- #include<reg51.h>
- #define JZKEY P1
- #define GPIO_DIG P0
- sbit LSA=P2^2;
- sbit LSB=P2^3;
- sbit LSC=P2^4;
- sbit K1=P3^2;
- sbit K2=P3^3;
- sbit BEEP=P1^5;
- sbit LED1=P2^7;
- sbit LED2=P2^6;
- sbit LED3=P2^5;
- sbit LED4=P2^1;
- sbit LED5=P2^0;
- unsigned char code COMD_CODE[17] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00};
- //0、1、2、3、4、5、6、7、8、9、A、b、C、d、E、F的顯示碼
- unsigned char COMD_Display[8];
- //用來存放要顯示的8位數的值
- unsigned char k;
- unsigned char KeyValue;
- unsigned char flag=0;
- char Sec=10;
- char xuanshou=0;
- unsigned char Keyflag; //記錄按鍵的狀態,0沒有,1有
- void Delay10ms(); //延時10ms
- void KeyDown(); //檢測按鍵函數
- //--聲明全局函數--//
- void DigDisplay(); //動態顯示函數
- void Delay(unsigned int i) //無符號類型的int
- char j;
- for(i; i > 0; i--)
- for(j = 200; j > 0; j--);
- void Delay10ms2(unsigned int c) //誤差 0us
- unsigned char a,b;
- for(;c>0;c--)
- for(b=38;b>0;b--)
- for(a=130;a>0;a--);
- void BZ1() //正確搶答蜂鳴器
- unsigned int t;
- for(t=0;t<1000;t++)
- BEEP= 1;
- Delay(10);
- BEEP= 0;
- Delay(10);
- void BZ2() //錯誤搶答蜂鳴器
- unsigned int t;
- BEEP= 1;
- Delay(10);
- BEEP= 0;
- Delay(10);
- Delay10ms2(30);
- BEEP= 1;
- Delay(10);
- BEEP= 0;
- Delay(10);
- void main(void)
- unsigned char i=0;
- BEEP=1;
- Keyflag=0;
- TMOD=0x01; //定時器0方式1
- TH0=(65536-50000)/256; //定時器0:50ms
- TL0=(65536-50000)%256;
- TH1=(65536-50000)/256; //定時器0:50ms
- TL1=(65536-50000)%256;
- EA=1; //開啟總中斷
- ET1=1;TR1=1; //開啟T1定時器 T1定時器允許中斷
- while(1)
- ET0=0;TR0=0;
- while(flag==0)
- COMD_Display[0] = COMD_CODE[Sec/10%10];
- COMD_Display[1] = COMD_CODE[Sec%10];
- DigDisplay();
- if(K1==0)
- flag=1;
- ET0=1;TR0=1;
- if(K2==0)
- Sec=10;
- flag=0;
- P2=0xff;
- xuanshou=0;
- KeyDown();
- if(Keyflag==1)
- if(KeyValue<5)
- BZ2();
- COMD_Display[0]=COMD_CODE[(KeyValue+1)/10];
- COMD_Display[1]=COMD_CODE[(KeyValue+1)%10];
- xuanshou=(KeyValue+1);
- flag=3;
- Keyflag=0;
- while(flag==1)
- KeyDown();
- if(Keyflag==1)
- Keyflag=0;
- if(KeyValue<5)
- ET0=0;TR0=0;
- flag=2;
- BZ1();
- DigDisplay();
- ET0=0;TR0=0;
- while(flag==2)
- if(K2==0)
- Sec=10;
- flag=0;
- P2=0xff;
- xuanshou=0;
- DigDisplay();
- while(flag==3)
- COMD_Display[0]=COMD_CODE[15];
- COMD_Display[1]=COMD_CODE[xuanshou];
- DigDisplay();
- if(K2==0)
- Sec=10;
- flag=0;
- P2=0xff;
- xuanshou=0;
- Keyflag=0;
- void DigDisplay()
- unsigned char i;
- unsigned int j;
- for(i=0;i<8;i++)
- switch(7-i) //位選,選擇點亮的數碼管,
- case(0):
- LSA=0;LSB=0;LSC=0; break;//顯示第0位
- case(1):
- LSA=1;LSB=0;LSC=0; break;//顯示第1位
- case(2):
- LSA=0;LSB=1;LSC=0; break;//顯示第2位
- case(3):
- LSA=1;LSB=1;LSC=0; break;//顯示第3位
- case(4):
- LSA=0;LSB=0;LSC=1; break;//顯示第4位
- case(5):
- LSA=1;LSB=0;LSC=1; break;//顯示第5位
- case(6):
- LSA=0;LSB=1;LSC=1; break;//顯示第6位
- case(7):
- LSA=1;LSB=1;LSC=1; break;//顯示第7位
- GPIO_DIG=COMD_Display[i];//發送段碼
- j=10; //掃描間隔時間設定
- while(j--);
- GPIO_DIG=0x00;//消隱
- void KeyDown(void)
- JZKEY=0x0f;
- if(JZKEY!=0x0f)
- Delay10ms();
- if(JZKEY!=0x0f)
- Keyflag=1;//有按鍵按下
- //測試列
- JZKEY=0X0F;
- switch(JZKEY)
- case(0X07): KeyValue=0;break;
- case(0X0b): KeyValue=1;break;
- case(0X0d): KeyValue=2;break;
- case(0X0e): KeyValue=3;break;
- //測試行
- JZKEY=0XF0;
- Delay10ms();
- switch(JZKEY)
- case(0X70): KeyValue=KeyValue;break;
- case(0Xb0): KeyValue=KeyValue+4;break;
- case(0Xd0): KeyValue=KeyValue+8;break;
- case(0Xe0): KeyValue=KeyValue+12;break;
- while(JZKEY!=0xf0);
- void Delay10ms(void)
- unsigned char a,b,c;
- for(c=1;c>0;c--)
- for(b=38;b>0;b--)
- void Timer0() interrupt 1 //倒計時
- unsigned char i;
- TH0=(65536-50000)/256; //恢復定時器0初值
- if(flag==1)
- i++;
- if(i>=20) //50ms*20=1s
- i=0;
- Sec--;
- if(Sec==0)
- ET0=0;TR0=0;
- BZ2();
- flag=2;
- void Timer1() interrupt 3 //正確LED閃爍
- TH1=(65536-50000)/256; //恢復定時器0初值
- k++;
- if(flag==2)
- if(k>=200)
- k=0;
- if(xuanshou==1)
- LED1=!LED1;
- if(xuanshou==2)
- LED2=!LED2;
- if(xuanshou==3)
- LED3=!LED3;
- if(xuanshou==4)
- LED4=!LED4;
- if(xuanshou==5)
- LED5=!LED5;
- if(flag==3) //錯誤搶答時的LED閃爍
- if(k>=20)
- k=0;
- if(xuanshou==1)
- LED1=!LED1;
- if(xuanshou==2)
- LED2=!LED2;
- if(xuanshou==3)
- LED3=!LED3;
- if(xuanshou==4)
- LED4=!LED4;
- if(xuanshou==5)
- LED5=!LED5;
