這個跑馬燈音樂盒為啥不能播放歌曲
- #include <reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit key1=P3^2;//定義按key1可切換花樣
- sbit key2=P3^3;//定義按key2可切換歌曲
- sbit fm=P3^5;//蜂鳴器連續(xù)的IO口,接蜂鳴器的管腳
- //sbit fm=P3^6;
- uchar code huayang1[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,
- 0xe7,0xdb,0xbd,0x7e,0xbd,0xdb,0xe7,0xdb,0xbd,0x7e}; //花樣1
- uchar code huayang2[]={0x7f,0xfe,0xbf,0xfd,0xdf,0xfb,0xef,0xf7,0xef,0xfb,0xdf,0xfd,0xbf,0xfe}; //花樣2
- uchar code huayang3[]={0x7f,0x3f,0x1f,0x0f,0x07,0x03,0x01,0x0,0x80,0xc0,0xe0,0xf0,0xf8,0xfc,0xfe,0xff,0x00};//花樣3
- uchar code huayang4[]={ 0x3f,0xcf,0xf3,0xfc,0xfc,0xf3,0xcf,0x3f,0x3f,0xf3,0xcf,0xfc,0x3f,0xf3,0xcf,0xfc}; //花樣4
- uchar code huayang5[]={ 0xff,0x00,0xff,0x00,0xf0,0x0f,0xf0,0x0f,0xf0,0x0f,0xf0,0x0f}; //花樣5
- uchar count1;//花樣標(biāo)志
- uchar count2;//歌曲標(biāo)志
- uchar timeh,timel,i;
- //---------------------------簡譜---------------------------------------
- //編程規(guī)則:字節(jié)高位是簡譜,低位是持續(xù)時間,代表多少個十六分音符。
- //1-7代表中央C調(diào),8-E代表高八度,0代表停頓
- //最后的0是結(jié)束標(biāo)志
- uchar code qnzl[]={ // 歌曲1
- 0xA1,0xA1,0xA1,0xA1,0x32,0x31,0x21,0x32,0x62,
- 0xA1,0xA1,0xA1,0xA1,0xA1,0xA1,0xA1,0xA1,0x32,0x22,
- 0x32,0x31,0x21,0x32,0x52,0x32,0x31,0x21,0x32,0x62,
- 0x32,0x31,0x21,0x32,0x83,0x82,0x71,0x72,0x02,
- 0x63,0xA1,0xA2,0x62,0x92,0x82,0x52,
- 0x31,0x51,0x63,0x51,0x63,0x51,0x63,0x51,0x62,0x82,0x7C,0x02,
- 0x61,0x71,0x82,0x71,0x62,0xA2,0x71,0x76,
- 0x61,0x71,0x82,0x71,0x62,0x52,0x31,0x36,
- 0x61,0x71,0x82,0x71,0x62,0xA3,0x73,0x62,0x53,
- 0x42,0x63,0x83,0x83,0x91,0x91,
- 0x61,0x71,0x82,0x71,0x62,0x0A2,0x71,0x76,
- 0x42,0x82,0x88,0x02,0x74,0x93,0x89,
- 0xff};//結(jié)束標(biāo)志
- uchar code jmszl[]={ // 歌曲二
- 0x12,0x12,0x22,0x32,0x31,0x22,0x21,0x22,
- 0x21,0x31,0x51,0x52,0x31,0x52,0x61,0x15,0x14,
- 0x51,0x52,0x31,0x52,0x62,0x13,0x11,0x13,0x32,0x28,
- 0x31,0x32,0x31,0x32,0x11,0x21,0x51,0x52,0x51,0x52,
- 0x51,0x51,0x31,0x32,0x31,0x32,0x81,0x72,0x63,
- 0x62,0x71,0x81,0x72,0x61,0x61,0x52,0x31,0x21,0x32,0x51,0x54,
- 0x22,0x12,0x11,0x12,0x11,0x12,0x12,0x14,0x26,0x32,0x26,
- 0x32,0x61,0x51,0x51,0x31,0x31,0x21,0x31,0x51,0x61,0x51,0x31,0x51,
- 0x02,0x32,0x81,0x81,0x81,0x81,0x62,0x52,0x34,
- 0x31,0x81,0x81,0x81,0x61,0x91,0x82,
- 0x51,0x51,0x51,0x51,0x31,0x61,0x53,
- 0x21,0x11,0x21,0x11,0x22,0x11,0x21,0x26,
- 0x32,0x61,0x51,0x51,0x31,0x31,0x21,0x31,0x51,0x61,0x51,0x31,0x51,0x52,
- 0x31,0x31,0x81,0x81,0x81,0x61,0x91,0x81,0x61,0x31,0x56,
- 0x32,0x32,0x81,0x81,0x81,0x81,0x91,0x81,0x61,0x81,0x61,0x51,0x31,0x51,0x34,
- 0x21,0x31,0x51,0x31,0x21,0x11,0x61,0x21,0x16,
- 0xff};
- uchar code song1 []= //歌曲三
- 0x34,0x32,0x32,0x34,0x42,0x51,
- 0x62,0x52,0x42,0x32,0x34,0x04,
- 0x74,0x74,0x62,0x62,0x64,
- 0x3c,0x04,
- 0x64,0x62,0x52,0x42,0x32,0x34,
- 0x33,0x31,0x32,0x72,0x76,0x72,
- 0x83,0x81,0x82,0x82,0x82,0x74,0x72,
- 0x7c,0x04,
- 0x63,0x61,0x62,0x62,0x64,0x72,0x82,
- 0x72,0x74,0x72,0x62,0x52,0x42,0x32,
- 0x42,0x44,0x42,0x42,0x52,0x62,0x52,
- 0x5c,0x04,
- 0x64,0x62,0x62,0x64,0x72,0x82,
- 0x42,0x46,0x53,0x41,0x42,0x32,
- 0x3c,0x04,
- 0xFF};
- uchar code song2[]={0x12,0x52,0x52,0x52,0x56,0x42, // 歌曲四
- 0x32,0x42,0x32,0x22,0x18,
- 0x82,0x82,0x82,0x82,0x86,0x72,
- 0xB2,0x72,0x72,0x62,0x58,
- 0x52,0x82,0x82,0x72,0x56,0x42,
- 0x32,0x42,0x32,0x22,0x16,0xB2,
- 0xB2,0x32,0x32,0x22,0x16,0x52,
- 0x42,0x32,0x22,0xC2,0x88,
- 0xFF};
- uchar code song3 []={ // 歌曲五
- 0x12,0x22,0x34,0x84,0x74,0x54,0x38,0x42,0x32,0x22,0x42,0x34,0x84,0x72,0x82,0x94,0xA6,
- 0x12,0x22,0x34,0x84,0x74,0x54,0x38,0x42,0x32,0x22,0x42,0x34,0x84,0x72,0x82,0x94,0xA8,0x08,
- 0xff };
- //----------------------------簡譜音調(diào)對應(yīng)的定時器初值---------------------------
- //適合11.0592M的晶振,對定時器置入的初值
- uchar code cuzhi[]={
- 0xff,0xff,//占位用的,沒有實(shí)際的意義
- 0xFC,0x8E,//中央C調(diào)1-7
- 0xFC,0xED,
- 0xFD,0x43,
- 0xFD,0x6A,
- 0xFD,0xB3,
- 0xFD,0xF3,
- 0xFE,0x2D,
- 0xFE,0x47, //高八度1-7
- 0xFE,0x76,
- 0xFE,0xA1,
- 0xFE,0xC7,
- 0xFE,0xD9,
- 0xFE,0xF9,
- 0xFF,0x16
- uchar yinyue[]={0xff,0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f,0x0,0x0};
- //將音調(diào)轉(zhuǎn)化為對應(yīng)的LED樣式
- void delay1(uint z); //延時1MS
- void delay(uint z); //延時165MS,即十六分音符
- void song();
- void beep();//蜂鳴器叫一聲
- main()
- { uchar x;
- count1=1;//流水燈花樣
- count2=0;//不唱歌
- EA=1;//開總中斷
- EX0=1;//開外部中斷0
- IT0=1;//外部中斷0下降沿觸發(fā)方式
- EX1=1;//開外部中斷1
- IT1=1;//外部中斷1下降沿觸發(fā)方式
- TMOD=0x01;//定時器0工作在方式1
- TH0=0;
- TL0=0;
- ET0=1;
- while(1)
- if(count1!=0)
- switch(count1)
- case 1:
- for(x=0;x<25;x++)
- P1=huayang1[x]; //花樣流水燈1
- beep();
- delay1(150);
- if(count1!=1)
- break;
- break;
- case 2:
- for(x=0;x<14;x++)
- P1=huayang2[x];//花樣流水燈2
- beep();
- delay1(300);
- if(count1!=2)
- break;
- break;
- case 3:
- for(x=0;x<17;x++)
- P1=huayang3[x];//花樣流水燈3
- beep();
- delay1(150);
- if(count1!=3)
- break;
- break;
- case 4:
- for(x=0;x<16;x++)
- P1=huayang4[x];//花樣流水燈4
- beep();
- delay1(300);
- if(count1!=4)
- break;
- break;
- case 5:
- for(x=0;x<12;x++)
- P1=huayang5[x];//花樣流水燈5
- beep();
- delay1(300);
- if(count1!=5)
- break;
- break;
- else
- song();
- delay1(1000);
- void int0() interrupt 0
- EA=0;//關(guān)總中斷
- delay1(1);//去抖
- if(key1==0)
- count2=0;//不讓蜂鳴器唱歌
- TR0=0;
- count1++;
- if(count1==6)
- count1=1;
- EA=1;//開總中斷
- void int1() interrupt 2 //外部中斷1
- EA=0;//關(guān)總中斷
- delay1(1);//去抖
- if(key2==0)
- count1=0;//流水燈無花樣
- TR0=1;
- i=0;//從頭開始唱
- count2++;
- if(count2==6)
- count2=1;
- EA=1;//開總中斷
- //---------------.按照51單片機(jī)的中斷向量順序編的號,也是缺省狀態(tài)下的優(yōu)先級------------
- //外部中斷0 interrupt 0
- //定時器0 interrupt 1
- //外部中斷1 interrupt 2
- //定時器1 interrupt 3
- //串口中斷 interrupt 4
- //定時器2 interrupt 5
- void timer0() interrupt 1 //用于產(chǎn)生各種音調(diào) 定時器0
- TH0=timeh;
- TL0=timel;
- fm=~fm;
- void song()
- uint temp;
- uchar jp; //簡譜
- i=0;
- while(1)
- { if(count2==0)
- break;
- if(count2==1) //選曲1
- { temp=qnzl [i];}
- if(count2==2) //選曲2
- temp=jmszl[i];
- if(count2==3) //選曲3
- temp=song1 [i];
- if(count2==4) //選曲4
- temp=song2 [i];
- if(count2==5) //選曲5
- temp=song3 [i];
- if(temp==0xff)
- break;
- jp=temp/16; //取數(shù)的高4位
- P1=yinyue[jp];
- if(jp!=0)
- timeh=cuzhi[jp*2];
- timel=cuzhi[jp*2+1];
- else
- TR0=0;
- fm=1;//關(guān)蜂鳴器
- delay(temp%16); //取數(shù)的低4位
- TR0=0; //唱完一個音停10MS
- fm=1;
- delay1(10);
- TR0=1;
- i++;
- TR0=0;
- fm=1;
- void delay(uint z) //延時165MS,即十六分音符
- { uint x,y;
- for(x=z;x>0;x--)
- for(y=19000;y>0;y--);
- void delay1(uint z) //延時1ms
- { uint x,y;
- for(x=z;x>0;x--)
- for(y=112;y>0;y--);
- void beep() //蜂鳴器叫一聲
- { uchar i;
- for(i=0;i<50;i++)
- { fm=~fm;
- delay1(1);
- fm=1;
