查看: 3021|回復(fù): 1
VL210 USB3.0 Hub
ID:824634 發(fā)表于 2020-12-3 13:46 | 顯示全部樓層 |閱讀模式
VL210是一個(gè)第四代先進(jìn)USB 3.0 Hub控制器。VL210具有四個(gè)下行端口:一個(gè)USB 3.0和3個(gè)USB 2.0端口,每個(gè)端口都可以在不需要外掛電源IC就可以實(shí)現(xiàn)充電器的功能。VL210擁有先進(jìn)的CMOS工藝,能夠大大降低功耗并在低功耗狀態(tài)下完全支持USB電源管理。客戶可對(duì)USB PHY進(jìn)行自定義,并可以給VL210各種信道提供良好的性能,使得VL210可支持新2.4GHz Radio Friendly mode的USB EMI認(rèn)證。VL210特點(diǎn)是一個(gè)高度靈活的固件架構(gòu),給客戶提供一個(gè)框架用于客戶自行開發(fā)其他高級(jí)功能。
VIA的VL210可工作在Windows,Mac OS X,Linux等系統(tǒng)。VL210還可以兼容非x86的設(shè)備和平臺(tái),支持USB集線器功能,如智能手機(jī)、平板電腦和機(jī)頂盒。它適合所有USB集線器應(yīng)用,如獨(dú)立的USB集線器,筆記本/ Ultrabook停靠點(diǎn)/ port-replicators,臺(tái)式電腦前面板,二合一平板電腦,和USB集線器復(fù)合設(shè)備。
VL210集成了過(guò)流保護(hù)電路,GPIO、LED控制,SPI接口還可支持USB更新EEPROM/Flash ROM,是一個(gè)設(shè)計(jì)具有高水準(zhǔn)、簡(jiǎn)潔的布局設(shè)計(jì)和簡(jiǎn)化的BOM成本的完美設(shè)計(jì)。
- Compliant to USB 3.0 specification revision 1.0, and USB specification revision 2.0
- Fully integrated single chip implementation
- One up-stream supports Super-speed, high-speed and full-speed traffic
- Four down-stream ports; one port supports Super-speed, high-speed and full-speed traffic, and three ports support high-speed and full-speed traffic
- Charging Downstream Port(CDP), feature for rapid-charging
- In-house USB PHY employs advanced CMOS process for  low power consumption
- Supports USB 3.0 low power states
- Supports full sideband signal functions include gang mode and LED status lights
- Full software support for Windows 8, 7, Vista, XP, 2003, 2000, ME and Mac OS 10X and various Linux kernels
ID:485499 發(fā)表于 2024-11-10 22:33 | 顯示全部樓層
請(qǐng)問(wèn)有參考設(shè)計(jì)嗎
