松翰單片機(jī)5703例程——IIC
- // FILE: Master_I2C.c
- // Copyright 2014 SONiX Technology Corp. All rights reserved.
- // AUTHOR: SONiX
- // DATE: 2014/11/11
- // The program is an example of Master I2C to implement it.
- // I2C decription:
- // User need to external pull-high at SDA and SCL pin
- // The system clock frequency is IHRC 32MHz
- // Device: SN8F5708
- // Tool chain: KEIL C51 V9.50a
- // Includes
- #include <string.h>
- #include <SN8F5703.h>
- #include "GenericTypeDefs.h"
- // Global Constants
- #define MAXDATALEN 5
- // Global Variables
- UINT8 u8I2CFlag = 0;
- UINT8 u8I2CData[MAXDATALEN];
- UINT8 u8I2CAddr = 0;
- UINT8 u8I2CLen = 0;
- UINT8 u8I2CCnt = 0;
- // Function Prototypes
- void I2C_Init(void);
- UINT8 I2C_Master_Write_One_Byte(UINT8 u8Addr, UINT8 u8data);
- UINT8 I2C_Master_Write_N_Byte(UINT8 u8Addr, UINT8 *u8data, UINT8 u8size);
- UINT8 I2C_Master_Read_N_Byte(UINT8 u8Addr, UINT8 *u8data, UINT8 u8size);
- // Main loop
- void main(void)
- UINT8 u8TxData[MAXDATALEN] = {0xAA,0xBB,0xCC,0xDD,0xEE}; // for test
- UINT8 u8RxData[] = {0};
- UINT8 u8SlaveAddr = 0x2C; // set addr
- CLKSEL = 0x06; // Fcpu = 32M/2 = 16M
- CLKCMD = 0X69;
- CKCON = 0X10;
- WDTR = 0x5A; // clear watchdog if watchdog enable
- P0 = 0;
- P0M = 0;
- P0UR = 0xFF;
- P1 = 0;
- P1M = 0;
- P1UR = 0xFF;
- P2 = 0;
- P2M = 0;
- P2UR = 0xFF;
- I2C_Init();
- // Write one data to slave
- I2C_Master_Write_One_Byte(u8SlaveAddr, u8TxData[0]);
- // Write multi data to slave
- I2C_Master_Write_N_Byte(u8SlaveAddr, u8TxData, sizeof(u8TxData));
- // read 1 data form slave
- I2C_Master_Read_N_Byte(u8SlaveAddr, u8RxData, 1);
- // read multi data form slave
- I2C_Master_Read_N_Byte(u8SlaveAddr, u8RxData, sizeof(u8RxData));
- while (1)
- // Function: void I2C_Init(void)
- // Description:
- // SCL and SDA need to external pull high
- I2CCON = 0x43; // I2C enable (ENS1),Fclk = Fcpu/160 = 100K
- EI2C = 1; // I2C interrupt enable
- EAL = 1; // Interrupt enable
- // Function: UINT8 I2C_Master_Write_One_Byte(UINT8 u8Addr, UINT8 u8Data)
- // Description:
- UINT8 I2C_Master_Write_One_Byte(UINT8 u8Addr, UINT8 u8Data)
- if (!u8I2CFlag) {
- u8I2CFlag = 1; // get Use Right
- u8I2CLen = 1; // set length
- u8I2CCnt = 0; // clear tx count
- u8I2CData[0] = u8Data;
- u8I2CAddr = u8Addr & 0xFE; // write mode
- I2CCON |= 0x20; // START (STA) = 1
- while(u8I2CFlag); // wait Trasmit end
- return TRUE;
- else
- return FALSE;
- // Function: UINT8 I2C_Master_Write_N_Byte(UINT8 u8Addr, UINT8 *u8data, UINT8 u8size)
- // Description:
- if (u8size > MAXDATALEN)
- return FALSE; // over buf size
- if (u8size == 0)
- return FALSE; // error size
- if (!u8I2CFlag) {
- u8I2CLen = u8size; // set length
- memcpy(u8I2CData, u8data, u8size);
- return TRUE;
- else
- return FALSE;
- // Function: UINT8 I2C_Master_Read_N_Byte(UINT8 u8Addr, UINT8 *u8data, UINT8 u8size)
- // Description:
- if (u8size == 0)
- if (!u8I2CFlag) {
- u8I2CCnt = 0;
- u8I2CAddr = u8Addr | 0x01; // read mode
- while(u8I2CFlag); // wait recevier end
- memcpy(u8data, u8I2CData, u8size);
- return TRUE;
- else
- return FALSE;
- // Function: I2C interrupt
- // Description:
- void I2C_ISR(void) interrupt ISRI2c // Vector @ 0x43
- switch (I2CSTA)
- // tx mode
- case 0x08:
- I2CCON &= 0xDF; // START (STA) = 0
- I2CDAT = u8I2CAddr; // Tx/Rx addr
- break;
- case 0x18: // write first byte
- I2CDAT = u8I2CData[u8I2CCnt++];
- u8I2CLen--;
- break;
- case 0x28: // write n byte
- if (u8I2CLen == 0) { // chk length if empty
- I2CCON |= 0x10; // STOP (STO)
- u8I2CFlag = 0;
- u8I2CCnt = 0;
- else {
- u8I2CLen--;
- break;
- // rx mode
- case 0x40: // get slave addr
- if(u8I2CLen > 1) I2CCON |= 0x04; // AA = 1
- else I2CCON &= 0xFB;
- break;
- case 0x50: // read n byte
- u8I2CData[u8I2CCnt++] = I2CDAT;
- if (u8I2CCnt == (u8I2CLen-1)) {
- I2CCON &= 0xFB; // AA = 0
- else {
- I2CCON |= 0x04; // AA = 1
- break;
- case 0x58: // read last byte & stop
- u8I2CData[u8I2CCnt] = I2CDAT;
- u8I2CFlag = 0;
- break;
- default:
- u8I2CFlag = 0;
- I2CCON &= 0xF7; // Clear I2C flag (SI)
5703_I2C_20161104.rar
2020-12-8 11:35 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
115.79 KB, 下載次數(shù): 10, 下載積分: 黑幣 -5
