只需一步,快速開(kāi)始
查看: 3019|回復(fù): 7
求大神指教啊我的1602為什么不顯示啊?
ID:443783 發(fā)表于 2020-8-29 23:36 | 顯示全部樓層 |閱讀模式
  1. #include<reg51.h>
  2. #define uint signed int
  3. #define uchar signed char
  4. uchar aa[]={"current voiltage :"};
  5. sbit lcden = P3^4;
  6. sbit lcdrs = P3^5;
  7. sbit START = P2^0;
  8. sbit CLK = P2^1;
  9. sbit EOC = P2^2;
  10. sbit OE = P2^3;
  11. sbit AA = P2^4;
  12. sbit BB = P2^5;
  13. sbit CC = P2^6;
  14. float v;
  15. void delay(uint ms)   //延時(shí)函數(shù)
  16. {
  17.   uchar i;
  18.   while(ms--);
  19.   {
  20.    for(i<0;i<120;i++);
  21.   }
  22. }
  23. void write_com(uchar com)    //寫命令函數(shù)
  24. {
  25.   lcdrs=0;
  26.   P0=com;
  27.   delay(5);
  28.   lcden=1;
  29.   delay(5);
  30.   lcden=0;
  31. }
  32. void write_data(uchar date)   //寫數(shù)據(jù)函數(shù)
  33. {
  34.   lcdrs=1;
  35.   P0=date;
  36.   delay(5);
  37.   lcden=1;
  38.   delay(5);
  39.   lcden=0;
  40. }
  41. void LCD1602_init()   //1602初始化函數(shù)
  42. {
  43.   lcden=0;
  44.   write_com(0x38);
  45.   write_com(0x0C);
  46.   write_com(0x01);
  47. }
  48. void display (int v)
  49. {
  50.   int shu,i;
  51.   write_com(0x80);
  52.   for(i=0;i<16;i++)
  53.    {
  54.     write_data(aa[i]);
  55.    }
  56.   write_com(0x80+0x46);
  57.    shu=v/100;
  58.    write_data(shu+'0');
  59.    delay(5);
  60.    write_data('.');
  61.    delay(5);
  62.     shu=v%100/10;
  63.     delay(5);
  64.     write_data(shu+'0');
  65.     delay(5);
  66.      shu=v%10;
  67.      write_data(shu+'0');
  68.      delay(5);
  69.      write_data('V');
  70. }
  71. void main()
  72. {
  73.   LCD1602_init();
  74.   TMOD=0x02;
  75.   TH0=0x14;
  76.   TL0=0X14;
  77.   IE=0X82;
  78.   TR0=1;
  79.   P2=0x0f;  //選用通道0,CLK=1,START=1,EOC=1,OE=1.
  80.   while(1)
  81.   {
  82.    START=0;
  83.    START=1;
  84.    START=0;
  85.    while(EOC=0);
  86.    OE=1;
  87.    v=P1*1.0/255*500;
  88.    display(v);
  89.    OE=0;
  90.   }
  91. }
  92. void Timer0() interrupt 1
  93. {
  94.   CLK=!CLK;
  95. }
ID:146782 發(fā)表于 2020-8-31 16:08 | 顯示全部樓層
while(EOC=0);這里有錯(cuò)
ID:429356 發(fā)表于 2020-8-31 14:55 | 顯示全部樓層
RW接IO扣一開(kāi)始給顯示屏顯示幾個(gè)字母一下看能不能正常,再清屏接著你程序又不影響,可以檢查一下你上面的程序會(huì)不會(huì)卡死沒(méi)運(yùn)行下來(lái)
ID:235954 發(fā)表于 2020-8-31 09:17 | 顯示全部樓層
while(EOC=0); 在這里了,應(yīng)該改為EOC==0
ID:235954 發(fā)表于 2020-8-31 09:13 | 顯示全部樓層
等待釋放,估計(jì)是卡在那里了
ID:444925 發(fā)表于 2020-8-30 11:26 | 顯示全部樓層
建議 LCD接口的RW 用單片機(jī)的IO來(lái)控制,而不是一直接低電平
ID:443783 發(fā)表于 2020-8-29 23:58 | 顯示全部樓層
主函數(shù)中 WHILE(EOC==0)這里少打個(gè)=
ID:443783 發(fā)表于 2020-8-29 23:38 | 顯示全部樓層
顯示函數(shù)沒(méi)的問(wèn)題 就是“v=P1*1.0/255*500”;如果把P1改成255 就可以正確顯示5.00V
