電路原理圖如下:
2020-12-21 14:13 上傳
- /*溫濕度實時監(jiān)測顯示,溫度測量范圍為0~+50℃; 濕度測量范圍為20%~90%;
- 1m/s=3.6km/h
- fs = 25*v m/s = 90*v km/h V單位是 伏
- #include"main.h"
- sbit set=P2^3; //設(shè)置
- sbit yw=P2^2; //移位
- sbit add=P2^1; //+
- sbit cut=P2^0; //-
- sbit change=P3^7; //切換
- sbit red=P1^3;sbit green=P1^4;//超限指示燈,上限,下限
- //===================================adc0832================================================
- sbit cs=P1^0; //片選
- sbit clk=P1^1;//時鐘
- sbit dio=P1^2;//數(shù)據(jù)
- extern uchar TH,RH;//溫度整數(shù),濕度整數(shù)部分
- extern uchar dat[3];//風(fēng)速上限,下限,初始化標(biāo)記
- uchar code word1[16]= {" Wind = km/h "};//km/h 調(diào)整界面
- uchar code word12[16]={"Wind= km/h L00"};//km/h
- uchar code word11[16]={"Wind= m/s L00"};//m/s
- uchar code word2[16]= {"Tem= C Hum= %"};//word2[4]word2[5]C word2[13]word2[14]%
- uchar code hehe[16]= {"Wind upper limit"};//設(shè)置風(fēng)速上限界面
- uchar code haha[16]= {"Wind lower limit"};//設(shè)置風(fēng)速下限界面
- uchar adcdat;
- uint sum=0; //5次adcdat數(shù)據(jù)之和
- uchar fs=0; //風(fēng)速默認(rèn) km/h
- bit flag1=0; //默認(rèn) 0(km/h) 1(m/s)
- uchar dengji=0;
- /**************開機初始化保存的數(shù)據(jù)*****************/
- void init_eeprom()
- read(0x20);read(0x22);read(0x24);//先讀
- if(dat[2]!=22) //新的單片機初始單片機內(nèi)部eeprom
- dat[0]= 20;//初始上限
- dat[1]= 3; //初始下限
- dat[2]=22;
- EA=0;
- eraze(0x20);delay1m(5);write(0x20);delay1m(5);//保存上限
- eraze(0x22);delay1m(5);write(0x22);delay1m(5);//保存下限
- eraze(0x24);delay1m(5);write(0x24);delay1m(5);//保存標(biāo)記數(shù)據(jù)
- EA=1;
- void main()
- uint i;uint j;uchar k;//動態(tài)延時變量
- init_1602();
- delay1m(100); //延時等待1602穩(wěn)定
- RH_founction();
- init_eeprom();
- while(1)
- if(!change)//切換單位顯示
- delay1m(10);
- if(!change)
- flag1 = ~flag1;
- if(flag1==0)//顯示km/h 等級
- w_string(0x80,word12);
- else if(flag1==1)//顯示m/s
- w_string(0x80,word11);
- while(!change);
- i++;if(i>2000)//動態(tài)延時讀取溫濕度值
- i=0;RH_founction();
- DHT11_display(0xc0+4,TH/10+0x30,TH%10+0x30); //顯示溫度
- DHT11_display(0xc0+13,RH/10+0x30,RH%10+0x30); //顯示濕度
- j++;if(j>300)
- j=0;
- adcdat=read_adc_convert();//讀出ADC轉(zhuǎn)換的結(jié)果
- sum=sum+adcdat;
- k++;
- if(k>=10)
- k=0;
- adcdat=sum/10; //風(fēng)速ad值,adcdat/51等于電壓,*90等于風(fēng)速
- if(adcdat<=1)adcdat=0;
- fs=adcdat*1.76; //fs=((float)adcdat/51)*90;
- //==================================報警判斷===============================================
- if(fs>dat[0]){red=0;green=1;}
- else if(fs<dat[1]){green=0;red=1;}
- else if((fs<=dat[0])&&(fs>=dat[1])){red=1;green=1;}
- //==================================等級判斷==============================================
- if(fs<1)dengji=0;
- else if((fs>=1)&&(fs<=5))dengji=1;
- else if((fs>=6)&&(fs<=11))dengji=2;
- else if((fs>=12)&&(fs<=19))dengji=3;
- else if((fs>=20)&&(fs<=28))dengji=4;
- else if((fs>=29)&&(fs<=38))dengji=5;
- else if((fs>=39)&&(fs<=49))dengji=6;
- else if((fs>=50)&&(fs<=61))dengji=7;
- else if((fs>=62)&&(fs<=74))dengji=8;
- else if((fs>=75)&&(fs<=88))dengji=9;
- else if((fs>=89)&&(fs<=102))dengji=10;
- else if((fs>=103)&&(fs<=117))dengji=11;
- else if((fs>=118)&&(fs<=133))dengji=12;
- else if((fs>=134)&&(fs<=149))dengji=13;
- else if((fs>=150)&&(fs<=166))dengji=14;
- else if((fs>=167)&&(fs<=183))dengji=15;
- else if((fs>=184)&&(fs<=201))dengji=16;
- else if((fs>=202)&&(fs<=220))dengji=17;
- if(flag1==0){} //km/h
- else if(flag1==1) //m/s
- fs=((float)fs/3.6)+0.5;
- if(fs/100==0)
- write_cmd(0x80+5);write_dat(0x20);//最高位為0,顯示空
- else
- write_cmd(0x80+5);write_dat(fs/100+0x30);
- if((fs/100==0)&&(fs/10%10==0))
- write_cmd(0x80+6);write_dat(0x20);//最高位為0,次高位也為0,顯示空
- else
- write_cmd(0x80+6);write_dat(fs/10%10+0x30);
- write_cmd(0x80+7);write_dat(fs%10+0x30);//最低位顯示
- //=================================顯示等級================================
- write_cmd(0x80+13);write_dat('L');
- if(dengji<10){write_cmd(0x80+14);write_dat(0x20);} //等級十位
- else {write_cmd(0x80+14);write_dat(dengji/10+0x30);}
- write_dat(dengji%10+0x30); //顯示等級
- sum=0;
- key_wind_up_down(); //風(fēng)速上限調(diào)整
- //=======================================風(fēng)速上限,下限調(diào)整函數(shù)================================
- void key_wind_up_down()
- uchar dz[3]={0xc8,0xc9,0xca};//風(fēng)速上下限數(shù)據(jù)在1602上顯示的地址
- uchar wei;//需要調(diào)整的位
- uchar buf[3];//風(fēng)速上限緩存
- uint counter;//用于產(chǎn)生閃爍效果
- if(!set)
- delay1m(10);
- if(!set)//進(jìn)入風(fēng)速上限設(shè)置
- while(!set);
- red=green=1;wei=0;
- buf[0]=dat[0]/100;
- buf[1]=dat[0]/10%10;
- buf[2]=dat[0]%10;//當(dāng)前風(fēng)速上限拆分后賦值給buf[]
- w_string(0x80,hehe); //"Wind upper limit"
- w_string(0xc0,word1); //" Wind = 000km/h "
- do
- counter++;if(counter>4000){counter=0;}//清零
- if(counter>2000){write_cmd(dz[wei]);write_dat(0x20);}//顯示空格
- if(counter<=2000)//顯示數(shù)據(jù)
- fs_display(0xc8,buf[0]+'0',buf[1]+'0',buf[2]+'0');//123km/h
- if(!yw)//按下yw,調(diào)整右移
- delay1m(10);
- if(!yw)
- while(!yw);
- wei++;if(wei>2){wei=0;}
- if(!add)//加1
- delay1m(10);
- if(!add)
- while(!add);
- buf[wei]++;if(buf[wei]>9){buf[wei]=9;}
- if(!cut)//減1
- delay1m(10);
- if(!cut)
- while(!cut);
- buf[wei]--;if(buf[wei]==0xff){buf[wei]=0;}
- if((buf[0]*100+buf[1]*10+buf[2])<=dat[1]) //保證上限大于下限
- dat[0]=dat[1]+1;
- buf[2]=dat[0]%10;
- }while(set);//按下set設(shè)置確定
- delay1m(100);while(!set);//等待彈起
- dat[0]=buf[0]*100+buf[1]*10+buf[2];
- EA=0;
- EA=1;
- //=====================================下限設(shè)置=============================================
- buf[0]=dat[1]/100;
- buf[1]=dat[1]/10%10;
- buf[2]=dat[1]%10;//當(dāng)前風(fēng)速下限拆分后賦值給buf[]
- w_string(0x80,haha); //"Wind Lower limit"
- do
- delay1m(10);
- if(!yw)
- while(!yw);
- if(!add)//加1
- delay1m(10);
- if(!add)
- while(!add);
- if(!cut)//減1
- delay1m(10);
- if(!cut)
- while(!cut);
- if((buf[0]*100+buf[1]*10+buf[2])>=dat[0])//保證下限小于上限
- dat[1]=dat[0]-1;
- buf[2]=dat[1]%10;
- dat[1]=buf[0]*100+buf[1]*10+buf[2];
- EA=0;eraze(0x22);delay1m(5);write(0x22);delay1m(5);EA=1;//保存上限
- w_string(0xc0,word2);
- //======================================ms級延時函數(shù)======================================
- void delay1m(uint x)
- uint k,j;
- for(k=0;k<x;k++) //連數(shù)x次,約 x ms
- for(j=0;j<120;j++); //數(shù)120 次,約1 ms
- //===================================讀出ADC轉(zhuǎn)換的結(jié)果函數(shù)======================================
- uchar read_adc_convert()
- uchar i; //循環(huán)變量
- uchar dat=0; //轉(zhuǎn)換之后讀出的數(shù)據(jù)
- uchar dat1=0;//轉(zhuǎn)換之后讀出的數(shù)據(jù)
- clk=0;cs=1;dio=0;//初始狀態(tài)
- cs=0;//cs置0,片選有效
- dio=1;//數(shù)據(jù)值1,起始信號
- clk=1;//第1個上升沿dio保持1,表示啟動
- _nop_();
- clk=0;//時鐘置0,為下一步上升沿做準(zhǔn)備
- clk=1;//第2個上升沿dio=1,表示選擇單通道輸入
- _nop_();
- dio=0;//數(shù)據(jù)值0
- clk=1;//第3個上升沿dio=0,表示選擇CH0
- _nop_();
- clk=0;
- dio=1;//將數(shù)據(jù)端口置為輸入狀態(tài),方便讀取
- clk=1;//為下一步讀取做準(zhǔn)備
- _nop_();
- for(i=0;i<8;i++)
- clk=1;_nop_();
- clk=0;//下降沿讀取一位數(shù)據(jù)
- dat<<=1;
- if(dio)
- dat|=0x01;
- else
- dat|=0x00;
- //時序圖中可見,前面8位與后面8位是共用最低位的,所以后面8位的
- //第一位必須再次讀取前面8位的最后一位,這過程中不允許出現(xiàn)下降沿
- for(i=0;i<8;i++)
- dat1>>=1;
- if(dio)
- dat1|=0x80;
- else
- dat1|=0x00;
- clk=1;_nop_();
- cs=1;
- if(dat==dat1)
- return dat;
- else
- return 0;
- return dat;
復(fù)制代碼 全部資料51hei下載地址:
溫濕度風(fēng)速.rar
(91.91 KB, 下載次數(shù): 31)
2020-12-21 10:40 上傳
下載積分: 黑幣 -5
