現(xiàn)在這個計算器僅有加法。出現(xiàn)的問題是計算結(jié)果顯示有時正確有時是亂碼。
/*結(jié)果有時會出現(xiàn)亂碼*/
#include<reg52.h>
uchar code table[]={0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f};
void delay( uint m ) //延時函數(shù)
uint x , y ;
for( x = m ; x > 0 ; x--)
for( y = 110 ; y > 0 ; y--);
sbit beep = P3^1 ; //蜂鳴器
uchar firstflot = 0;
int boat = 0 ;
int second = 0 , third = 0 , m , n ;
int keyscan() //掃描鍵盤
int temp, num ;
P2=0x7f;
temp=P2;
temp=temp&0x0f; //判斷第一行按鍵
if(temp != 0x0f )
delay( 10 ) ;
temp = P2 ; //重讀P2口值
temp = temp & 0x0f ;
if( temp != 0x0f )
temp = P2 ;
switch(temp)
case 0x77: num=1; //1
firstflot=1 ;
break;
case 0x7b: num=2; //2
firstflot=1 ;
break;
case 0x7d: num=3; //3
firstflot=1 ;
break;
case 0x7e: num = '+' ; //+
break;
while(temp != 0x0f) //等待按鍵釋放
temp = P2;
temp = temp & 0x0f;
P2 = 0xbf ; //掃描第二行鍵盤
temp = P2 ;
temp = temp & 0x0f;
if( temp != 0x0f )
delay( 10 ) ; //消抖
temp = P2 ;
if( temp != 0x0f )
temp = P2 ;
switch( temp )
case 0xb7: num=4; //4
firstflot=1 ;
break;
case 0xbb: num=5; //5
firstflot=1 ;
break;
case 0xbd: num=6; //6
firstflot=1 ;
break;
case 0xbe: num = '-' ; //-
break;
while( temp != 0x0f )
temp = P2 ;
P2 = 0xdf ; //掃描第三行鍵盤
temp = P2 ;
if( temp != 0x0f )
delay( 10 ) ; //消抖
temp = P2 ;
if( temp != 0x0f )
temp = P2 ;
switch( temp )
case 0xd7: num=7; //7
firstflot=1 ;
break;
case 0xdb: num=8; //8
firstflot=1 ;
break;
case 0xdd: num=9; //9
firstflot=1 ;
break;
case 0xde: num = '*' ; //*
break;
temp = P2;
P2 = 0xef ; //掃描第四行鍵盤
temp = P2 ;
if( temp != 0x0f )
delay( 10 ) ; //消抖
temp = P2 ;
temp = temp & 0x0f;
if( temp != 0x0f )
temp = P2 ;
switch( temp )
// case 0xe7: printf("num%s",onn) //歸0
// break;
case 0xeb: num = 0 ; //0
firstflot=1 ;
break;
case 0xed: num = '=' ; //=
break;
case 0xee: num = '/' ; //除
break;
return num ;
/*分模塊完成計算器程序,完成一個模塊后測試能否正常執(zhí)行,能則進行下一個*/
/*掃描鍵盤省略*/
int modern_1() //輸入第一次數(shù)字
if(firstflot == 1 && second == 0)
P0 = 0x7f ;
m = keyscan() ;
P1 = table[ m ] ;
delay( 1 ) ;
return m ;
return m ;
void modern_2() //掃描功能鍵
if(keyscan() == '+')
P0 = 0xff ; //熄滅上位數(shù)字
delay(100) ;
firstflot = 0 ;
second = 1 ;
boat = 1 ;
int modern_3() /*再次輸入數(shù)字*/
// int n ;
if(second == 1 && boat ==1)
keyscan() ;
if(firstflot == 1)
P0 = 0x7f ;
n = keyscan() ;
P1 = table[ n ] ;
boat = 0 ;
return n ;
return n ;
int modern_4() /*計算結(jié)果*/
int z ;
if(keyscan() == '=')
z = m + n ;
third = 1 ;
return z ;
return z ;
void modern_5() /*輸出結(jié)果*/
int c ;
if(third == 1)
c = modern_4() ;
P0 = 0x7f ; /*個位*/
P1 = table[c%10] ;
delay(1) ;
P0 = 0xbf ; /*十位*/
P1 = table[c/10] ;
delay(1) ;
void main() /*輸出結(jié)果*/
P0 = 0x7f;
P1 = table[0] ;
delay(1) ;
keyscan() ;
modern_1() ; modern_2() ;
modern_3() ; modern_4() ;
modern_5() ;
