查看: 1948|回復: 1
大神們,matlab代碼求解釋
ID:326549 發表于 2020-10-29 20:40 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
50黑幣
s=serial(PORT);
            fclose(s);
            s.status
            fopen(s);
            s.status
            %%%%%%%%%%%%%%%利用找空格的方法,確保讀取串口值為正常有效值
            f = 1;
            N = 25;
            while f <= N
                Bstr = fscanf(s)
                q = num2str(f);
                index = find(Bstr==' ')
                %if ( Bstr(1:(index(1)-2)) ~= ['x' q] |  Bstr((index(3)+1):(index(4)-2)) ~= ['y' q] |  Bstr((index(6)+1):(index(7)-2)) ~= ['z' q] )
                if ( str2num(Bstr(1:(index(1)-2))) ~= str2num(['x' q]) |  str2num(Bstr((index(3)+1):(index(4)-2))) ~= str2num(['y' q]) |  str2num(Bstr((index(6)+1):(index(7)-2))) ~= str2num(['z' q]) )
                    f = 1;
                    continue;
                end
                len = length(index)
                Bx(1,f) =  str2num( Bstr( index(1):index(2) ) );
                By(1,f) =  str2num( Bstr( index(4):index(5) ) );
                Bz(1,f) =  str2num( Bstr( index(7):length(Bstr) ) );
                if abs(Bx(f))>=4096 | Bx(f)==0 | abs(By(f))>=4096 | By(f)==0 | abs(Bz(f))>=4096 | Bz(f)==0
                    display('數據超范圍。');
                    return
                end
                f = f + 1;
            end
ID:326549 發表于 2020-10-29 20:41 | 只看該作者
解釋一下怎么用的啊,從if那就看不懂了
