查看: 2750|回復: 0
STM8L0單片機+L76C GPS+DMA+串口源程序
ID:420860 發表于 2020-11-18 16:04 | 顯示全部樓層 |閱讀模式
本程序用于太陽能同步霧燈,可通過DMA+USART1接收移遠GPS模塊(L76C)實現同步閃爍。
  1. #include "stm8l15x.h"
  2. #include "led.h"
  3. #include "lamp.h"
  4. #include "adc.h"
  5. #include "usart1.h"
  6. #include "timer.h"
  7. #include "switch.h"
  8. #include "gps.h"
  9. #include "dma.h"
  10. void main()
  11. {
  12.   disableInterrupts();   //關閉系統總中斷
  13.   CLK_SYSCLKDivConfig(CLK_SYSCLKDiv_1); //內部時鐘為1分頻 = 16Mhz
  14.
  15.   LEDInit();
  16.   LAMPInit();
  17.   SWITCHInit();
  18.   ADCInit();
  19.   USART1Init(9600);
  20.   DMAInit();
  21.   GPSInit();
  22.   TIM4_Init();   //調用定時器4初始化函數
  23.   enableInterrupts();   //使能系統總中斷
  24.   while(1)
  25.   {
  26.     AdcHandler(); //AD采樣
  27.     GPSHandler(); //GPS數據解析
  28.   }
  29. }
#include "GPS.h"
void GPSInit(void)
  L76C_CFG_GGA(0);//關閉GGA
  L76C_CFG_GLL(0);//關閉GLL
  L76C_CFG_GSA(0);//關閉GSA
  L76C_CFG_GSV(0);//關閉GSV
  L76C_CFG_RMC(0);//關閉RMC
  L76C_CFG_VTG(0);//關閉VTG
  L76C_CFG_ZDA(5);//ZDA數據5秒發送一次
  L76C_CFG_GST(0);//關閉GST
  L76C_CFG_SAVE();//保存配置信息
void L76C_CFG_GGA(unsigned char temp)
  unsigned char tempBuf[15]={'$','C','F','G','M','S','G',',','0',',','0',',','0',0x0A,0x0D};
  if(temp!=0)
    tempBuf[12]=temp;
  Uart1_SendString(tempBuf,15);
void L76C_CFG_GLL(unsigned char temp)
  unsigned char tempBuf[15]={'$','C','F','G','M','S','G',',','1',',','0',',','0',0x0A,0x0D};
  if(temp!=0)
    tempBuf[12]=temp;
void L76C_CFG_GSA(unsigned char temp)
  unsigned char tempBuf[15]={'$','C','F','G','M','S','G',',','2',',','0',',','0',0x0A,0x0D};
  if(temp!=0)
    tempBuf[12]=temp;
void L76C_CFG_GSV(unsigned char temp)
  unsigned char tempBuf[15]={'$','C','F','G','M','S','G',',','3',',','0',',','0',0x0A,0x0D};
  if(temp!=0)
    tempBuf[12]=temp;
void L76C_CFG_RMC(unsigned char temp)
  unsigned char tempBuf[15]={'$','C','F','G','M','S','G',',','4',',','0',',','0',0x0A,0x0D};
  if(temp!=0)
    tempBuf[12]=temp;
void L76C_CFG_VTG(unsigned char temp)
  unsigned char tempBuf[15]={'$','C','F','G','M','S','G',',','5',',','0',',','0',0x0A,0x0D};
  if(temp!=0)
    tempBuf[12]=temp;
void L76C_CFG_ZDA(unsigned char temp)
  unsigned char tempBuf[15]={'$','C','F','G','M','S','G',',','6',',','0',',','0',0x0A,0x0D};
  if(temp!=0)
    tempBuf[12]=temp;
void L76C_CFG_GST(unsigned char temp)
  unsigned char tempBuf[15]={'$','C','F','G','M','S','G',',','7',',','0',',','0',0x0A,0x0D};
  if(temp!=0)
    tempBuf[12]=temp;
void L76C_CFG_SAVE(void)
  unsigned char tempBuf[14]={'$','C','F','G','S','A','V','E',',','h','0','F',0x0A,0x0D};
  Uart1_SendString(tempBuf,14);
GPS.7z (810.72 KB, 下載次數: 32)
L76-C.7z (2.31 MB, 下載次數: 28)
