只需一步,快速開(kāi)始
查看: 2524|回復(fù): 0
ch376_usb STM32源程序
ID:302293 發(fā)表于 2020-9-17 17:18 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include <stdio.h>
#include "FILE_SYS.H"
#include "usart.H"
#include "string.h"
void Delay(__IO uint32_t nCount);
void GPIOInit(void);
void mStopIfError(uint8_t iError);
UINT8        CH376DiskFat( void );
unsigned char buf[64];
*        函數(shù)名:mStopIfError
*        輸  入:        iError, 錯(cuò)誤代碼
*        輸  出:
*        功能說(shuō)明:檢查操作狀態(tài),如果錯(cuò)誤則顯示錯(cuò)誤代碼并停機(jī),
*        應(yīng)該替換為實(shí)際的處理措施,例如顯示錯(cuò)誤信息,等待用戶確認(rèn)后重試等
        if (iError == USB_INT_SUCCESS)
                return;  /* 操作成功 */
//                printf("212123\r\n");
                /* LED閃爍 */
                GPIO_ResetBits(GPIOB,  GPIO_Pin_12);
                mDelaymS( 200 );
                GPIO_SetBits(GPIOB,  GPIO_Pin_12);
                mDelaymS( 200 );
UINT8        CH376DiskFat( void )  /* 查詢磁盤文件格式信息,扇區(qū)數(shù) */
        UINT8        s, i;
#ifndef        DEF_IC_V43_U
        xWriteCH376Cmd( CMD01_GET_IC_VER );
        if ( xReadCH376Data( ) < 0x43 ) {
                if ( CH376ReadVar8( VAR_DISK_STATUS ) >= DEF_DISK_READY ) CH376WriteVar8( VAR_DISK_STATUS, DEF_DISK_MOUNTED );
#endif
        s = CH376SendCmdWaitInt( CMD0H_DISK_QUERY );
        if ( s == USB_INT_SUCCESS ) {  /* 參考CH376INC.H文件中CH376_CMD_DATA結(jié)構(gòu)的DiskQuery */
                xWriteCH376Cmd( CMD01_RD_USB_DATA0 );
                xReadCH376Data( );  /* 長(zhǎng)度總是sizeof(CH376_CMD_DATA.DiskQuery) */
                xReadCH376Data( );  /* CH376_CMD_DATA.DiskQuery.mTotalSector */
                xReadCH376Data( );
                xReadCH376Data( );
                xReadCH376Data( );
                xReadCH376Data( );  /* CH376_CMD_DATA.DiskQuery.mFreeSector */
                xReadCH376Data( );
                xReadCH376Data( );
                xReadCH376Data( );
                i = xReadCH376Data( );  /* CH376_CMD_DATA.DiskQuery.mDiskFat */
                xEndCH376Cmd( );
        else  i = 5;
        return( i );
int main(void)
          unsigned char i,s;
    P_FAT_DIR_INFO        pDir;
          GPIOInit();
          USART_init();
          //printf("\r\n TEST \r\n");
                s = mInitCH376Host();  /* 初始化CH376 */
          mStopIfError( s );
                while ( CH376DiskConnect( ) != USB_INT_SUCCESS )          /* 檢查U盤是否連接,等待U盤插入,對(duì)于SD卡,可以由單片機(jī)直接查詢SD卡座的插拔狀態(tài)引腳 */
                        printf("1212121:\r\n");
                        mDelaymS( 100 );
                printf("8888888888\r\n");
                mDelaymS( 200 );  /* 延時(shí),可選操作,有的USB存儲(chǔ)器需要幾十毫秒的延時(shí) */
        /* 對(duì)于檢測(cè)到USB設(shè)備的,最多等待100*50mS,主要針對(duì)有些MP3太慢,對(duì)于檢測(cè)到USB設(shè)備并且連接DISK_MOUNTED的,最多等待5*50mS,主要針對(duì)DiskReady不過(guò)的 */
                for ( i = 0; i < 100; i ++ )
                {  /* 最長(zhǎng)等待時(shí)間,100*50mS */
                        mDelaymS( 50 );
                        s = CH376DiskMount( );  /* 初始化磁盤并測(cè)試磁盤是否就緒 */
                        if ( s == USB_INT_SUCCESS ) break;  /* 準(zhǔn)備好 */
                        else if ( s == ERR_DISK_DISCON ) break;  /* 檢測(cè)到斷開(kāi),重新檢測(cè)并計(jì)時(shí) */
                        if ( CH376GetDiskStatus( ) >= DEF_DISK_MOUNTED && i >= 5 ) break;  /* 有的U盤總是返回未準(zhǔn)備好,不過(guò)可以忽略,只要其建立連接MOUNTED且嘗試5*50mS */
                if ( CH376GetDiskStatus( ) < DEF_DISK_MOUNTED )
                {  /* 未知USB設(shè)備,例如USB鍵盤、打印機(jī)等 */
    //    printf( "Unknown device\n" );
                  while ( CH376DiskConnect( ) == USB_INT_SUCCESS )
                        {  /* 檢查U盤是否連接,等待U盤拔出 */
                          mDelaymS( 100 );
//                i = CH376ReadBlock( buf );  /* 如果需要,可以讀取數(shù)據(jù)塊CH376_CMD_DATA.DiskMountInq,返回長(zhǎng)度 */
//                if ( i == sizeof( INQUIRY_DATA ) )
//                {  /* U盤的廠商和產(chǎn)品信息 */
//                        buf[ i ] = 0;
//                        printf( "SDdiskInfo: %s\n", ((P_INQUIRY_DATA)buf) -> VendorIdStr );
    strcpy( buf, "\\*" );  //列出根目錄下的文件
                s = CH376FileOpenPath( buf );  /* 枚舉多級(jí)目錄下的文件或者目錄,輸入緩沖區(qū)必須在RAM中 */
                while ( s == USB_INT_DISK_READ ) /* 枚舉到匹配的文件 */
                    CH376ReadBlock( buf );  /* 讀取枚舉到的文件的FAT_DIR_INFO結(jié)構(gòu),返回長(zhǎng)度總是sizeof( FAT_DIR_INFO ) */
                                pDir = (P_FAT_DIR_INFO)buf;  /* 當(dāng)前文件目錄信息 */
                                if ( pDir -> DIR_Name[0] != '.' )  /* 不是本級(jí)或者上級(jí)目錄名則繼續(xù),否則必須丟棄不處理 */
                                        if ( pDir -> DIR_Name[0] == 0x05 ) pDir -> DIR_Name[0] = 0xE5;  /* 特殊字符替換 */
                                        pDir -> DIR_Attr = 0;  /* 強(qiáng)制文件名字符串結(jié)束以便打印輸出 */
                                        printf( "*** EnumName: %s\n", pDir -> DIR_Name );  /* 打印名稱,原始8+3格式,未整理成含小數(shù)點(diǎn)分隔符 */
                                xWriteCH376Cmd( CMD0H_FILE_ENUM_GO );  /* 繼續(xù)枚舉文件和目錄 */
                                xEndCH376Cmd( );
                                s = Wait376Interrupt( );
                        if ( s != ERR_MISS_FILE ) mStopIfError( s );  /* 操作出錯(cuò) */
          while (1)
            /* Insert delay */
            Delay(0xAFFFF);
            /* Insert delay */
            Delay(0xAFFFF);
void GPIOInit(void)
        /* GPIOB Periph clock enable */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
        /* Configure PB12 and PB13 in output pushpull mode */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12 | GPIO_Pin_13;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
        for(; nCount != 0; nCount--);
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
GPIO.7z
218.23 KB, 下載次數(shù): 33, 下載積分: 黑幣 -5
收藏收藏2 分享淘帖 頂 踩
