查看: 1700|回復(fù): 2
單片機(jī)匯編語(yǔ)言串行口通信好像轉(zhuǎn)不了ASCII碼,發(fā)送的數(shù)據(jù)很亂
初學(xué)者,好像轉(zhuǎn)不了ASCII碼,發(fā)送的數(shù)據(jù)很亂,看不明白。或者有相關(guān)實(shí)驗(yàn)的資料推一下也行,謝謝大家。
求修改代碼:
ORG  0000H
AJMP MAIN
ORG  0023H
AJMP RT
ORG 0030H
MAIN:MOV R2,#00H
     MOV R5,#00H
      MOV TMOD,#20H
     MOV SCON,#50H
     MOV TH1,#0F3H
     MOV TL1,TH1
     MOV PCON,#00
     SETB EA;×üÖD¶Ï
     SETB ES;′®DDÖD¶Ï
     SETB TR1;′ò¿a¶¨ê±
LOOP:
     LCALL DISPLAY        ;
     MOV A,P1
     ANL A,#00001111B;
     MOV R5,A
     MOV SBUF,A
     JNB P1.5,DONE
     SJMP  LOOP
DISP:
     CLR RI
     MOV A,SBUF
     MOV R6,A
     CLR CY
     CLR F0
     SUBB A,#58
     MOV F0,C  ;
     JNB F0, _A_F
_0_9:
     MOV A,R6
     SUBB A,#48
     MOV R5,A
     LJMP LOOP
_A_F:
     MOV A,R6
     SUBB A,#55
     MOV R5,A
     LJMP LOOP
RT:
    JBC TI,L0;
    PUSH  ACC
    PUSH  PSW
    CLR RI;
    MOV A,SBUF
    MOV R2,A;
    POP   PSW
    POP   ACC
    ACALL  DISPLAY1
  L0:
       RETI
DISPLAY:
    MOV DPTR,#TAB
    MOV A,R5
    MOVC A,@A+DPTR
    MOV DPTR,#1110000000000100B
    MOVX @DPTR,A
    MOV DPTR,#1110000000000010B
    MOV A,#00010000B
    MOVX @DPTR,A
    ACALL DELAY5MS
    RET
DISPLAY1:
    MOV DPTR,#TAB
    MOV A,R2
    MOVC A,@A+DPTR
    MOVX @DPTR,A
    MOV A,#00001000B
    MOVX @DPTR,A
    ACALL DELAY5MS
    RET
DELAY5MS:
        MOV R4,#250
        MOV  R5,#10
       L6: DJNZ R4,$
        DJNZ R5,L6
                RET
TAB:DB 3FH,06H,5BH,4FH,66H,6DH,7DH,07H,7FH,6FH,77H,7CH,39H,5EH,79H,71H
DONE:
END
ID:860332 發(fā)表于 2020-12-15 11:36 | 只看該作者
看看兩邊的波特率是否一致
ID:938838 發(fā)表于 2021-6-17 21:34 | 只看該作者
1714461639 發(fā)表于 2020-12-15 11:36
看看兩邊的波特率是否一致
兩邊如果波特率不一致,是不是仍然能傳送,只是傳送的數(shù)據(jù)出現(xiàn)問題錯(cuò)亂而已?
