查看: 1549|回復: 0
求幫助:用HC-SR04測距讓后用LCD1602顯示,為什么顯示錯誤
ID:761375 發表于 2020-9-22 16:26 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include <intrins.h>
#define LCD_DATA P0
sbit LCD_E=P2^7;
sbit LCD_RW=P2^5;
sbit LCD_RS=P2^6;
sbit led = P2^0;
sbit led1 = P2^1;
sbit led2 = P2^2;
sbit key = P3^1;
sbit trg = P1^2;           //超聲波模塊控制端
sbit ech = P1^3;           //超聲波模塊接收端
unsigned char i;
unsigned char flag = 0;
unsigned int count = 0;           //超聲波模塊時間變量
unsigned long dis;   //超聲波測量的距離
unsigned char num[10] = "0123456789";
unsigned char thousend,hundred,ten,unit;
延時函數delay延時 1ms入口參數  c
void delay(unsigned int c)
    unsigned char a,b;
        for (c; c>0; c--)
                 for (b=199;b>0;b--)
                          for(a=1;a>0;a--);
/****10us延時****/
void Delay10us()                //@12.000MHz
        unsigned char i;
        _nop_();
        _nop_();
        i = 27;
        while (--i);
void Lcd_Write_Cmd(unsigned int cmd)
        LCD_RS = 0;
        LCD_RW = 0;
        LCD_DATA = cmd;
        delay(5);
        LCD_E = 1;
        LCD_E = 0;
void Lcd_Write_Dat(unsigned char dat)
        LCD_RS = 1;
        LCD_RW = 0;
        LCD_DATA = dat;
        delay(5);
        LCD_E = 1;
        LCD_E = 0;
void Lcd_Init()
        Lcd_Write_Cmd(0x38);
        Lcd_Write_Cmd(0x0f);
        Lcd_Write_Cmd(0x06);
        Lcd_Write_Cmd(0x01);
/****定時器初始化****/
void T0_T1_Int0_Init()
        TMOD = 0x11;     //配置定時器工作模式及方式寄存器(TCON為定時器控制寄存器)
        TH0 = (65535 - 5000) / 256;
        TL0 = (65535 - 5000) % 256;
        TH1 = 0;                 //為定時器1設初值
        TL1 = 0;                 //高八位與低八位均為0
        EA = 1;                         //開放總中斷
        ET1 = 1;                 //開放定時器1中斷
        ET0 = 1;
void T0_ser() interrupt 1
        unsigned char n;
        n++;
        if(n >= 16)
                n = 0;
                trg = 1;                                   //向控制端
                Delay10us();                           //提供
                Delay10us();                          //20us
                trg = 0;
                led = ~led;
void T1_ser() interrupt 3
        TH1 = 0;
        TL1 = 0;
void Distance()
        while(!ech);
        TR1 = 1;
        while(ech);
        TR1 = 0;
void Dis_Count()
        count = TH1 * 256 + TL1;
        dis = (long)(count * 0.017); //計算小車到障礙物的距離(cm)
        thousend = dis / 1000;
        hundred = dis % 1000 / 100;
        ten = dis % 100 / 10;
        unit = dis % 10;
        Lcd_Init();
        T0_T1_Int0_Init();
        Lcd_Write_Cmd(0x80);
        TR0 = 1;
                Distance();
                Dis_Count();
                Lcd_Write_Dat(num[thousend]);
                delay(1);
                Lcd_Write_Dat(num[hundred]);
                delay(1);
                Lcd_Write_Dat(num[ten]);
                delay(1);
                Lcd_Write_Dat(num[unit]);
                delay(100);
                if(dis < 50)
                        led2 = 0;
                if(dis > 50)
                        led2 = 1;
LCD1602顯示的數字一直再增加
不知道哪里出了問題
