查看: 2603|回復: 7
在12864.h以下代碼是什么意思?
ID:839448 發(fā)表于 2020-11-24 16:20 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
#ifndef __LCD12864_H__
#define __LCD12864_H__
#define LCD_RS_L            GPIO_ResetBits(GPIOG, GPIO_Pin_8)                  //RS = PG8
#define LCD_RS_H            GPIO_SetBits(GPIOG, GPIO_Pin_8)
#define LCD_RW_L            GPIO_ResetBits(GPIOG, GPIO_Pin_9)                   //RW = PG9
#define LCD_RW_H            GPIO_SetBits(GPIOG, GPIO_Pin_9)
#define LCD_EN_L            GPIO_ResetBits(GPIOG, GPIO_Pin_10)                     //EN = PG10
#define LCD_EN_H            GPIO_SetBits(GPIOG, GPIO_Pin_10)
#define LCD_DataIn          P8DIR = 0x00                    //數(shù)據(jù)口方向設置為輸入
#define LCD_DataOut         P8DIR = 0xff                    //數(shù)據(jù)口方向設置為輸出
#define LCD_RST_L           GPIO_ResetBits(GPIOG, GPIO_Pin_11)                  // RST= PG11
#define LCD_RST_H           GPIO_SetBits(GPIOG, GPIO_Pin_11)
#define DATA_12864                 GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7
#define BSP_GPIOG_SW1         GPIO_Pin_12                       //sw1=PG12
#define BSP_GPIOG_SW2         GPIO_Pin_13                       //sw1=PG13
#define BSP_GPIOG_SW3         GPIO_Pin_14                       //sw1=PG14
#define BSP_GPIOG_SW4         GPIO_Pin_15                       //sw1=PG15
//void LCD_GPIO_Init();
unsigned char LCD_Busy();
void LCD_WriteCommand(unsigned char Cmd);
void LCD_WriteData(unsigned char Dat);
void LCD_Init();
void LCD_Position(unsigned char X,unsigned char Y);
void LCD_Flash();
void  LCD_Char_Display();
void LCD_Clear_Screen();
void gpio_12864_initout();
const unsigned char Photo1[] ={
      0x00,0x00,0x00,0x04,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x01,0x3F,0xC0,
      0x80,0x42,0x04,0x20,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0x8A,0x1F,
      0xFC,0x42,0x04,0xF8,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0x80,
      0x01,0xFF,0xDE,0x88,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x01,0x2A,0x87,
      0xF0,0xA2,0x0A,0xF8,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0xBF,0x84,
      0x10,0xA2,0x0A,0x88,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x1F,
      0xFC,0xA2,0x0A,0xF8,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0x9F,0x90,
      0x05,0x2F,0xCA,0xA4,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x01,0x80,0x03,
      0xE1,0xA8,0x4A,0xA8,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0xBF,0xC2,
      0x24,0x48,0x44,0x90,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0x92,0x84,
      0x24,0xA8,0x4A,0xA8,0x00,0x00,0x00,0x00,
      0x00,0x00,0x00,0x00,0x00,0x00,0xA6,0x58,
      0x3D,0x0F,0xD0,0xC4,0x00,0x00,0x00,0x00,
      0x00,0x1C,0xFF,0xC0,0x00,0x00,0x00,0x00,
      0x00,0x23,0x08,0x37,0x80,0x00,0x00,0x00,
      0x00,0x40,0x10,0x08,0x40,0x00,0xFF,0x90,
      0x10,0x08,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x81,0x86,0x10,0x40,0x00,0x08,0x08,
      0x10,0xFF,0x86,0x00,0x00,0x00,0x00,0x00,
      0x01,0x02,0x49,0x40,0x40,0x00,0x7F,0x0B,
      0xFC,0x08,0x0F,0x00,0x00,0x00,0x00,0x00,
      0x01,0x08,0x00,0x40,0x20,0x00,0x10,0x00,
      0x10,0x49,0x0F,0x00,0x00,0x00,0x00,0x00,
      0x02,0x08,0x00,0x20,0x20,0x01,0xFF,0xDD,
      0x10,0x2A,0x0F,0x00,0x00,0x00,0x00,0x00,
      0x04,0x31,0x83,0x20,0x20,0x00,0x20,0x04,
      0x91,0xFF,0xC6,0x00,0x00,0x00,0x00,0x00,
      0x04,0x52,0x44,0x90,0x20,0x00,0x7F,0x04,
      0x90,0x1C,0x06,0x00,0x00,0x00,0x00,0x00,
      0x09,0xA4,0x28,0x4C,0x10,0x00,0xA1,0x04,
      0x10,0x2A,0x00,0x00,0x00,0x00,0x00,0x00,
      0x0E,0x44,0xE9,0xC3,0x90,0x01,0x3F,0x04,
      0x70,0x49,0x06,0x00,0x00,0x00,0x00,0x00,
      0x00,0x82,0xC5,0x81,0x70,0x00,0x21,0x0A,
      0x01,0x88,0xC6,0x00,0x00,0x00,0x00,0x00,
      0x01,0x01,0x83,0x00,0x80,0x00,0x3F,0x11,
      0xFC,0x08,0x00,0x00,0x00,0x00,0x00,0x00,
      0x01,0x0C,0x70,0x00,0x80,0x00,0x00,0x00,
      0x02,0x13,0x87,0x10,0x40,0x00,0x00,0x00,
      0x02,0x20,0x78,0xA0,0x40,0x00,0x00,0x00,
      0x02,0x20,0x00,0x60,0x40,0x00,0x00,0x00,
      0x02,0x21,0x80,0x60,0x40,0x00,0x00,0x71,
      0xEE,0x3C,0x00,0x00,0x00,0x00,0x00,0x00,
      0x01,0x11,0x98,0x90,0x80,0x00,0x00,0x8E,
      0x31,0xC6,0x00,0x00,0x00,0x00,0x00,0x00,
      0x01,0x08,0x18,0x80,0x80,0x00,0x01,0x24,
      0x24,0x83,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x96,0x01,0x01,0x00,0x00,0x01,0x40,
      0x28,0x03,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x49,0x86,0x03,0x00,0x00,0x01,0x40,
      0x00,0x34,0x78,0x8C,0x00,0x00,0x01,0x00,
      0x20,0x03,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x0E,0x01,0x30,0x00,0x00,0x00,0x80,
      0x30,0x06,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0x71,0x87,0xCE,0x00,0x00,0x00,0x40,
      0x68,0x0C,0x00,0x00,0x00,0x00,0x00,0x00,
      0x00,0xE0,0x78,0x07,0x00,0x00,0x00,0x20,
      0xC4,0x18,0x00,0x00,0x00,0x00,0x00,0x00,
      0x01,0xAF,0xFF,0xC5,0x80,0x00,0x00,0x11,
      0x82,0x30,0x00,0x00,0x00,0x00,0x00,0x00,
      0x03,0xA9,0xB6,0x45,0xC0,0x00,0x00,0x0B,
      0x01,0x60,0x00,0x00,0x00,0x00,0x00,0x00,
      0x07,0x2F,0x03,0xC4,0xE0,0x00,0x00,0x06,
      0x00,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,
      0x0E,0x16,0x01,0x88,0x70,0x00,0x00,0x00,
      0x0F,0x08,0x00,0x10,0xF0,0x00,0x00,0x00,
      0x0F,0x84,0x00,0x21,0xF0,0x00,0x00,0x00,
#endif
ID:917397 發(fā)表于 2021-5-11 19:09 | 只看該作者
定義接口和函數(shù)
ID:790408 發(fā)表于 2020-12-5 11:28 | 只看該作者
是一些圖片數(shù)數(shù)據(jù),如圖片多大,字符多大,什么字體等
ID:517466 發(fā)表于 2020-12-5 11:07 | 只看該作者
定義和12864的硬件接口信息,以及接口函數(shù)聲明。通過這些接口和函數(shù)實現(xiàn)嵌入式開發(fā)板與12864之間進行通訊。最底下的photo代碼是預先定義一個圖片的數(shù)據(jù)。用來在液晶上顯示圖片。
ID:517951 發(fā)表于 2020-12-5 09:03 | 只看該作者
.h文件定義了控制信號reset,EN,RS等引腳的GPIO高低電平,顯示函數(shù)的聲明,后面的數(shù)組是顯示圖片的數(shù)據(jù)
ID:758126 發(fā)表于 2020-12-3 11:31 | 只看該作者
定義lcd12864端口的變量
ID:674033 發(fā)表于 2020-11-27 09:18 | 只看該作者
在.h文件定義變量、端口號等等,可以減少主程序的代碼量,更清晰一點,方便看程序。
ID:97554 發(fā)表于 2020-11-24 18:10 | 只看該作者
這個我這沒入門的都能看個大概,如果這個都不明白,建議還是耐心的學一下基礎的東西,這玩意貪不得快。
那些代碼無非就是定義了一些字符串短的替代長的在寫程序的時候相對簡單些,還有些引腳定義,一些子函數(shù)定義,最下邊那一堆是一個圖片的數(shù)組。
參與人數(shù) 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎勵!
