單片機(jī)是STC12C5A16S2
HC-SR04 超聲波測(cè)距模塊實(shí)現(xiàn)數(shù)碼管顯示 , 但是數(shù)碼管只顯示0000沒有數(shù)顯示 ,我感覺可能是模塊根本就沒啟動(dòng), 不知道程序哪里出了問題,新人小白希望各位大佬能夠幫幫忙
單片機(jī)源程序如下:
#include <reg52.h>
#include <intrins.h>
#include <stdio.h>
#define w P2
#define d P0
typedef unsigned char uchar;
typedef unsigned int uint;
char code smg[10] = {0x28,0xeb,0x32,0xa2,0xe1,0xa4,0x24,0xea,0x20,0xa0};
//char code weixuan[4] = {0x7f,0xbf,0xdf,0xef};
uint a2,a1;
uint distance;
uchar ge;
uchar shi;
uchar bai;
uchar qian;
uchar time;
sbit Trig = P2^0;
sbit Echo = P2^1;
sbit w1 = P2^7;
sbit w2 = P2^6;
sbit w3 = P2^5;
sbit w4 = P2^4;
bit flag = 0;
void display();
void read();
void count();
void Init();
void delay(uchar p)
while(p--);
void delay20us()
uchar i;
_nop_();
_nop_();
_nop_();
i = 52;
while (--i);
void display()
// w = weixuan[3];
w1 = 1; w2 = 1; w3 = 1; w4 = 0;
d = smg[ge];
delay(100);
// w = weixuan[2];
w1 = 1; w2 = 1; w3 = 0; w4 = 1;
d = smg[shi];
delay(100);
// w = weixuan[1];
w1 = 1; w2 = 0; w3 = 1; w4 = 1;
d = smg[bai];
delay(100);
// w = weixuan[0];
w1 = 0; w2 = 1; w3 = 1; w4 = 1;
d = smg[qian];
delay(100);
w1 = 0;w2 = 0;w3 = 0;w4 = 0;
void Init_timer0()
TMOD = 0x01;
TH0 = 0;
TL0 = 0;
// TH1 = 0xf8;
// TL1 = 0x30;
// ET1 = 1;
ET0 = 1;
TR0 = 1;
// TR1 = 1;
EA = 1;
void count()
uchar a;
time = TH0*256+TL0;
TH0 = 0;
TR0 = 0;
distance = (time*0.17)/100;
if(distance <= 300 && flag == 1)
flag = 0;
a = distance;
ge = a%1000%100%10;
shi = a%1000%100/10;
bai = a%1000/100;
qian = a/1000;
distance = 0000;
Trig = 0;
Echo = 0;
Init_timer0();
display();
Trig = 1;
delay20us();
Trig = 0;
if(Echo == 0)
TR0 = 1;
if(Echo == 1)
TR0 = 0;
count();
void Timer0() interrupt 1
flag = 1;
//void Timer1() interrupt 3 //T1中斷用來掃描數(shù)碼管和計(jì)800MS啟動(dòng)模塊
// TH1 = 0xf8;
// TL1 = 0x30;
// a2++;
// display();
// if(a2 >= 400)
// a2 = 0;
// Trig = 1; //800MS 啟動(dòng)一次模塊
// delay20us();
// Trig = 0;
不管是開始用的定時(shí)器還是后來放到主函數(shù)里用延時(shí)都是這樣 。
