72,
                                0x78, 0x94, 0x92, 0x92, 0x60,
                                0x02, 0xE2, 0x12, 0x0A, 0x06,
                                0x6C, 0x92, 0x92, 0x92, 0x6C,
                                 0x0C, 0x92, 0x92, 0x52, 0x3C,
                                0x00, 0x6C, 0x6C, 0x00, 0x00,
                                0x00, 0xAC, 0x6C, 0x00, 0x00,
                                0x10, 0x28, 0x44, 0x82, 0x00,
                                0x28, 0x28, 0x28, 0x28, 0x28,
                                0x00, 0x82, 0x44, 0x28, 0x10,
                                0x04, 0x02, 0xA2, 0x12, 0x0C,
                        0x64, 0x92, 0xF2, 0x82, 0x7C,
                                0xFC, 0x22, 0x22, 0x22, 0xFC,
                                 0xFE, 0x92, 0x92, 0x92, 0x6C,
                                0x7C, 0x82, 0x82, 0x82, 0x44,
                                0xFE, 0x82, 0x82, 0x44, 0x38,
                                0xFE, 0x92, 0x92, 0x92, 0x82,
                                0xFE, 0x12, 0x12, 0x12, 0x02,
                                0x7C, 0x82, 0x92, 0x92, 0xF4,
                                0xFE, 0x10, 0x10, 0x10, 0xFE,
                                0x00, 0x82, 0xFE, 0x82, 0x00,
                                0x40, 0x80, 0x82, 0x7E, 0x02,
                                0xFE, 0x10, 0x28, 0x44, 0x82,
                                0xFE, 0x80, 0x80, 0x80, 0x80,
                                0xFE, 0x04, 0x18, 0x04, 0xFE,
                                0xFE, 0x08, 0x10, 0x20, 0xFE,
                                0x7C, 0x82, 0x82, 0x82, 0x7C,
                        0xFE, 0x12, 0x12, 0x12, 0x0C,
                                0x7C, 0x82, 0xA2, 0x42, 0xBC,
                                0xFE, 0x12, 0x32, 0x52, 0x8C,
                                0x8C, 0x92, 0x92, 0x92, 0x62,
                                0x02, 0x02, 0xFE, 0x02, 0x02,
                                0x7E, 0x80, 0x80, 0x80, 0x7E,
                                0x3E, 0x40, 0x80, 0x40, 0x3E,
                                0x7E, 0x80, 0x70, 0x80, 0x7E,
                                0xC6, 0x28, 0x10, 0x28, 0xC6,
                                0x0E, 0x10, 0xE0, 0x10, 0x0E,
                                0xC2, 0xA2, 0x92, 0x8A, 0x86,
                                0x00, 0xFE, 0x82, 0x82, 0x00,
                                0x04, 0x08, 0x10, 0x20, 0x40,
                                0x00, 0x82, 0x82, 0xFE, 0x00,
                                0x08, 0x04, 0x02, 0x04, 0x08,
                                0x80, 0x80, 0x80, 0x80, 0x80,
                        0x00, 0x02, 0x04, 0x08, 0x00,
                                0x40, 0xA8, 0xA8, 0xA8, 0xF0,
                                0xFE, 0x90, 0x88, 0x88, 0x70,
                                0x70, 0x88, 0x88, 0x88, 0x40,
                                0x70, 0x88, 0x88, 0x90, 0xFE,
                                0x70, 0xA8, 0xA8, 0xA8, 0x30,
                                0x10, 0xFC, 0x12, 0x02, 0x04,
                                0x18, 0xA4, 0xA4, 0xA4, 0x7C,
                                0xFE, 0x10, 0x08, 0x08, 0xF0,
                                0x00, 0x88, 0xFA, 0x80, 0x00,
                                0x40, 0x80, 0x88, 0x7A, 0x00,
                                0xFE, 0x20, 0x50, 0x88, 0x00,
                                0x00, 0x82, 0xFE, 0x80, 0x00,
                                0xF8, 0x08, 0x30, 0x08, 0xF8,
                                0xF8, 0x10, 0x08, 0x08, 0xF0,
                                0x70, 0x88, 0x88, 0x88, 0x70,
                        0xF8, 0x28, 0x28, 0x28, 0x10,
                                0x10, 0x28, 0x28, 0x30, 0xF8,
                                0xF8, 0x10, 0x08, 0x08, 0x10,
                                0x90, 0xA8, 0xA8, 0xA8, 0x40,
                                0x08, 0x7E, 0x88, 0x80, 0x40,
                                0x78, 0x80, 0x80, 0x40, 0xF8,
                                0x38, 0x40, 0x80, 0x40, 0x38,
                                0x78, 0x80, 0x60, 0x80, 0x78,
                                0x88, 0x50, 0x20, 0x50, 0x88,
                                0x18, 0xA0, 0xA0, 0xA0, 0x78,
                                0x88, 0xC8, 0xA8, 0x98, 0x88,
                                0x00, 0x10, 0x6C, 0x82, 0x00,
                                0x00, 0x00, 0xFE, 0x00, 0x00,
                                0x00, 0x82, 0x6C, 0x10, 0x00,
                                0x10, 0x10, 0x54, 0x38, 0x10,
                                0x10, 0x38, 0x54, 0x10, 0x10};
//以filldata充填液晶屏
void  LCD_DispFill(uchar filldata)
{  uchar  x, y;
   LCD_WrCmd(CSL,LCD_STARTROW+0);        //設置左半屏顯示起始行為0
   LCD_WrCmd(CSR,LCD_STARTROW+0);        //設置右半屏顯示起始行為0
   for( y=0;y<8;y++)           //循環充填8頁
   {  LCD_WrCmd(CSL,LCD_ADDRSTRY+y);        // 設置左半屏頁地址
      LCD_WrCmd(CSL,LCD_ADDRSTRX);            // 設置左半屏列地址
      LCD_WrCmd(CSR,LCD_ADDRSTRY+y);        // 設置右半屏頁地址
      LCD_WrCmd(CSR,LCD_ADDRSTRX);                // 設置右半屏列地址
      for(x=0;x<64;x++)                  //充填每頁的64個單元(列)
      {  LCD_WrDat(CSL,filldata);
         LCD_WrDat(CSR,filldata);
//液晶模塊初始化
void  LCD_DispIni(void)
{  uint  i;
   LCD_RST = 0;                                           // 復位驅動芯片
   for(i=0; i<500; i++);
   LCD_RST = 1;
   LCD_WrCmd(CSL,LCD_DISPON);                 // 打開顯示
   LCD_WrCmd(CSL,LCD_STARTROW);           // 設置顯示起始行為0
   LCD_WrCmd(CSR,LCD_DISPON);
   LCD_WrCmd(CSR,LCD_STARTROW);
   LCD_DispFill(00);                        // 清屏
   LCD_WrCmd(CSL,LCD_ADDRSTRY+0);        // 設置頁(字符行)地址
   LCD_WrCmd(CSL,LCD_ADDRSTRX+0);        // 設置列地址
   LCD_WrCmd(CSR,LCD_ADDRSTRY+0);
   LCD_WrCmd(CSR,LCD_ADDRSTRX+0);
//在液晶屏的cy(0-7)行、cx(0-15)列顯示字符dispdata
void LCD_DispChar(uchar cy, uchar cx, char dispdata)
{  uchar  code  *pch;
   uchar  i;
   bit port;
   cy = cy&0x07;                // 參數過濾
   cx = cx&0x0f;
   pch = &ASCII_TAB[(dispdata-0X20)*5];     //指向字符起始列的點陣碼
   if((cx&0x08)==0)                // 列號cx<8,在左半屏顯示
       {  port=CSL;
          i=cx<<3;
       {  port=CSR;
          i = (cx&0x07)<<3;
   LCD_WrCmd(port,LCD_ADDRSTRX+i);        // 設置當前列地址
   LCD_WrCmd(port,LCD_ADDRSTRY+cy);        // 設置當前頁地址
   for(i=0; i<5; i++);           //延時
   LCD_WrDat(port,0x00);                                // 顯示一列空格
   for(i=0; i<5; i++)            //送出字符的5列點陣碼
      { LCD_WrDat(port,*pch);
        pch++;
   LCD_WrDat(port,0x00);                   //顯示一列空格
      for(i=0; i<5; i++);
//在液晶屏的cy(0-7)行、cx(0-15)列顯示字符disp_str
void  LCD_DispStr(uchar cy, uchar cx, char *disp_str)
{  while( *disp_str !='\0')
   {  cy = cy&0x07;                        // 參數過濾
      cx = cx&0x0f;
      LCD_DispChar(cy, cx, *disp_str);         // 顯示字符
             disp_str++ ;                                // 指向下一字符數據
      cx++;
      if(cx>15) cy++;                    // 指向下一顯示行
extern void LCD_DispIni(void);
extern void LCD_DispFill(uchar filldata);
extern void LCD_DispChar(uchar cy,uchar cx,char dispdata);
extern void LCD_DispStr(uchar cy,uchar cx,char *disp_str);
void  main(void)
{ while(1)
   {  LCD_DispIni();        // 初始化液晶模塊
      LCD_DispStr (0,1,"void Stop()");
      LCD_DispStr (1,1,"{ SDA=0;");
      LCD_DispStr (2,1,"        SCL=1;");
      LCD_DispStr (3,1,"        delay5us();");
      LCD_DispStr (4,1,"        SDA=1;");
      LCD_DispStr (5,1,"        delay5us();");
      LCD_DispStr (6,1,"        SCL=0;");
      LCD_DispChar (7,1,'}');
      while(1);
ID:726849 發表于 2020-12-22 20:08 | 顯示全部樓層
出錯的是40和54行
ID:726849 發表于 2020-12-22 20:36 | 顯示全部樓層
后面按要求把CSL=port;改成了if(port)
CSR=1;
CSL=0;
CSR=0;
CSL=1;
}還是C213的錯誤
ID:517466 發表于 2020-12-22 23:31 | 顯示全部樓層
你的程序寫的有點讓人迷惑啊。是不是從別的地方拷貝過來的?
1、函數明明在這個程序中為什么要加extern說明?
2、#define CSL 0和sbit CSL=P1^2;同時存在,你到底想要聲明CSL是什么?CSR也一樣。
3、#define能否全部提到前面?
4、類似extern void LCD_DispIni(void);這樣的函數聲明是不是也放到前面?
改好的程序如下:
#include<reg51.h>
#include<absacc.h>
//#define CSL 0
//#define CSR 1
sbit LCD_RST=P1^0;
sbit DI=P1^5;
sbit RW=P1^4;
sbit CSL=P1^2;
sbit CSR=P1^1;
sbit EN=P1^3;
sbit RDY=P0^7;
sbit LCD=0x80;
EN=0;
CSL=port;
DI=0;
RW=0;
EN=1;
LCD=cmd;
EN=0;
EN=0;
CSR=port;
DI=1;
RW=0;
EN=1;
LCD=wrdata;
EN=0;
//以filldata充填液晶屏
{  uchar  x, y;
//液晶模塊初始化
{  uint  i;
   LCD_RST = 1;
{  uchar  code  *pch;
   uchar  i;
   bit port;
   cx = cx&0x0f;
       {  port=CSL;
          i=cx<<3;
       {  port=CSR;
          i = (cx&0x07)<<3;
        pch++;
      for(i=0; i<5; i++);
      cx = cx&0x0f;
      cx++;
void  main(void)
{ while(1)
      while(1);
ID:517466 發表于 2020-12-22 23:32 | 顯示全部樓層
感覺你需要加強C語言的基本編程知識。
ID:865960 發表于 2020-12-22 23:37 | 顯示全部樓層
后面按要求把CSL=port;改成了if(port) { CSR=1; CSL=0; } else { CSR=0; CSL=1; }還是C213的錯誤
ID:517466 發表于 2020-12-22 23:39 | 顯示全部樓層
你的程序結構太亂。#define的函數聲明位置不正常。CSL和CSR在程序中被重復使用,這個是主要原因。
#define CSL 0 和sbit CSL=P1^2;同時存在,程序能正常?CSR也一樣。把#define CSL 0注釋掉或者刪除
extern沒必要加的
代碼給你修改了,編譯沒有問題。
#include<reg51.h>
#include<absacc.h>
//#define CSL 0
//#define CSR 1
sbit LCD_RST=P1^0;
sbit DI=P1^5;
sbit RW=P1^4;
sbit CSL=P1^2;
sbit CSR=P1^1;
sbit EN=P1^3;
sbit RDY=P0^7;
sbit LCD=0x80;
EN=0;
CSL=port;
DI=0;
RW=0;
EN=1;
LCD=cmd;
EN=0;
EN=0;
CSR=port;
DI=1;
RW=0;
EN=1;
LCD=wrdata;
EN=0;
//以filldata充填液晶屏
{  uchar  x, y;
//液晶模塊初始化
{  uint  i;
   LCD_RST = 1;
{  uchar  code  *pch;
   uchar  i;
   bit port;
   cx = cx&0x0f;
       {  port=CSL;
          i=cx<<3;
       {  port=CSR;
          i = (cx&0x07)<<3;
        pch++;
      for(i=0; i<5; i++);
      cx = cx&0x0f;
      cx++;
void  main(void)
{ while(1)
      while(1);
ID:517466 發表于 2020-12-22 23:43 | 顯示全部樓層
//#define CSL 0
//#define CSR 1
sbit CSL=P1^2;
sbit CSR=P1^1;
//#define uchar unsigned char
//#define uint unsigned int
下面的去掉extern ,并把所有聲明放在函數LCD_WrCmd的實體前面
參與人數 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎勵!
ID:517466 發表于 2020-12-22 23:49 | 顯示全部樓層
CSL和CSR在sbit后又被define了,然后后面對define的對象賦值,你的代碼有些神奇。
把#define CSL和#define CSR注釋掉,或者刪除!
參與人數 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎勵!
ID:726849 發表于 2020-12-23 11:19 | 顯示全部樓層
suncat0504 發表于 2020-12-22 23:49
把#define CSL和# ...
謝謝謝謝
