查看: 3439|回復: 12
基于51單片機的模擬電話系統矩陣按鍵設置反了,比如按下#顯示的是“1”,按下顯示...
回帖獎勵 12 黑幣 回復本帖可獲得 6 黑幣獎勵! 每人限 1 次(中獎概率 50%)
如題,基于51單片機的1602液晶顯示的模擬電話系統中,矩陣按鍵設置反了,比如按下#顯示的是“1”,按下顯示的是“*”,這怎么調代碼,沒學過液晶不太懂琢磨了好久沒有用,代碼圖片如下
#include <reg51.h>
#include <intrins.h>
#define DelayNOPx() {_nop_();_nop_();_nop_();_nop_();}
sbit  BEEP = P1^0;
sbit  RS = P2^0;
sbit  RW = P2^1;
sbit  E = P2^2;
void DelayMS (uint ms);   //聲明延時函數
bit LCD_Busy ();
void LCD_Pos (uchar);
void LCD_Wcmd (uchar);
void LCD_Wdat (uchar);
//  標題字符串
char code Title_Text[] = {"-- Phone Code --"};
// 鍵盤序號與鍵盤符號映射表
  uchar code Key_Table[]={'1','2','3','4','5','6','7','8','9','*','0','#'};
// 鍵盤撥號數字緩沖
  uchar Dial_Code_Str[] = {"              "};
  uchar KeyNo = 0xFF;
  int tCount = 0;
// 延時
     void DelayMS (uint x)
    uchar i;
    while(x--) for (i = 0;i < 120; i++);
// 在LCD指定鍵盤上顯示字符串
void Display_String(uchar * str,uchar LineNo)
   uchar k;
   LCD_Pos(LineNo);
   for (k = 0; k< 16; k++) LCD_Wdat (str[k]);
// LCD狀態檢測
  bit LCD_Busy ()
    bit result;
    RS =0;RW =1;E=1;DelayNOPx();result = (bit)(P0 & 0x80); E= 0;
    return result;
// 寫LCD命令
  void LCD_Wcmd (uchar cmd)
     while (LCD_Busy ()); //判斷LCD是否忙碌
     RS=0;RW=0;E=0;_nop_();_nop_();
     P0=cmd;DelayNOPx();E=1;DelayNOPx();E=0;
// 寫LCD數據
   void LCD_Wdat (uchar str)
      RS =1;RW =0;E=0;
      P0=str; DelayNOPx ();
// LCD初始化
   void LCD_Init()
      LCD_Wcmd(0x38);DelayMS(1);//設定LCD為16*2顯示,5*7點陣,8位數據接口
      LCD_Wcmd(0x0c);DelayMS(1);//開顯示,不顯示光標
      LCD_Wcmd(0x06);DelayMS(1);//顯示光標,自動右移,整屏不要動
      LCD_Wcmd(0x01);DelayMS(1);//顯示清屏
// 設置LCD顯示位置
   void LCD_Pos (uchar pos)
     LCD_Wcmd(pos | 0x80);
// T0控制按鍵聲音
void T0_INT () interrupt 1
  TH0 = -600 / 256;
  TL0 = -600 % 256;
  BEEP = ~BEEP;
  if (++tCount == 200)
    tCount = 0; TR0 = 0;
// 鍵盤掃描
uchar GetKey ()
   uchar i, j, k = 0;
   uchar KeyScanCode [] = {0xEF, 0xDF, 0xBF, 0x7F}; //鍵盤掃描碼
   uchar KeyCodeTable[] ={0xEE,0xED,0xEB,0xDE,0xDD,0xDB,
0xBE,0xBD,0xBB,0x7E,0x7D,0x7B}; //鍵盤特征碼
   P3 = 0x0F;//掃描鍵盤獲取按鍵序號
   if (P3!=0x0F)  DelayMS(20);//延時去機械抖動
   if (P3!=0x0F)
    for (i = 0; i< 4;i++)
   P3 = KeyScanCode[i];
   for (j = 0;j < 3;j++)
    k = i * 3 + j;
    if (P3 == KeyCodeTable[k]) return k;
   else return 0xFF;
// 主程序
uchar i = -1,j;
P0 = P2 = P1 = 0xFF;
IE = 0x82;
  TMOD = 0X01;//寄存器工作方式設定為模式1
  LCD_Init();//初始化LCD
  Display_String (Title_Text,0x00);//在第一行顯示標題
  KeyNo = GetKey();//獲取按鍵
  if (KeyNo ==0xFF) continue;//無按鍵時繼續掃描
         i++ ;
    if(KeyNo==9)
         { Dial_Code_Str[i-1]= ' ';i=i-2;  }  //按”*”鍵退格
     {  if (KeyNo==11)
       {for (j = 0;j< 16;j++) Dial_Code_Str[j] = ' '; i=-1;}//按鍵“#”鍵清空
    else if (i == 11)
    {for (j = 0;j < 16;j++) Dial_Code_Str[j] = ' ';i = 0;} //超過11位清空
         Dial_Code_Str[i] = Key_Table [KeyNo]; }
         Display_String (Dial_Code_Str, 0x40); //在第二行顯示號碼
         TR0 = 1;//T0中斷控制按鍵聲音
         while(GetKey()!=0xFF);//等待釋放
ID:339804 發表于 2020-10-20 13:01 | 只看該作者
按下1顯示的是“*”
ID:739545 發表于 2020-10-20 16:33 | 只看該作者
代碼里面重新設置矩陣就可以了
ID:213173 發表于 2020-10-20 16:40 | 只看該作者
把鍵值對應的字符重新調整一下即可。
ID:339804 發表于 2020-10-20 16:52 | 只看該作者
lovezjf234 發表于 2020-10-20 16:33
代碼里面重新設置矩陣就可以了
額。。具體是哪里呢 小白不太懂
ID:339804 發表于 2020-10-20 16:53 | 只看該作者
wulin 發表于 2020-10-20 16:40
把鍵值對應的字符重新調整一下即可。
具體是哪里呢 不太懂液晶顯示的
ID:337139 發表于 2020-10-20 19:12 | 只看該作者
重新設置矩陣列的鍵值。
ID:235954 發表于 2020-10-21 10:01 | 只看該作者
uchar KeyCodeTable[] ={0xEE,0xED,0xEB,0xDE,0xDD,0xDB, 0xBE,0xBD,0xBB,0x7E,0x7D,0x7B}; //鍵盤特征碼順序更換一下
ID:339804 發表于 2020-10-21 12:33 | 只看該作者
梁廷明 發表于 2020-10-21 10:01
uchar KeyCodeTable[] ={0xEE,0xED,0xEB,0xDE,0xDD,0xDB, 0xBE,0xBD,0xBB,0x7E,0x7D,0x7B}; //鍵盤特征碼 ...
改特征碼好像不行的。按鍵取反都不行,琢磨了好久
ID:827243 發表于 2020-10-21 14:48 | 只看該作者
如果真是反了 改這個
uchar code Key_Table[]={'#','0','*','9','8','7','6','5','4','3','2','1'};
ID:460753 發表于 2020-10-21 14:55 | 只看該作者
更改按鍵映射表:
#與1對調一下。
ID:339804 發表于 2020-10-22 16:49 | 只看該作者
不行的 改過了
ID:339804 發表于 2020-10-22 16:50 | 只看該作者
daemondong 發表于 2020-10-21 14:48
如果真是反了 改這個
改過了 沒用的 這些顯示碼的基本都倒過來換過 都不行
