2020-12-9 19:42 上傳
#include<reg51.h>
#include<intrins.h>
#include<absacc.h>
sbit key1=P3^0; //模式切換:0.時(shí)分秒顯示,1.時(shí)分秒調(diào)整,2.年月日顯示,3.年月日調(diào)整,4.鬧鐘顯示,5.鬧鐘調(diào)整
sbit key2=P3^1;//調(diào)秒或日
sbit key3=P3^2;//調(diào)分或月
sbit key4=P3^3;//調(diào)時(shí)或年
sbit key5=P3^4;//24或12轉(zhuǎn)換
sbit key6=P3^5;//關(guān)閉鬧鐘
sbit horn=P1^0;//蜂鳴器
sbit led1=P1^1;//時(shí)分秒顯示,閃爍代表調(diào)整
sbit led2=P1^2;//年月日顯示,閃爍代表調(diào)整
sbit led3=P1^3;//鬧鐘顯示,閃爍代表調(diào)整
sbit led4=P1^4;//24制滅,12制亮
sbit led5=P1^5;//上午滅,下午亮
unsigned char sech=0,secl=0,minh=0,minl=0,hourh=0,hourl=0,mark=0,
sech1=0,secl1=0,minh1=0,minl1=0,hourh1=0,hourl1=0,mark1=0,
year4=0,year3=0,year2=0,year1=0,monh=0,monl=0,dayh=0,dayl=0,//定義時(shí)間鬧鐘日期存儲(chǔ)
mark2=0,mark3=1;//2是進(jìn)制標(biāo)志,3是上下午標(biāo)志
unsigned int num=0,sec=0,min=0,hour=0,hour2=0,//時(shí)間時(shí)分秒計(jì)數(shù)
num1=0,sec1=6,min1=6,hour1=6,hour3=0,//鬧鐘時(shí)分秒技計(jì)數(shù)
year=0,mon=1,day=1;//日期年月日計(jì)數(shù)
unsigned char code table[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//數(shù)碼管1到10
void keyscan();//鍵盤掃描韓函數(shù)
void showtime();//時(shí)鐘顯示函數(shù)
void showyear();//年月日顯示函數(shù)
void showtime1();//鬧鐘顯示函數(shù)
void clock();//鬧鐘發(fā)聲函數(shù)
void time0();//中斷函數(shù)
void delay(unsigned char z)
{unsigned char x,y;
for(x=z;x>0;x--)
for(y=255;y>0;y--);}//延時(shí)函數(shù)
void time0() interrupt 1
{num++;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
if(num==20)//20次為1S
{num=0;
sec++;}
if(sec>=60)
{sec=0;
min++;}//60秒清零,分加一
if(min>=60)
{min=0;
hour++;}//60分清零,時(shí)加一,下面以此類推
if(hour>=12)
{mark3=0;}
if(hour>=24)
{mark3=1;
hour=0;
day++;}
if(mon==2)//判斷是否為2月
{if(year%4==0)//判斷是否為閏年
{if(day>=30)
{day=1;mon++;}}
else if(day>=29)
{day=1;mon++;}}
if((mon==1)||(mon==3)||(mon==5)||(mon==7)||(mon==8)||(mon==10)||(mon==12))//判斷是否是大月
{if(day>=32)
{day=1;mon++;}}
if((mon==4)||(mon==6)||(mon==9)||(mon==11))//判斷是否是小月
{if(day>=31)
{day=1;mon++;}}
if(mon>=13)
{mon=1;year++;}
if(year>=31)
{year=0;}
}//中斷函數(shù)T0,1S,累加時(shí)分秒,年月日
void showtime()
secl=sec%10;//秒的個(gè)位
sech=sec/10;//秒的十位,下面類推
minl=min%10;
minh=min/10;
hourl=hour2%10;
hourh=hour2/10;
P2=0xfe;//循環(huán)輸出數(shù)碼管顯示碼
P0=table[secl];
delay(5);
P2=0xfd;
P0=table[sech];
delay(5);
P2=0xfb;
P0=0x40;
delay(5);
P2=0xf7;
P0=table[minl];
delay(5);
P2=0xef;
P0=table[minh];
delay(5);
P2=0xdf;
P0=0x40;
delay(5);
P2=0xbf;
P0=table[hourl];
delay(5);
P2=0x7f;
P0=table[hourh];
delay(5);
}//時(shí)鐘顯示函數(shù)
void showtime1()
secl1=sec1%10;//原理同上
sech1=sec1/10;
minl1=min1%10;
minh1=min1/10;
hourl1=hour3%10;
hourh1=hour3/10;
P2=0xfe;
P0=table[secl1];
delay(5);
P2=0xfd;
P0=table[sech1];
delay(5);
P2=0xfb;
P0=0x40;
delay(5);
P2=0xf7;
P0=table[minl1];
delay(5);
P2=0xef;
P0=table[minh1];
delay(5);
P2=0xdf;
P0=0x40;
delay(5);
P2=0xbf;
P0=table[hourl1];
delay(5);
P2=0x7f;
P0=table[hourh1];
delay(5);
}//鬧鐘顯示函數(shù)
void showyear()
dayl=day%10;//原理同上
dayh=day/10;
monl=mon%10;
monh=mon/10;
year4=year%10;
year3=year/10;
year2=0;
year1=2;
P2=0xfe;
P0=table[dayl];
delay(5);
P2=0xfd;
P0=table[dayh];
delay(5);
P2=0xfb;
P0=table[monl];
delay(5);
P2=0xf7;
P0=table[monh];
delay(5);
P2=0xef;
P0=table[year4];
delay(5);
P2=0xdf;
P0=table[year3];
delay(5);
P2=0xbf;
P0=table[year2];
delay(5);
P2=0x7f;
P0=table[year1];
delay(5);
}//年份顯示函數(shù)
void keyscan()
if(key5==0)//進(jìn)制切換按鍵按下
{delay(10);//消抖
if(key5==0)//再次判斷進(jìn)制按鍵按下
{mark2++;//進(jìn)制標(biāo)志加1
if(mark2>=2)
mark2=0;}//標(biāo)志清零
while(key5==0);//松開按鍵跳出
if(key1==0) //模式切換按鍵按下
{ delay(10);//消抖,下同
if(key1==0)//再次判斷按鍵是否按下
{mark++;
if(mark>=6)
mark=0;} //按鍵按下次數(shù)標(biāo)志加1,6次清零
while(key1==0);} //松開按鍵跳出
if(mark==1)//時(shí)間調(diào)整
{if(key2==0)//調(diào)秒鍵按下
{delay(10);
if(key2==0)//再次判斷鍵是否按下
{sec++;//秒加1
if(sec>=60)//判斷秒是否到60S
sec=0;}//到60S清零
while(key2==0);//釋放鍵
if(key3==0)//調(diào)分,原理同上
{delay(10);
if(key3==0)
{min++;
if(min>=60)
min=0;}
while(key3==0);
if(key4==0)//調(diào)時(shí),原理同上
{delay(10);
if(key4==0)
{hour++;
if(hour==24)
hour=0;}
while(key4==0);
if(mark==5)//鬧鐘調(diào)整,原理同上
{if(key2==0)
{delay(10);
if(key2==0)
{sec1++;
if(sec1>=60)
sec1=0;}
while(key2==0);
if(key3==0)
{delay(10);
if(key3==0)
{min1++;
if(min1>=60)
min1=0;}
while(key3==0);
if(key4==0)
{delay(10);
if(key4==0)
{hour1++;
if(hour1>=24)
hour1=0;}
while(key4==0);
if(mark==3)//年份調(diào)整,原理同上
{if(key2==0)
{delay(10);
if(key2==0)
{day++;
if(mon==2)
{if(year%4==0)
{if(day>=30)
day=1;}
else if(day>=29)
{ day=1;}
{if(day>=32)
day=1;}
{if(day>=31)
day=1;}
while(key2==0);
if(key3==0)
{delay(10);
if(key3==0)
{mon++;
if(mon>=13)
mon=1;}
while(key3==0);
if(key4==0)
{delay(10);
if(key4==0)
{year++;
if(year>=31)
year=0;}
while(key4==0);
}//鍵盤掃描函數(shù)
void clock()
{ unsigned int i;
for(i=1000;i>0;i--)
{horn=1;
P1=0xfe;
delay(10);
horn=0;
P1=0xff;
delay(10);
if(key6==0)
{mark1=0;break;}
}//蜂鳴器發(fā)聲函數(shù)
void to12()
if(mark2==1)
{led4=0;
if(hour>=12)
{hour2=hour-12;}
else {hour2=hour;}
if(hour1>=12)
{hour3=hour1-12;}
else {hour3=hour1;}
if(mark2==0)
{led4=1;
hour2=hour;
hour3=hour1;
}//24或12制轉(zhuǎn)換函數(shù)
main()
{TMOD=0x01;
EA=1;ET0=1;TR0=1;//中斷T0初始化
keyscan();to12();
if(mark==0) {showtime();led1=0;}//顯示時(shí)間,燈1常亮
if(mark==1) {showtime();led1=0;delay(50);led1=1;}//調(diào)整時(shí)間,燈1閃爍
if(mark==2) {showyear();led2=0;}//顯示日期,燈2常亮
if(mark==3) {showyear();led2=0;delay(50);led2=1;}//調(diào)整日期,燈2閃爍
if(mark==4) {showtime1();led3=0;}//顯示鬧鐘,燈3常量
if(mark==5) {showtime1();led3=0;delay(50);led3=1;}//調(diào)整鬧鐘,燈3閃爍
if((hour==hour1)&&(min==min1)&&(sec==sec1)){mark1=1;}//判斷當(dāng)前時(shí)間與鬧鐘是否一致
if(mark1==1){clock();}//鬧鐘響
led5=mark3;//關(guān)閉鬧鐘
全部資料51hei下載地址:
電子時(shí)鐘程序+仿真.7z
(1.72 MB, 下載次數(shù): 168)
2020-12-9 19:43 上傳
點(diǎn)擊文件名下載附件
電子時(shí)鐘 下載積分: 黑幣 -5
