我真的是要哭了,為啥這個會出現這種情況呢,代碼如下
2020-12-15 22:14 上傳
- #include "stc12c5a60s2.h"
- #include <intrins.h>
- #include <string.h>
- #include <stdio.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit RS= P2^7 ; //液晶顯示引腳定義
- sbit RW= P2^6 ;
- sbit EN= P2^5 ;
- uint t=0,dian=0;
- uchar LCD_LINE_ONE[16]={"TP1: "}; //定義顯示屏幕
- uchar LCD_LINE_TWO[16]={"TP2: "};
- int Tm;
- int fushu=0 ;
- sbit DQ= P1^4;
- static unsigned char get_serial[]={ //獲取的八個DS18B20內部RAM64位序列號
- 1, 0,0,12, 135, 85, 127, 40,
- 149, 0,0,12, 134, 218, 150, 40
- void delay( ms ) //用于液晶顯示的延時函數
- int i ;
- while(ms--)
- for(i=0 ;i<5 ;i++ ) ;
- uchar Read_LCD_State() //讀取液晶顯示的狀態
- uchar state;
- RS=0;RW=1;EN=1;delay(1);
- state=P0;
- EN = 0;delay(1);
- return state;
- void LCD_Busy_Wait() //如果忙則等待函數
- while((Read_LCD_State()&0x80)==0x80);
- delay(5);
- void Write_LCD_Zhilin(uchar zl) //液晶顯示寫指令函數
- LCD_Busy_Wait();
- RS=0;RW=0;
- EN=0;
- P0=zl;
- EN=1;
- delay(1);
- EN=0;
- void Write_LCD_shuju(uchar date) //液晶顯示寫數據函數
- LCD_Busy_Wait();
- RS=1;RW=0;
- EN=0;
- P0=date;
- EN=1;
- delay(1);
- EN=0;
- void LCD_INIT() //液晶顯示初始化
- Write_LCD_Zhilin(0x38); // 顯示模式設置
- delay(1);
- Write_LCD_Zhilin(0x01); // 顯示清屏
- delay(1);
- Write_LCD_Zhilin(0x06); // 光標移動設置
- delay(1);
- Write_LCD_Zhilin(0x0c); // 開及光標設置
- delay(1);
- void Display_LCD_String(uchar p,uchar *s) //液晶顯示寫入函數
- uchar i;
- Write_LCD_Zhilin(p|0x80) ; //寫地址高位為一
- //Write_LCD_Zhilin(0x40|0x80) ;
- for(i=0;i<16;i++)
- Write_LCD_shuju(s[i]);
- delay(1);
- void delays(int us) //用于DS18B20的延時函數
- { int s;
- for ( s=0; s<us; s++);
- void rst(void) //DS18B20初始化
- DQ = 1;
- delays(20);
- DQ = 0;
- delays(300); //精確延時 480~960us
- DQ = 1;
- delays(80);
- void write(unsigned char ku) //DS18B20寫函數
- int i=0;
- for (i=0;i<8;i++)
- DQ=0;
- DQ =ku&0x01;
- delays(30);
- DQ=1;
- ku>>=1;
- void match_rom(unsigned char *rom) //DS18B20匹配ROM函數
- unsigned char i;
- rst(); //初始化
- write(0x55); //匹配ROM
- for(i=8;i>0;i--)
- write(*(rom+i-1));
- unsigned int read(void) //DS18B20讀函數,每次讀16位
- int i=0;
- unsigned int u=0;
- for (i=0;i<16;i++)
- DQ=0;
- u>>=1;
- DQ=1;
- if(DQ) u|=0x8000;
- delays(40);
- return (u);
- int read0(unsigned char *seria) //讀取對應溫度值并轉換函數
- int temperature ;
- unsigned int tp;
- unsigned int lsb;
- rst(); //初始化
- write(0xCC); //跳過RAM
- write(0x44); //溫度轉換
- rst(); //再次初始化
- write(0xCC);
- match_rom(seria); //匹配ROM函數調用
- write(0xBE); //讀取存儲器指令
- tp=read(); //讀取溫度值
- if((tp&0xf800)==0xf800) //判斷正負數
- fushu=1 ;
- tp=~tp+1 ;
- lsb=(unsigned int)(tp*6.25);
- dian=lsb%100; //取小數部分
- temperature=lsb/100;
- else
- fushu=0;
- dian=lsb%100;
- return(temperature);
- void main()
- uint i ;
- LCD_INIT();
- EA=0 ; //使用DS18B20禁止任何中斷
- while(1)
- for(i=0;i<2;i++)
- Tm=read0(get_serial+i*8);
- if(i==0) //判斷是第幾個的數據
- if(fushu==0) //判斷是否加負號
- sprintf(LCD_LINE_ONE+5," %d", Tm);
- if(fushu==1)
- sprintf(LCD_LINE_ONE+5,"-%d", Tm);
- sprintf(LCD_LINE_ONE+10,".%d",dian); //加入小數部分
- Display_LCD_String(0x00,LCD_LINE_ONE);
- if(i==1)
- if(fushu==0)
- sprintf(LCD_LINE_TWO+5," %d", Tm);
- if(fushu==1)
- sprintf(LCD_LINE_TWO+5,"-%d", Tm);
- sprintf(LCD_LINE_TWO+10,".%d",dian);
- Display_LCD_String(0x40,LCD_LINE_TWO);
