查看: 3316|回復: 11
我寫了一個關于51單片機控制舵機的垃圾桶程序,諸位大佬幫幫忙看看哪里有什么漏洞嗎
ID:760058 發表于 2020-9-4 19:19 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include <stdio.h>
#include <intrins.h>
#define  uchar unsigned char
#define  uint  unsigned int
sbit Trig = P3^4;    //超聲波控制端
sbit Echo = P3^5;   //超聲波接收端
sbit led  =  P1^0;   //指示燈
sbit led1 = P3^2;   //紅外感應
sbit beep = P2^3;        //蜂鳴器
sbit servorControl = P1^3;  //舵機的控制引腳
uchar flag = 0;
uchar control  = 0;  //舵機控制變量
uchar servorTime =0;
unsigned char T0RH =0;
unsigned char T0RL =0;
void delay (unsigned int z)//毫秒級延時
unsigned int x,y;
for(x = z; x > 0; x--)
  for(y = 114; y > 0 ; y--);
//初始化定時器
void Delay_us(unsigned char t)
while(--t);
}  //大約延時t*2+5us  超聲波模塊用
void timer0() interrupt 1
TH0 = 0;
TL0 = 0;
//中斷程序初始化賦值 重新計數 超聲波模塊用 計算時間
//void time_init()
// TMOD |= 0x01;
// TH0 = 0;
// TL0 = 0;
// TR0 = 1;     //啟動定時器0
// ET0 = 1;     //允許定時器0中斷
// EA = 1;
void time_init()
EA  = 1;     //總中斷允許
TMOD= 0x11;  //8位自動重裝模塊
TH0 = 0;
TL0 = 0;     //11.0592M晶振下占空比最大比值是256,輸出100HZ
  unsigned int time,distance;
EA  = 1;
  ET0 = 1;
  ET1 = 1;
  TMOD=0x11;
  TH1 =0xff;
  TL1 =0x9c;
  servorTime = 0;
Trig = 0;
Echo = 0;   //超聲波脈沖
time_init();
  Trig = 1;
  Delay_us (5);
  Trig = 0;
  while (Echo == 0);
  TR0  = 1;
  while (Echo);
  TR0  = 0;
  time = TH0*256+TL0;
  distance = (int)(time*0.017);  //計算路程 單位為cm
  TH0 = 0;
  TL0 = 0;
   if (led1 == 0) //紅外 檢測到雜物
   led = 0;       //指示燈閃亮
       delay(50);
   led = 1;
    delay(100);
   control = 0;   //舵機不轉動
   servorTime = 0;
   TR1 = 0;
   delay (200);
   delay (200);
   TR1 = 1;
   delay (200);
   delay (200);
   if(led1 == 1)
    led = 1;
    if(distance>=40 && led1==1)
    beep = 1;
    control = 20;    //使舵機向右擺動
    servorTime =0;
    TR1 = 1;
    delay(200);
    delay(200);
    TR1 = 0;
    delay(200);
    delay(200);
    if(distance<40 && led1==1)  //如果距離小于40cm 蜂鳴器響
    control = 5;   //使舵機向左擺動
    servorTime =0;
    TR1 = 1;
    delay(200);
    delay(200);
    TR1 = 0;
    delay(200);
    delay(200);
      beep = 0;
     delay (50);
     beep = 1;
     delay (2500);
void T1_int (void ) interrupt 3   //產生舵機所需要的脈沖
  TH1 = 0xff;
  TL1 = 0x9c;
  servorTime++;
  if(servorTime <= control)
   servorControl = 1;
   servorControl = 0;
   if(servorTime >= 200)
   servorTime=0;
ID:473004 發表于 2020-9-5 19:01 | 只看該作者
燒錄后是什么問題,舵機沒反應?
ID:584814 發表于 2020-9-5 19:04 | 只看該作者
沒有任何漏洞。因為不知道這個是做什么的,就是算指出問題也可能有意為之。
ID:760058 發表于 2020-9-7 01:12 | 只看該作者
1025432523 發表于 2020-9-5 19:01
燒錄后是什么問題,舵機沒反應?
這個燒錄后時好時壞的,很尷尬,上面寫的程序中,當紅外傳感器感應到雜物的時候舵機應該不動的,可是有的時候也會動,很煩惱的。大佬啊,幫幫我看看吧
ID:760058 發表于 2020-9-7 01:13 | 只看該作者
man1234567 發表于 2020-9-5 19:04
那我想請教一下,怎么樣才能讓蜂鳴器只響一聲就停,就是舵機運動一次,蜂鳴器響一聲
ID:511890 發表于 2020-9-7 02:22 | 只看該作者
這個應該是燈亮滅的過程中和脈沖發生中斷產生沖突的原因。把舵機控制放到第一位。然后再去亮滅燈和其它的。修改程序如下:
   Trig = 1;
   Delay_us (5);
   Trig = 0;
   while (Echo == 0);
   TR0  = 1;
   while (Echo);
   TR0  = 0;
   time = TH0*256+TL0;
   TH0 = 0;
   TL0 = 0;
   servorTime = 0;
    led = 0;       //指示燈閃亮
       delay(50);  //這三行注釋掉,改成檢測到有雜物燈常亮,判斷下紅外檢測是否正常。
    led = 1;   //這三行注釋掉,改成檢測到有雜物燈常亮,判斷下紅外檢測是否正常。
     delay(100);//這三行注釋掉,改成檢測到有雜物燈常亮,判斷下紅外檢測是否正常。
    TR1 = 0;
    delay (200);
    delay (200);
    TR1 = 1;
    delay (200);
    delay (200);
    if(led1 == 1)
     led = 1;
    servorTime =0;
     beep = 1;
     TR1 = 1;
     delay(200);
     delay(200);
     TR1 = 0;
     delay(200);
     delay(200);
    servorTime =0;
     TR1 = 1;
     delay(200);
     delay(200);
     TR1 = 0;
     delay(200);
     delay(200);
       beep = 0;
      delay (50);
      beep = 1;
      delay (2500);
如果還是不行,那要看看紅外是否出問題了。把紅外檢測到雜物燈閃改成常量檢查下紅外感應是否出問題。
參與人數 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎勵!
ID:816586 發表于 2020-9-7 08:43 | 只看該作者
燒錄后是什么問題,舵機沒反應?
ID:760058 發表于 2020-9-10 19:26 | 只看該作者
幻劍心 發表于 2020-9-7 02:22
這個應該是燈亮滅的過程中和脈沖發生中斷產生沖突的原因。把舵機控制放到第一位。然后再去亮滅燈和其它的。 ...
好的,謝謝啦,情況我已經解決了,哈哈,感謝感謝。
ID:760058 發表于 2020-9-10 19:27 | 只看該作者
圖銳工程 發表于 2020-9-7 08:43
燒錄后是什么問題,舵機沒反應?
情況已經解決,感謝少俠。
ID:1036122 發表于 2022-6-21 15:32 | 只看該作者
可以求這個垃圾桶的所有資料嘛,包括實物圖,pcb圖等
ID:760058 發表于 2022-10-5 22:35 | 只看該作者
1205200383 發表于 2022-6-21 15:32
這個垃圾桶我沒做PCB板子,就按照這個程序搭建了一個硬件電路,就是做著玩玩的
ID:879348 發表于 2022-10-6 13:33 | 只看該作者
沒有實物談何漏洞
