查看: 1507|回復: 1
做單片機呼吸燈遇到的問題,為什么中斷沒反應呢?
#include<reg51.h>
#include<stdio.h>
#include<stdlib.h>
unsigned char ZHOUQI_COUNT;
unsigned char PWM_VLAUE;
int i;
unsigned int UPDATA_COUNT;
bit direc_flag;
sbit LED=P1^0;
sbit LED1=P0^0;
sbit LED2=P0^1;
sbit LED3=P0^2;
void timer0_init();
void int0_init();
void timer0_init()
        TMOD = 0x02;
                TH0=0XA3;
        TL0=0XA3;
        ET0=1;
        IT0=1;
        TR0=1;
                EA=1;
        EX0=1;
        EX1=1;
        IT1=1;
        IT0=1;
        IP=0x05;
{ZHOUQI_COUNT=0;
UPDATA_COUNT=0;
        PWM_VLAUE=10;
        i=0;
        direc_flag=0;
        LED=0;
        timer0_init();
        while(1);
void int0()interrupt 0
        switch(i){case 0:LED1=0;i++;break;
                case 1:LED2=0;i++;break;
                case 2:LED1=1,i++;break;
                case 3:LED3=0,i++;break;
                case 4:LED2=1,i++;break;
                case 5:LED1=0,i++;break;
                case 6:LED2=0,i++;break;
                 default:LED1=1,LED2=1,LED3=1;i=0;break;}
                void int1()interrupt 2
                        void time0() interrupt 1
{ZHOUQI_COUNT++;
        UPDATA_COUNT++;
        if(ZHOUQI_COUNT==PWM_VLAUE)
                LED=1;
        if(ZHOUQI_COUNT==20)
        {LED=0;
                ZHOUQI_COUNT=0;
        if((UPDATA_COUNT==1200)&&(direc_flag==0))
                UPDATA_COUNT=0;
                PWM_VLAUE++;
                if(PWM_VLAUE==19)
                        direc_flag=1;
        if((UPDATA_COUNT==1200)&&(direc_flag==1))
                UPDATA_COUNT=0;
                PWM_VLAUE--;
                if(PWM_VLAUE==1)
                        direc_flag=0;
為什么中斷沒反應呢
ID:278840 發表于 2020-11-27 09:13 | 只看該作者
                        void time0() interrupt 1。。。
這里錯了
