只需一步,快速開(kāi)始
查看: 2997|回復(fù): 2
STM32控制HMI串口屏發(fā)送指令字符串后,串口屏無(wú)響應(yīng)溫度沒(méi)有改變
ID:824585 發(fā)表于 2020-10-11 16:45 | 顯示全部樓層 |閱讀模式
5黑幣
#include "stm32f10x.h"
#include "usart.h"
#include "delay.h"
#include "mlx90614.h"
#include "sys.h"
extern uint8_t aRxBuffer[100];
extern uint8_t aRxCounter;
extern uint8_t aReceiveState;
void USART_HalfDuplexCmd(USART_TypeDef* USARTx, FunctionalState NewState)
  /* Check the parameters */
  assert_param(IS_USART_ALL_PERIPH(USARTx));
  assert_param(IS_FUNCTIONAL_STATE(NewState));
  if (NewState != DISABLE)
    /* Enable the Half-Duplex mode by setting the HDSEL bit in the CR3 register */
    USARTx->CR3 |= CR3_HDSEL_Set;
    /* Disable the Half-Duplex mode by clearing the HDSEL bit in the CR3 register */
    USARTx->CR3 &= CR3_HDSEL_Reset;
volatile uint8_t aRxBuffer[100]={0x00};
volatile uint8_t aRxCounter=0;
volatile uint8_t aReceiveState=0;
int main(void)
  USART_Config();
//DEBUG_USARTx = USART1;
//        DEBUG_USARTx = USART2;
Temperature = SMBus_ReadTemp();
        delay_ms(500);
// ′®¿ú1μÄêy¾Y
                if(aReceiveState==1)//èç1û½óêÕμ½1Ö¡êy¾Y
                        aReceiveState=0;
                        if(aRxBuffer[0]=='a')
                          if(aRxBuffer[2]=='1')
                          { x=1;        }
                          else if(aRxBuffer[2]=='2')
                          { x=0;  }
                                if(x==1)
                        printf("x0.val=%d",(int)(Temperature*10));   //x0.val=%d為向串口屏發(fā)送的指令
                        delay_ms(500);
                        usart_pm_end();
                        if(x==2)
                        printf("x0.val=a10");    ////x0.val=%d為向串口屏發(fā)送的指令
ID:36656 發(fā)表于 2020-10-12 15:43 | 顯示全部樓層
               if(x==1)
                        usart_pm_end();
                        delay_ms(500);
                        if(x==2)
                        //printf("x0.val=a10");    ////x0.val=%d為向串口屏發(fā)送的指令
ID:36656 發(fā)表于 2020-10-12 15:45 | 顯示全部樓層
用串口調(diào)試助手看下你單片機(jī)發(fā)送的數(shù)據(jù)是什么
