查看: 2387|回復: 6
怎么讓這幾個函數同時運行,求分析
ID:840694 發表于 2020-11-8 19:23 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include <stdio.h>
#include<intrins.h>
sbit LEDR=P1^0;//???
sbit LEDY=P1^1;//???
sbit LEDG=P1^2;//???
sbit DU = P2^6;
sbit WE = P2^7;
uchar  code tabel[]= {0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F,};
void delay (uint i)
uint x,y;
for (x=0;x<i;x++)
for (y=0;y<110;y++);
void UARTInit()
        SM0 = 0;        SM1 = 1;
        TR1 = 1;
        TMOD |= 0x20;
        TH1 = 0xfd;
        TL1 = 0xfd;
uchar k;
void display(uchar i)
        uchar  shi, ge;
        shi = i % 100 / 10;        //236 % 100 / 10 = 3
        ge  = i % 10;//236 % 10 =6
        P0 = 0XFF;
        WE = 1;
        P0 = 0XFE;
        WE = 0;
        DU = 1;
        P0 = tabel[shi];//
        DU = 0;
        delay(5);
        //???λ?????
        P0 = 0XFF;//???????
        WE = 1;//??λ???????
        P0 = 0XFD; //1111 1101
        WE = 0;//????λ?????
        DU = 1;//???????????
        P0 = tabel[ge];//
        DU = 0;//??????????
        delay(5);
//?????0?????
void timer0Init()
        TR0 = 1;         //????????0
        TMOD = 0X01; //???????????1??16λ???????????
        TH0 =(65535-46082 ) / 256;
        TL0 =(65535-46082 ) % 256; //???50ms
         UARTInit();
                TI = 1;
                puts("?????");
                while(!TI);
                TI = 0;
                delay(15000);
                TI= 1;
                puts("?????");
                while(!TI);
                TI=0;
                delay(3000);
                TI=1;
                puts("?????");
                delay(10000);
                TI=0;
LEDR=0;
        uchar mSec, Sec;//????????????
        Sec=15;
        timer0Init();//?????0?????
                if(TF0 == 1)//?ж???????
                        TF0 = 0;//?????????????λ
                        TL0 = (65535-46082) % 256; //???50ms
                        mSec++;//50ms??
                        if(mSec == 20)
                                mSec = 0;
                                Sec--;//1?????
                display(Sec); //????????????
delay(12000);
LEDR=1;
LEDR=0;
delay(250);
LEDR=1;
delay(250);
LEDR=0;
delay(250);
LEDR=1;
delay(250);
LEDR=0;
delay(250);
LEDR=1;
delay(250);
LEDR=0;
delay(250);
LEDR=1;
delay(250);
LEDR=0;
delay(250);
LEDR=1;
delay(250);
LEDR=0;
delay(250);
LEDR=1;
delay(250);
LEDY=0;
delay(3000);
LEDY=1;
LEDG=0;
delay(10000);
for(k=0;k<3;k++);
LEDG=0;
delay(250);
LEDG=1;
delay(250);
LEDG=0;
delay(250);
LEDG=1;
delay(250);
LEDG=0;
delay(250);
LEDG=1;
delay(250);
LEDG=0;
delay(250);
LEDG=1;
delay(250);
LEDG=0;
delay(250);
LEDG=1;
delay(250);
LEDG=0;
delay(250);
LEDG=1;
delay(250);
ID:472390 發表于 2020-11-9 11:27 | 只看該作者
程序不可能同時執行的,都是挨個執行。即使加入操作系統也是挨個執行,只是從宏觀上看好像是在并行執行而已。單片機推薦使用定時器設置不同的時間標志位,進行任務的分配。比如設置10毫秒的定時器時基,然后在定時器中用一個變量進行加加,當這個變量等于10或者20 的時候,設置一個標志位,在主函數中檢測這個標志位即可完成定時器對任務的分配。切記分配的函數執行時間不能超過設置的調度時間,否則調度任務將毫無意義。
ID:739545 發表于 2020-11-9 11:43 | 只看該作者
已經在運行了,怎么叫同時運行,不知道表達什么意思
ID:626055 發表于 2020-11-9 15:38 | 只看該作者
樓主想要多線程運行。
單片機中不得行哦。
ID:840694 發表于 2020-11-9 17:22 | 只看該作者
江上遠帆 發表于 2020-11-9 11:27
程序不可能同時執行的,都是挨個執行。即使加入操作系統也是挨個執行,只是從宏觀上看好像是在并行執行而已 ...
有點明白了,謝謝
ID:840694 發表于 2020-11-9 17:23 | 只看該作者
T_Trigger 發表于 2020-11-9 15:38
樓主想要多線程運行。
單片機中不得行哦。
哦哦,主要沒學過c,一直摸黑走路
ID:414556 發表于 2020-11-10 09:51 | 只看該作者
要想“同時”就不要使用程序延時,延時用定時中斷處理就有“同時”的效果。
