查看: 2015|回復: 0
LCD12864多級菜單設計
ID:521630 發表于 2020-10-2 19:13 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "menu1.h"
#include "stm32f10x.h"
#include "12864.h"
#include "systick.h"
#include <stdio.h>
#include <stdlib.h>
#include "key4x4.h"
#include "public.h"
/*菜單結構體*/
typedef struct menu
u8 range_from,range_to; //當前選擇的項開始及結束符號
u8 itemCount;//項目總數
u8 selected;//當前選擇項
u8 *menuItems[17];//菜單項目
struct menu **subMenus;//子菜單
struct menu *parent;//上級菜單,若是主菜單則為null
void (**func)();//選擇相應按鍵后執行的函數
}Menu;
Menu MainMenu1 = {
0,3,4,0,                                                //默認顯示0-3項,總共4項,當前選擇0項,
  "dis1           \x10",//"\x10"表示一個小箭頭
  "dis2           \x10",
  "dis3           \x10",
  "dis4           \x10",
Menu dis1Menu = {
  "secondline1    \x10",//"\x10"表示一個小箭頭
  "secondline2    \x10",
  "secondline3        ",
  "secondline4    \x10",
Menu dis2Menu = {
  "secondline2    \x10",
  "secondline3        ",
  "secondline4    \x10",
Menu *currentMenu;//當前菜單
/*用于顯示菜單*/
void displaymenu(u8 line)
        int i;
        line = 3-(currentMenu->range_to-line);
        /*4次循環打印菜單*/
        for(i = 0;i<4;i++)
                Display_LCD_String(i,currentMenu->menuItems[i+currentMenu->range_from],5);
        con_disp(line,1);
void func(void)
void initmenu(void)
        currentMenu = &MainMenu1;
        MainMenu1.subMenus = malloc(sizeof(&MainMenu1)*4);
        MainMenu1.subMenus[0] = &dis1Menu;
        MainMenu1.subMenus[1] = &dis2Menu;
        MainMenu1.subMenus[2] = NULL;
        MainMenu1.subMenus[3] = NULL;
        MainMenu1.func = malloc(sizeof(&func)*4);
        MainMenu1.func[0] = NULL;
        MainMenu1.func[1] = NULL;
        MainMenu1.func[2] = NULL;
        MainMenu1.func[3] = NULL;
        MainMenu1.parent = NULL;//mainmenu is top menu
        dis1Menu.subMenus = malloc(sizeof(&dis1Menu)*4);
        dis1Menu.subMenus[0] = NULL;
        dis1Menu.subMenus[1] = NULL;
        dis1Menu.subMenus[2] = NULL;
        dis1Menu.subMenus[3] = NULL;
        dis1Menu.func = malloc(sizeof(&func)*4);
        dis1Menu.func[0] = NULL;
        dis1Menu.func[1] = NULL;
        dis1Menu.func[2] = NULL;
        dis1Menu.func[3] = NULL;
        dis1Menu.parent = &MainMenu1;//dis1menu parent menu is mainmenu1
        dis2Menu.subMenus =  malloc(sizeof(&dis1Menu)*4);
        dis2Menu.subMenus[0] = NULL;
        dis2Menu.subMenus[1] = NULL;
        dis2Menu.subMenus[2] = NULL;
        dis2Menu.subMenus[3] = NULL;
        dis2Menu.func = malloc(sizeof(&func)*4);
        dis2Menu.func[0] = NULL;
        dis2Menu.func[1] = NULL;
        dis2Menu.func[2] = NULL;
        dis2Menu.func[3] = NULL;
        dis2Menu.parent = &MainMenu1;//dis2menu parent menu is mainmenu1
void menutest(void)
        initmenu();
        displaymenu(currentMenu->selected);
                if(key_pressed_flag)
                        ReadValue=Key_scan();
                        if(ReadValue!=0)
                                delay_ms(100);
                                if(ReadValue == Key_scan())
                                        switch(ReadValue)
                                                case key_sure://按鍵A(確認按鍵)
                                                if(currentMenu->subMenus[currentMenu->selected] !=NULL)
        currentMenu = currentMenu->subMenus[currentMenu->selected];
        displaymenu(0);
                                                        break;
                                                case key_up://按鍵B(上一行菜單)
                                                        if(currentMenu->selected == 0)
        break;
        currentMenu->selected--;
        if(currentMenu->selected < currentMenu->range_from)
        currentMenu->range_from = currentMenu->selected;
        currentMenu->range_to = currentMenu->range_from+3;
                                                        break;
                                                case key_down://按鍵C(下一行菜單 )
                                                        if(currentMenu->selected == currentMenu->itemCount-1)
        break;
        currentMenu->selected++;
        if(currentMenu->selected>currentMenu->range_to)
        currentMenu->range_to = currentMenu->selected;
        currentMenu->range_from = currentMenu->range_to-3;
                                                        break;
                                                case key_back://按鍵D(返回)
                                                        if(currentMenu->parent!=NULL)
        currentMenu = currentMenu->parent;
                                                        break;
                                                default:
                                                        break;
收藏收藏2 分享淘帖 頂 踩
