查看: 3505|回復: 0
單片機LCD12864液晶串行顯示源程序
ID:558259 發表于 2020-11-20 17:28 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
程序代碼分為12864.c文件、12864.h頭文件、main.c文件,3個文件程序代碼如下
(1)12864.c文件程序代碼
#include"lcd12864.h"
#include"reg52.h"
sbit CS=P1^0;                                   //RS(CS)數據/命令選擇端(H/L)(串片選)
sbit SID=P1^1;                                   //R/W(SID)讀/寫命令選擇端(H/L)(串數據口)
sbit SCLK=P1^2;                                   //E(SLCK)使能信號(串同步時鐘信號端)
/*  延時函數                                             */
void delayms(unsigned int xms)
    uint i,j;
    for(i=xms;i>0;i--)
        for(j=110;j>0;j--);
/*  發送一個字節                                             */
void lcd_sent_beyt(unsigned char date)
    uchar k=0;
    for(k=0;k<8;k++)
        if((date<<k)&0x80)
            SID=1;
            SID=0;
        SCLK=0;
        SCLK=1;
    delayms(2);
/*   寫數據                                            */
void lcd_write_data(unsigned char date)
    CS=1;
    lcd_sent_beyt(0xfa);
    lcd_sent_beyt(date&0xf0);
    lcd_sent_beyt((date<<4)&0xf0);
    delayms(1);
    CS=0;
/*  寫命令                                             */
void lcd_write_cmd(unsigned char date)
    CS=1;
    lcd_sent_beyt(0xf8);
    delayms(1);
    CS=0;
/*  坐標函數                                             */
void lcd_pos(unsigned char X,unsigned Y)
    uchar pos;
    if(X==0)
    {X=0x80;}
    else if(X==1)
    {X=0x90;}
    else if(X==2)
    {X=0x88;}
    else if(X==3)
    {X=0x98;}
    pos=X+Y;
    lcd_write_cmd(pos);
/*  12864液晶初始化                                             */
void lcd_init()
    lcd_write_cmd(0x30);
    delayms(1);
    lcd_write_cmd(0x0c);
    delayms(1);
    lcd_write_cmd(0x01);
    delayms(1);
/*  中英文字符顯示函數                                             */
void writestring(unsigned char X,unsigned Y,unsigned char *p)
    lcd_pos(X,Y);
    while(*p!='\0')
        lcd_write_data(*p);
        p++;
(2)lcd12864.h頭文件代碼如下,要完全參照模塊化編程所需格式書寫
#ifndef LCD12864_H
#define LCD12864_H
extern void delayms(unsigned int xms);
extern void lcd_write_cmd(unsigned char date);
extern void lcd_write_data(unsigned char date);
extern void lcd_sent_beyt(unsigned char date);
extern void lcd_pos(unsigned char X,unsigned Y);
extern void lcd_init();
extern void writestring(unsigned char X,unsigned Y,unsigned char *p);
#endif
(3)main.c文件代碼
#include"reg52.h"
void lcd_init();
void testring(unsigned char *p);
char keyscan();                                       //定義獨立按鍵函數
sbit key1=P2^0;                                       //聲明單片機口P3口的第5位
sbit key2=P2^1;                                       //聲明單片機口P3口的第4位
sbit key3=P2^2;                                       //聲明單片機口P3口的第3位
sbit key4=P2^3;                                       //聲明單片機口P3口的第2位
uchar a,key,b;
/*  主函數,按鍵控制顯示                                     */
    lcd_init();
        a=keyscan();
        if(a==1)
            writestring(0,0,"202011205555");
        a=keyscan();
        if(a==2)
            writestring(1,0,"51電子黑論壇");
        a=keyscan();
        if(a==3)
            writestring(2,0,"12846液晶顯示");
        a=keyscan();
        if(a==4)
            writestring(3,0,"串行通信");
/*  獨立按鍵控制                                             */
char keyscan()                                       //定義獨立按鍵函數,設計有返回值的函數更加方便,
{                                                   //注意有返回值函數的類型為返回值的類型
    if(key1==0)                                       //當key1按下時
    {                                               //軟件防抖動
        delayms(10);
        if(key1==0)
            key=1;
            while(!key1);                           //等待按鍵釋放/***若按鍵沒有釋放則key1始終為0,那么!key1始終為1。
    if(key2==0)                                       //當key2按下時
        delayms(10);                               //軟件防抖動
        if(key2==0)
            key=2;
            while(!key2);                           //等待按鍵釋放/***若按鍵沒有釋放則key2始終為0,那么!key2始終為1。
    if(key3==0)                                       //當key3按下時
            if(key3==0)
            key=3;
            while(!key3);                           //等待按鍵釋放/***若按鍵沒有釋放則key3始終為0,那么!key3始終為1。
    if(key4==0)                                       //當key3按下時
            if(key4==0)
            key=4;
            while(!key4);                           //等待按鍵釋放/***若按鍵沒有釋放則key3始終為0,那么!key3始終為1。
    return key;
