新建工程,在HARDWARE目錄下新建adc.c和adc.h文件。編輯adc.h文件: //初始化ADC //這里我們僅以規(guī)則通道為例 //我們默認(rèn)將開啟通道0~3 void Adc_Init(void) { ADC_InitTypeDef ADC_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_ADC1, ENABLE );//使能ADC1通道時鐘 RCC_ADCCLKConfig(RCC_PCLK2_Div6); //設(shè)置ADC分頻因子6 //72M/6=12,ADC最大時間不能超過14M //PA1 作為模擬通道輸入引腳 GPIO_InitStructure.GPIO_Pin =GPIO_Pin_1; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;//模擬輸入 GPIO_Init(GPIOA, &GPIO_InitStructure);//初始化GPIOA.1 ADC_DeInit(ADC1); //復(fù)位ADC1,將外設(shè)ADC1 的全部寄存器重設(shè)為缺省值 ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;//ADC獨(dú)立模式 ADC_InitStructure.ADC_ScanConvMode = DISABLE;//單通道模式 ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;//單次轉(zhuǎn)換模式 ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;//轉(zhuǎn)換由 //軟件而不是外部觸發(fā)啟動 ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//ADC數(shù)據(jù)右對齊 ADC_InitStructure.ADC_NbrOfChannel = 1;//順序進(jìn)行規(guī)則轉(zhuǎn)換的ADC通道的數(shù)目 ADC_Init(ADC1, &ADC_InitStructure);//根據(jù)指定的參數(shù)初始化外設(shè)ADCx ADC_Cmd(ADC1, ENABLE);//使能指定的ADC1 ADC_ResetCalibration(ADC1);//開啟復(fù)位校準(zhǔn) while(ADC_GetResetCalibrationStatus(ADC1));//等待復(fù)位校準(zhǔn)結(jié)束 ADC_StartCalibration(ADC1);//開啟AD校準(zhǔn) while(ADC_GetCalibrationStatus(ADC1));//等待校準(zhǔn)結(jié)束 } //獲得ADC值 //ch:通道值0~3 u16 Get_Adc(u8 ch) { //設(shè)置指定ADC的規(guī)則組通道,設(shè)置它們的轉(zhuǎn)化順序和采樣時間 ADC_RegularChannelConfig(ADC1, ch, 1, ADC_SampleTime_239Cycles5 ); //通道1,規(guī)則采樣順序值為1,采樣時間為239.5周期 ADC_SoftwareStartConvCmd(ADC1, ENABLE);//使能軟件轉(zhuǎn)換功能 while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ));//等待轉(zhuǎn)換結(jié)束 return ADC_GetConversionValue(ADC1);//返回最近一次ADC1規(guī)則組的轉(zhuǎn)換結(jié)果 } u16 Get_Adc_Average(u8 ch,u8 times) { u32 temp_val=0; u8 t; for(t=0;t<times;t++) { temp_val+=Get_Adc(ch); delay_ms(5); } return temp_val/times; } 編輯main.c文件: int main(void) { u16 adcx; float temp; delay_init();//延時函數(shù)初始化 NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //設(shè)置NVIC中斷分組2 uart_init(115200);//串口初始化波特率為115200 LED_Init();//LED端口初始化 LCD_Init();//LCD初始化 Adc_Init();//ADC初始化 POINT_COLOR=RED;//設(shè)置字體為紅色 LCD_ShowString(60,50,200,16,16,"WarShip STM32"); LCD_ShowString(60,70,200,16,16,"ADC TEST"); LCD_ShowString(60,90,200,16,16,"ATOM@ALIENTEK"); LCD_ShowString(30,110,200,16,16,"2015/1/14"); //顯示提示信息 POINT_COLOR=BLUE;//設(shè)置字體為藍(lán)色 LCD_ShowString(60,130,200,16,16,"ADC_CH0_VAL:"); LCD_ShowString(60,150,200,16,16,"ADC_CH0_VOL:0.000V"); while(1) { adcx=Get_Adc_Average(ADC_Channel_1,10); LCD_ShowxNum(156,130,adcx,4,16,0);//顯示ADC的值 temp=(float)adcx*(3.3/4096); adcx=temp; LCD_ShowxNum(156,150,adcx,1,16,0);//顯示電壓值 temp-=adcx; temp*=1000; LCD_ShowxNum(172,150,temp,3,16,0X80); LED0=!LED0; delay_ms(250); } } 此部分代碼,在TFTLCD模塊上顯示一些提示信息后,將每隔250ms讀取一次ADC通道0的值,并顯示讀到的ADC值(數(shù)字量),以及其轉(zhuǎn)換成模擬量后的電壓值。同時控制LED0閃爍,以提示程序正在運(yùn)行。 |
