查看: 2804|回復(fù): 0
51單片機交通燈控制電路
ID:747099 發(fā)表于 2020-9-26 18:49 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#define  uint unsigned int;
#define  uchar unsigned char;
void  DigitalTube();
void  InterruptT0();
sbit  P10 = P1^0;
sbit  P11 = P1^1;
sbit  P12 = P1^2;
sbit  P13 = P1^3;
sbit  P14 = P1^4;
sbit  P15 = P1^5;
sbit  P16 = P1^6;
sbit  P17 = P1^7;
sbit  P20 = P2^0;
sbit  P21 = P2^1;
sbit  K22 = P2^2;
sbit  K23 = P2^3;
sbit  K24 = P2^4;
sbit dula = P2^5;
uint LedBuf[10] = { 0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
uint Kflag = 1;
uint LedNumNS = 27;
uint LedNumEW = 30;
uint i = 0;
uint j = 0;
uint j1 = 0;
uint k = 0;
uint g = 0;
uint z = 0;
uint LedTime1 = 30;
uint LedTime2 = 27;
uint LedTime3 = 30;
uint LedTime4 = 27;
uint Kf22 = 1;
uint Kf23 = 1;
uint Kf24 = 1;
uint KSta24 = 1;
uint KSta23 = 1;
uint KSta22 = 1;
uchar Kflag22 = 0;
EA = 1;
ET0 = 1;
TR0 = 1;
TMOD = 0x01;
TH0 = 0xFC;
TL0= 0x67;
P1 = 0xEE;
  DigitalTube();
void InterruptT0() interrupt 1
    TH0 = 0xFC;
    TL0 = 0x67;
    i++;
    k++;
    KSta24 = K24;
    if(Kf24 != KSta24)
     if(Kf24 == 1)
      Kflag = !Kflag;
     Kf24 = KSta24;
   KSta23 = K23;
   if(Kf23 != KSta23)
    if(Kf23 == 1)
     LedTime1 = LedTime1 +5;
     LedTime2 = LedTime2 +5;
     LedTime3 = LedTime3 +5;
     LedTime4 = LedTime4 +5;
     if(LedTime1 >=60)
       LedTime1 = 10;
       LedTime2 = 7;
       LedTime3 = 10;
       LedTime4 = 7;
     LedNumEW = LedTime1;
     LedNumNS = LedTime2;
    Kf23= KSta23;
   KSta22 = K22;
   if(Kf22 != KSta22)
    if(Kf22 == 1)
     Kflag22 ++;
     if(Kflag22>= 3)
      Kflag22 = 0;
     switch(Kflag22)
      case 1:
       LedTime1 = 50;
             LedTime2 = 47;
       LedTime3 = 20;
       LedTime4 = 17;
          break;
      case 2:
       LedTime1 = 20;
             LedTime2 = 17;
       LedTime3 = 50;
       LedTime4 = 47;
       break;
      case 0:
       LedTime1 = 30;
             LedTime2 = 27;
       LedTime3 = 30;
       LedTime4 = 27;
       break;
    Kf22 = KSta22;
if(j >= 200)
   j  = 0;
   j1++;
if(i >= 1000)
  i = 0;
  LedNumNS--;
  LedNumEW--;
  switch(g)
   case 0:
    if(LedNumEW == 3)
      P14 = ! P14;
    if(Kf24 == Kflag)  P15 = ! P15;
      LedNumNS = 3;
    if(LedNumEW == 0)
     LedNumNS =  LedTime3;
     LedNumEW =  LedTime4;
     P12 = ! P12;
     P10 = ! P10;
     P13 = ! P13;
        if(Kf24 == Kflag)
     P15 = ! P15;
     g = 1;
    break;
   case 1:
    if(LedNumNS == 3)
               P12 = !P12;
         P11 = !P11;
         LedNumEW = 3;
    if(LedNumNS == 0)
    if(Kf24 == Kflag) P11 = !P11;
     P10 = !P10;
     P14 = !P14;
     P13 = !P13;
     g = 0;
    break;
     if(Kf24 != Kflag)
   if(j1 % 2 == 0)
    P11 = ! P11;
    P15 = ! P15;
51交通燈.rar
50.77 KB, 下載次數(shù): 24, 下載積分: 黑幣 -5
