八位數(shù)碼管電子時鐘
代碼
#include <reg51.h>
sbit key1 = P1^0;
bit flag1s = 0;
bit KeySta = 1;
unsigned char hour = 8;
unsigned char minute = 31;
unsigned char second = 59;
unsigned char mode = 0;
void FreshTime();
void TimeInit();
void IntInit();
void InitLedBuff();
void keyscan();
unsigned char code LedChar[] = { //共陰數(shù)碼管顯示字符轉(zhuǎn)換表
0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x40,0x00};
unsigned char LedBuff[8] = { //數(shù)碼管顯示緩沖區(qū)
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff};
TimeInit();
IntInit();
InitLedBuff();
while(1)//顯示內(nèi)容處理
if(flag1s&&!mode) //時間顯示模式
flag1s = 0;
FreshTime();
else if(mode == 1) //校準分鐘
LedBuff[0] = 17;
LedBuff[1] = 17;
LedBuff[4] = 17;
LedBuff[5] = 17;//不顯示
LedBuff[6] = 17;
LedBuff[7] = 17;
LedBuff[2] = minute/10;
LedBuff[3] = minute%10;
else if(mode == 2) //校準小時
LedBuff[2] = 17;
LedBuff[3] = 17;
LedBuff[4] = 17;
LedBuff[6] = 17;
LedBuff[7] = 17;
LedBuff[0] = hour/10;
LedBuff[1] = hour%10;
else if(mode == 3) //校準完成重新顯示
InitLedBuff();
mode = 0;
keyscan();
void InitLedBuff()//初始化時間到顯示緩沖區(qū)
LedBuff[4] = second/10;
LedBuff[5] = second%10;
void FreshTime()//刷新時間到顯示緩沖區(qū)
second++;
if(second == 60)//進位
second = 0;
minute++;
if(minute==60)//進位
minute=0;
hour++;
if(hour == 24)
hour = 0;
void TimeInit()//定時器初始化
TMOD = 0X11; //設(shè)置定時器為模式1
TL0 = 0xB0;
TH0 = 0x3C; //定時初值 50ms
TL1 = 0x18; //
TH1 = 0xFC; //定時初值 1ms
TR0 = 1; //定時器0開始計時
TR1 = 1; //定時器1開始計時
ET1 = 1; //使能定時器1
ET0 = 1; //使能定時器0
PT0 = 1; //提高計時準確性,提高定時器0中斷優(yōu)先級
EA = 1; //打開總中斷
void IntInit()//外部中斷初始化
IT0 = 1; //下降沿觸發(fā)
EX0 = 1; //使能外部中斷0
void keyscan() //按鍵掃描及處理
static bit backup = 1;
if (KeySta != backup) //當前值與前次值不相等說明此時按鍵有動作
if (backup == 0) //如果前次值為0,則說明當前是彈起動作
if(mode == 1) //校準分鐘時,分鐘加一
minute++;
if(minute==60)
minute = 0;
else if(mode == 2) //校準小時,小時加一
hour++;
if(hour==24)
hour = 0;
backup = KeySta; //更新備份為當前值,以備進行下次比較
void Int0() interrupt 0
mode++;
if(mode == 4)
mode = 0;
void Ledfresh() //數(shù)碼管顯示刷新
static unsigned char i = 0;
switch(i)
case 0 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff[0]];i++;break;
case 1 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff[1]];i++;break;
case 2 : P2 = ~(0x01<<i);P0 = 0x40;i++;break;//時分間隔線
case 3 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff[2]];i++;break;
case 4 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff[3]];i++;break;
case 5 : P2 = ~(0x01<<i);P0 = 0x40;i++;break;//分秒間隔線
case 6 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff[4]];i++;break;
case 7 : P2 = ~(0x01<<i);P0 = LedChar[LedBuff[5]];i=0;break;
void Time0() interrupt 1 // 50ms
static unsigned char n = 0;
TL0 = 0xB0;
TH0 = 0x3C;
n++;
if(n==20)
n=0;
flag1s = 1;//1s標志位
void Time1() interrupt 3 // 1ms
static unsigned char keybuff = 0xff;
TL1 = 0x18; //
Ledfresh();
keybuff = (keybuff<<1)|key1;
if (keybuff == 0x00)
{ //連續(xù)8次掃描值都為0,即16ms內(nèi)都只檢測到按下狀態(tài)時,可認為按鍵已按下
KeySta = 0;
else if (keybuff == 0xFF)
{ //連續(xù)8次掃描值都為1,即16ms內(nèi)都只檢測到彈起狀態(tài)時,可認為按鍵已彈起
KeySta = 1;
{} //其它情況則說明按鍵狀態(tài)尚未穩(wěn)定,則不對KeySta變量值進行更新
八位數(shù)碼管電子時鐘.zip
2020-12-2 21:41 上傳
下載積分: 黑幣 -5
18.14 KB, 下載次數(shù): 64, 下載積分: 黑幣 -5
