查看: 5613|回復: 5
關于ADC0831讀取熱敏電阻如何轉化為阻值并顯示溫度
50黑幣
購買了一個ADC0831就試著編寫程序,讀取電壓值正確。使用NTC(3950   10K)顯示溫度,但是在轉換阻值與查表卻無法編寫出正確的程序,經多次實驗還是無法寫出程序,實屬無奈還請大神不吝賜教,給予文獻作為參考不勝感激!!!單片機使用;STC89C52;
#include <reg52.h>
#include <intrins.h>
sbit SCK = P1^0;    //11腳數據時鐘
sbit RCK = P1^1;    //12腳輸出時鐘
sbit SI  = P1^2;    //14腳數據
sbit CS=P1^3;        //ADC片選信號
sbit CLK=P1^4;        //ADC時鐘信號
sbit DO=P1^5;        //ADC數據接口
unsigned int NTC_R;//定義熱敏電阻阻值變量
unsigned char code segmcode[]={
    0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90  //共陰極數碼管段碼0-9
unsigned int code Ttable[106][2]={//溫度與電阻阻值對應關系表格
0,3274,//0度對應阻值32.74k
1,3111,//1度對應阻值31.11k
2,2957,//2度對應阻值29.57k
3,2812,//
4,2674,//
5,2545,
6,2422,
7,2306,
8,2196,
9,2092,
10,1993,
11,1900,
12,1811,
13,1728,
14,1648,
15,1573,
16,1501,
17,1433,
18,1369,
19,1308,
20,1250,
21,1194,
22,1142,
23,1092,
24,1045,
25,1000,//25度對應阻值10k
26,957,//26度對應阻值9.57k
27,916,
28,877,
29,840,
30,805,
31,771,
32,739,
33,709,
34,679,
35,652,
36,625,
37,600,
38,576,
39,553,
40,531,
41,510,
42,490,
43,471,
44,453,
45,435,
46,418,
47,402,
48,387,
49,372,
50,358,
51,345,
52,332,
53,320,
54,308,
55,297,
56,286,
57,276,
58,266,
59,256,
60,247,
61,238,
62,230,
63,222,
64,214,
65,207,
66,199,
67,193,
68,186,
69,180,
70,174,
71,168,
72,162,
73,157,
74,        152,
75,        147,
76,        142,
77,        137,
78,        133,
79,        128,
80,        124,
81,        120,
82,        116,
83,        113,
84,        109,
85,        106,
86,        102,//86度對應阻值1.02k
87,        99,//87度對應阻值0.99k
88,        96,
89,        93,
90,        90,
91,        88,
92,        85,
93,        82,
94,        80,
95,        78,
96,        75,
97,        73,
98,        71,
99,        69,
100,67,
101,65,
102,63,
103,61,
104,59,
105,58//105度對應阻值0.58k
unsigned char data bitcode[4]={0,0,0,0};  //數碼管顯示位置 1-4
unsigned int date,i;
void hc595(uchar num)
    uchar i;
    for(i=0;i<8;i++)
        SI=(num<<i)&0x80;
        SCK=0;
        _nop_();
        SCK=1;
        SCK=0;
    RCK=0;
    _nop_();
    RCK=1;
    RCK=0;
unsigned char ad_conv(void){
        unsigned char i,com;
        CS=1;
        CLK=0;        _nop_();        _nop_();
        CS=0;        _nop_();        _nop_();//CS置低,啟動轉換
    CLK=1;        _nop_();        _nop_();
        CLK=0;        _nop_();        _nop_();//第一個下降沿,準備輸出數據
        for(i=8;i>0;i--){
                CLK=1;        //第二至九個下降沿
        _nop_();
        _nop_();
                com<<=1;//左移,先采最高位
                if(DO)com++;//采當前數據
                CLK=0;
                _nop_();
            _nop_();
        CS=1;
    _nop_();
    _nop_();
        return com;
//數碼管顯:
void display()
        static uchar i=0;
        bitcode[0]=segmcode[date/100]   ;
        bitcode[1]=segmcode[date%100/10];
        bitcode[2]=segmcode[date%10];
        P0=0xFF;
        hc595(0x01<<i);
        P0=bitcode[i];
        i++;
        i%=3;
void main(void)
   uchar i = 0;
            i++;
            if(i==100)
                i=0;
                date=ad_conv()*100;
                date=date/51;
            display();      //顯示
最佳答案
查看完整內容
給你寫了一個簡單的溫度表示例,8位ADC溫度不是很準確,需要補充完善,但程序框架和邏輯沒有問題。
ID:213173 發表于 2020-11-20 16:18 | 只看該作者
1P1P 發表于 2020-11-23 13:35
是的更改了你給的電壓碼表,電壓值轉換阻值/溫度顯示錯誤,麻煩看一下是不是我的轉換程序錯誤,試了很多 ...
  1. #include "reg52.h"
  2. #include <intrins.h>
  4. #define uint unsigned int
  5. sbit CS =P1^0;
  6. sbit CLK=P1^1;
  7. sbit DO =P1^2;
  8. //順序共陰極數碼管段碼表,段碼a-h順序接PX0-PX7
  9. uchar code table[]={//共陰數碼管段碼"0~f-."
  10.                 0x3f,0x06,0x5b,0x4f,
  11.                 0x66,0x6d,0x7d,0x07,
  12.                 0x7f,0x6f,0x77,0x7c,
  13.                 0x39,0x5e,0x79,0x71,0x40,0x80};
  14. uchar data dis_buf[4];
  15. uchar code Temp[102]={
  16. 239         ,//        0
  17. 238         ,//        1
  18. 237         ,//        2
  19. 236         ,//        3
  20. 235         ,//        4
  21. 234         ,//        5
  22. 233         ,//        6
  23. 232         ,//        7
  24. 231         ,//        8
  25. 230         ,//        9
  26. 229         ,//        10
  27. 227         ,//        11
  28. 226         ,//        12
  29. 225         ,//        13
  30. 224         ,//        14
  31. 222         ,//        15
  32. 221         ,//        16
  33. 219         ,//        17
  34. 218         ,//        18
  35. 216         ,//        19
  36. 215         ,//        20
  37. 213         ,//        21
  38. 212         ,//        22
  39. 210         ,//        23
  40. 208         ,//        24
  41. 207         ,//        25
  42. 205         ,//        26
  43. 203         ,//        27
  44. 201         ,//        28
  45. 199         ,//        29
  46. 197         ,//        30
  47. 195         ,//        31
  48. 193         ,//        32
  49. 191         ,//        33
  50. 189         ,//        34
  51. 187         ,//        35
  52. 185         ,//        36
  53. 183         ,//        37
  54. 181         ,//        38
  55. 179         ,//        39
  56. 177         ,//        40
  57. 174         ,//        41
  58. 172         ,//        42
  59. 170         ,//        43
  60. 168         ,//        44
  61. 165         ,//        45
  62. 163         ,//        46
  63. 161         ,//        47
  64. 158         ,//        48
  65. 156         ,//        49
  66. 154         ,//        50
  67. 151         ,//        51
  68. 149         ,//        52
  69. 147         ,//        53
  70. 144         ,//        54
  71. 142         ,//        55
  72. 140         ,//        56
  73. 137         ,//        57
  74. 135         ,//        58
  75. 133         ,//        59
  76. 130         ,//        60
  77. 128         ,//        61
  78. 126         ,//        62
  79. 124         ,//        63
  80. 121         ,//        64
  81. 119         ,//        65
  82. 117         ,//        66
  83. 115         ,//        67
  84. 112         ,//        68
  85. 110         ,//        69
  86. 108         ,//        70
  87. 106         ,//        71
  88. 104         ,//        72
  89. 102         ,//        73
  90. 100         ,//        74
  91. 98         ,//        75
  92. 96         ,//        76
  93. 94         ,//        77
  94. 92         ,//        78
  95. 90         ,//        79
  96. 88         ,//        80
  97. 86         ,//        81
  98. 84         ,//        82
  99. 83         ,//        83
  100. 81         ,//        84
  101. 79         ,//        85
  102. 77         ,//        86
  103. 76         ,//        87
  104. 74         ,//        88
  105. 72         ,//        89
  106. 71         ,//        90
  107. 69         ,//        91
  108. 68         ,//        92
  109. 66         ,//        93
  110. 65         ,//        94
  111. 63         ,//        95
  112. 62         ,//        96
  113. 61         ,//        97
  114. 59         ,//        98
  115. 58         ,//        99
  116. 57         ,//        100
  117. 56          //        101
  118. };
  119. uchar Read_ADC0831()
  120. {
  121.         uchar i,temp;
  122.         DO=1;
  123.         _nop_();
  124.         _nop_();
  125.         CS=0;
  126.         _nop_();
  127.         _nop_();
  128.         CLK=0;
  129.         _nop_();
  130.         _nop_();
  131.         CLK=1;
  132.         _nop_();
  133.         _nop_();
  134.         CLK=0;
  135.         _nop_();
  136.         _nop_();
  137.         CLK=1;
  138.         _nop_();
  139.         _nop_();
  140.         CLK=0;
  141.         _nop_();
  142.         _nop_();
  143.         for(i=0;i<8;i++)
  144.         {
  145.                 CLK=1;
  146.                 _nop_();
  147.                 _nop_();
  148.                 temp<<=1;
  149.                 if(DO) temp++;
  150.                 CLK=0;
  151.                 _nop_();
  152.                 _nop_();
  153.         }
  154.         CS=1;
  155.         _nop_();
  156.         _nop_();
  157.         return temp;
  158. }
  159. void display()
  160. {
  161.         static uchar i=0;
  162.         P0=0x00;
  163.         P2=~(0x01<<i);
  164.         P0=dis_buf[i];
  165.         i++;
  166.         i%=4;
  167. }
  168. void delay(uint n)
  169. {
  170.         uint i,j;
  171.         for(i=n;i>0;i--)
  172.                 for(j=120;j>0;j--);
  173. }
  174. /*******主函數********/
  175. void main()
  176. {
  177.         uint i,T,date;
  178.         while(1)
  179.         {
  180.                 date=Read_ADC0831();
  181.                 for(i=0;i<101;i++)
  182.                 {
  183.                         if(date<=Temp[i]&&date>Temp[i+1])
  184.                         {
  185.                                 T=i;
  186.                                 break;
  187.                         }
  188.                 }
  189.                 dis_buf[0]=table[T/100];
  190.                 dis_buf[1]=table[T/10%10];
  191.                 dis_buf[2]=table[T%10];
  192.                 dis_buf[3]=0x39;//'C'
  193.                 display();
  194.                 delay(1);
  195.         }
  196. }
ID:213173 發表于 2020-11-21 16:04 | 只看該作者
ADC0831需要輸入的是電壓值,電壓范圍0~VCC。要根據生產商提供的溫度/阻值資料制作數據表。獲取的ADC轉換值通過查表得到當前溫度值。 10K B3950 NTC溫阻電壓編碼表 上偏電阻2.4K.zip (23.96 KB, 下載次數: 29)
ID:709561 發表于 2020-11-23 13:35 | 只看該作者
wulin 發表于 2020-11-21 16:04
ADC0831需要輸入的是電壓值,電壓范圍0~VCC。要根據生產商提供的溫度/阻值資料制作數據表。獲取的ADC轉換值 ...
是的更改了你給的電壓碼表,電壓值轉換阻值/溫度顯示錯誤,麻煩看一下是不是我的轉換程序錯誤,試了很多次顯示還是錯的,還是摸不著頭腦。
//電壓換算成溫度//與上面程序對應
void temp_data()
   float Rt=0;
   float Rp=10000;
   float T2=273.15+25;
   float Bx=3950;
   float Ka=273.15;
   float vol=0;
   vol=(float)((date)*(5/256));
   Rt=(5-vol)*10000/vol;
   temp=1/(1/T2+log(Rt/Rp)/Bx)-Ka+0.5;
ID:709561 發表于 2020-11-25 11:16 | 只看該作者
wulin 發表于 2020-11-23 19:36
多謝你給予的幫助!!!
ID:398219 發表于 2023-3-1 20:27 | 只看該作者
1P1P 發表于 2020-11-25 11:16
多謝你給予的幫助!!!
樓主,單片機AD采集的固定電阻和NTC電阻中間,分出來的電壓,你是怎么轉換成阻值的呢,謝謝指導
