按你的要求,寫了下,仿真通過
P0口接數(shù)碼管,
#include<reg52.h>
#include<intrins.h>
uchar led_tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00}; //共陰數(shù)碼管段碼 0-9
uchar led_num; //LED計數(shù)值
uchar num_L,num_H; //LED計數(shù)值高低位分離
uint key_cont; //按鍵消抖計數(shù)
bit key_lock; //按鍵自鎖標志
sbit P20=P2^0; //數(shù)碼管 個位
sbit P21=P2^1; // 數(shù)碼管 十位
sbit key = P3^0; //按鍵
void delayms(uint ms)
uint i,j;
for(j = 0; j < ms; j--)
for(i = 0;i < 120; i++);
void display()
if(led_num<10)
P20=0;
P21=1;
P0=led_tab[led_num];
delayms(10);
num_L=led_num%10;
num_H=led_num/10;
P20=1;
P0=led_tab[num_H];
P21=0;
delayms(5);
P21=1;
P0=led_tab[num_L];
P20=0;
delayms(5);
void keyscan()
if(key) //按鍵沒按下
key_cont = 0;
key_lock = 0;
else if(key_lock == 0) //短按
key_cont++;
if(key_cont>100)
key_lock = 0;
key_lock = 1;
led_num++;
if(led_num>100)
led_num=0;
else if(key_cont<1000) //長按
key_cont++;
if(key_cont==1000)
key_cont=900; //這里調(diào)節(jié)長按連加的速度
led_num+=10;
if(led_num>100)
led_num=0;
void main(void)
led_num=21;
display();
keyscan();
