#include <reg52.h>
sbit S2=P3^4; //加速
sbit S3=P3^5; //減速
sbit S4=P3^6; //前進
sbit S5=P3^7; //后退
sbit IN1=P2^4; //電機IN1
sbit IN2=P2^5; //電機IN2
sbit EN1=P2^6; //電機EN1
sbit fm=P2^3;
uchar pwm,num;
void delay(uint ms)//延時函數(shù)
uchar i;
while(ms--)
for(i=0;i<120;i++);
void bee()//蜂鳴器函數(shù)
fm=0;
delay(100);
fm=1;
delay(100);
void qianjin() //前進
IN1=0; //電機IN1
IN2=1; //電機IN2
// EN1=1; //電機EN1
void houtui() //后退
IN1=1; //電機IN1
IN2=0; //電機IN2
//EN1=1; //電機EN1
void stop( ) //停止
IN1=0; //電機IN1
IN2=0; //電機IN2
//EN1=0; //電機EN1
void jiasu( )
if(pwm<32)
pwm++;
//加速
void jiansu( )
if(pwm>1)
pwm--;
//減速
void keyscan() //鍵盤函數(shù)
if(S2==0)
delay(50);
if(S2==0)
jiasu( ) ;
//if(pwm<32)
// pwm++;
//delay(100); //加速
// else
// bee();
if(S3==0)
delay(50); //消抖
if(S3==0)
jiansu( );
//if(pwm>1)
// pwm--;
delay(100); //減速
bee();
if(S4==0) //反轉(zhuǎn)
delay(50); //消抖
if(S4==0)
houtui();
//IN1=1; //電機IN1
//IN2=0; //電機IN2
//EN1=1; //電機EN1
if(S2==0)
delay(50);
if(S2==0)
jiasu( ); //加速
bee();
if (S3==0)
delay(50); //消抖
if(S3==0)
jiansu( ); //減速
bee();
if(S4==0) //正轉(zhuǎn)
delay(50); //消抖
if(S4==0)
qianjin();
delay(50);
if(S5==0) //停止
delay(50); //消抖
if(S5==0)
stop( ); //停止
delay(50);
if(S5==0&&S4==0 ) //反轉(zhuǎn)
delay(30); //消抖
if(S5==0&& S4==0)
houtui();
delay(50);
//if(S5==0)
//delay(50); //消抖
//if(S5==0)
// IN1=0; //電機IN1
// IN2=0; //電機IN2
//EN1=0; //電機EN1
void init_t0() //中斷函數(shù)
TMOD=0x01;
TH0=(65536-500)/256;
TL0=(65536-500)%256;
EA=1;
ET0=1;
TR0=1;
void t0() interrupt 1 //中斷服務(wù)函數(shù)
TR0=0;
num++;
if(num>32)
num=0;
if(num<=pwm)
EN1 = 1;
//P1=0xff;
//P0=0x00;
EN1=0;
//P1=0x00;
//P0=0xff;
TR0=1;
void main() //主函數(shù)
init_t0();
num=0;
pwm=16;
keyscan();
為什么 按S4不反轉(zhuǎn)
