本帖最后由 51黑電子會(huì)員 于 2020-8-27 13:27 編輯
- #include <reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define LCD12864Data P2//LCD12864點(diǎn)陣型液晶顯示器輸入輸出數(shù)據(jù)/命令端口
- sbit LCD12864_RS=P0^7;//LCD12864點(diǎn)陣型液晶顯示器數(shù)據(jù)/命令選擇端
- sbit LCD12864_RW=P0^6;//LCD12864點(diǎn)陣型液晶顯示器讀/寫端
- sbit LCD12864_EN=P0^5;//LCD12864點(diǎn)陣型液晶顯示器使能端
- //太陽
- uchar code sun[]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x02,0x40,0x08,0x10,0x00,0x00,0x10,0x08,0x00,0x00,0x10,0x08,0x00,0x00,0x08,0x10,0x02,0x40,0x00,0x00,0x00,0x00,0x00,0x00};
- //月亮
- uchar code moon[]={0x00,0x00,0x00,0x00,0x03,0x80,0x02,0x40,0x02,0x20,0x02,0x10,0x02,0x10,0x02,0x10,0x02,0x10,0x02,0x10,0x02,0x10,0x02,0x20,0x02,0x40,0x03,0x80,0x00,0x00,0x00,0x00};
- //星星
- uchar code star[]={0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x02,0x80,0x00,0x00,0x54,0x54,0x20,0x08,0x08,0x20,0x02,0x80,0x12,0x90,0x08,0x20,0x20,0x08,0x00,0x00,0x00,0x00};
- //人
- uchar code robot[]={0x07,0xE0,0x08,0x10,0x12,0x48,0x10,0x08,0x1F,0xF8,0x10,0x08,0x30,0x0C,0x50,0x0A,0x50,0x0A,0x50,0x0A,0x50,0x0A,0x5F,0xFA,0x04,0x20,0x04,0x20,0x04,0x20,0x0E,0x70};
- void Delay(uint i)
- while(--i);
- void ReadBuzy()//讀忙函數(shù)
- P2=0x00;
- LCD12864_RS=0;
- LCD12864_RW=1;
- LCD12864_EN=1;
- while(P2 & 0x80);
- LCD12864_EN=0;
- void LCD12864WriteCommand(uchar command)//寫指令函數(shù)
- ReadBuzy();//讀忙
- LCD12864_RS=0;
- LCD12864_RW=0;
- LCD12864_EN=1;
- LCD12864Data=command;
- Delay(100);
- LCD12864_EN=0;
- void LCD12864WriteData(uchar value)//寫數(shù)據(jù)函數(shù)
- ReadBuzy();//讀忙
- LCD12864_RS=1;
- LCD12864_RW=0;
- LCD12864_EN=1;
- LCD12864Data=value;
- Delay(100);
- LCD12864_EN=0;
- void LCD12864Init()//LCD12864點(diǎn)陣型液晶顯示器初始化函數(shù)
- ReadBuzy();//讀忙
- Delay(4000);
- LCD12864WriteCommand(0x30);//8位數(shù)據(jù)端口傳輸,且設(shè)置為基本指令集動(dòng)作。
- Delay(100);
- Delay(37);
- LCD12864WriteCommand(0x0c);//設(shè)置整體顯示,光標(biāo)、閃爍全關(guān),不反白。
- Delay(100);
- LCD12864WriteCommand(0x01);//清屏,并且DDRAM數(shù)據(jù)指針清零。
- Delay(10000);
- LCD12864WriteCommand(0x06);//進(jìn)入點(diǎn)設(shè)定模式,設(shè)置地址指針自動(dòng)加1。
- void CGRAM()//寫自定義字符函數(shù)
- uchar i;
- LCD12864WriteCommand(0x30);//設(shè)置LCD12864點(diǎn)陣型液晶顯示器數(shù)據(jù)端口D0-D7為8位控制接口,且這8位控制接口接收基本指令操作。
- LCD12864WriteCommand(0x40);//寫自定義字符到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM第1個(gè)內(nèi)存地址
- for(i=0;i<16;i++)//一個(gè)完整自定義字符占用LCD12864點(diǎn)陣型液晶顯示器16(行)x16(列)顯示界面,每一行占用2個(gè)字節(jié)(即16列)才顯示該行某點(diǎn)字符,因單片機(jī)寫數(shù)據(jù)是以寫2個(gè)字節(jié)為一次寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,且一個(gè)完整自定義字符占用32個(gè)字節(jié),那么要寫完一個(gè)完整自定義字符占用的32個(gè)字節(jié),必須分16次來寫,這就是循環(huán)16次的原由。
- LCD12864WriteData(sun[i*2]);//把第一個(gè)字節(jié)的自定義字符寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。
- LCD12864WriteData(sun[i*2+1]);//把第二個(gè)字節(jié)的自定義字符寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。為什么乘以2?由于單片機(jī)寫數(shù)據(jù)是以寫2個(gè)字節(jié)為一次寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,所以要乘以2。
- LCD12864WriteCommand(0x50);//寫自定義字符到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM第2個(gè)內(nèi)存地址
- LCD12864WriteData(moon[i*2]);//把第一個(gè)字節(jié)的自定義字符寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。
- LCD12864WriteData(moon[i*2+1]);//把第二個(gè)字節(jié)的自定義字符寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。為什么乘以2?由于單片機(jī)寫數(shù)據(jù)是以寫2個(gè)字節(jié)為一次寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,所以要乘以2。
- LCD12864WriteCommand(0x60);//寫自定義字符到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM第3個(gè)內(nèi)存地址
- LCD12864WriteData(star[i*2]);//把第一個(gè)字節(jié)的自定義字符寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。
- LCD12864WriteData(star[i*2+1]);//把第二個(gè)字節(jié)的自定義字符寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。為什么乘以2?由于單片機(jī)寫數(shù)據(jù)是以寫2個(gè)字節(jié)為一次寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,所以要乘以2。
- LCD12864WriteCommand(0x70);//寫自定義字符到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM第4個(gè)內(nèi)存地址
- for(i=0;i<16;i++)//一個(gè)完整自定義字符占用LCD12864點(diǎn)陣型液晶顯器16(示行)x16(列)顯示界面,每一行占用2個(gè)字節(jié)(即16列)才顯示該行某點(diǎn)字符,因單片機(jī)寫數(shù)據(jù)是以寫2個(gè)字節(jié)為一次寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,且一個(gè)完整自定義字符占用32個(gè)字節(jié),那么要寫完一個(gè)完整自定義字符占用的32個(gè)字節(jié),必須分16次來寫,這就是循環(huán)16次的原由。
- LCD12864WriteData(robot[i*2]);//把第一個(gè)字節(jié)的自定義字符寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。
- LCD12864WriteData(robot[i*2+1]);//把第二個(gè)字節(jié)的自定義字符寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。為什么乘以2?由于單片機(jī)寫數(shù)據(jù)是以寫2個(gè)字節(jié)為一次寫到LCD12864點(diǎn)陣型液晶顯示器內(nèi)部ST7920芯片的CGRAM內(nèi)存地址上,所以要乘以2。
- void main()//主函數(shù)
- LCD12864Init();//LCD12864點(diǎn)陣型液晶顯示器初始化函數(shù)
- CGRAM();//寫自定義字符函數(shù)
- LCD12864WriteCommand(0x98);//LCD12864點(diǎn)陣型液晶顯示器下半屏第二行第1個(gè)顯示位置
- LCD12864WriteData(0x00);//清空DRAM內(nèi)存地址上的內(nèi)容
- LCD12864WriteData(0x00);//把自定義字符寫進(jìn)DDRAM內(nèi)存地址0x00,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。
- LCD12864WriteCommand(0x99);//LCD12864點(diǎn)陣型液晶顯示器下半屏第二行第2個(gè)顯示位置
- LCD12864WriteData(0x02);//把自定義字符寫進(jìn)DDRAM內(nèi)存地址0x02,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。
- LCD12864WriteCommand(0x9A);//LCD12864點(diǎn)陣型液晶顯示器下半屏第二行第3個(gè)顯示位置
- LCD12864WriteData(0x04);//把自定義字符寫進(jìn)DDRAM內(nèi)存地址0x04,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。
- LCD12864WriteCommand(0x9B);//LCD12864點(diǎn)陣型液晶顯示器下半屏第二行第4個(gè)顯示位置
- LCD12864WriteData(0x06);//把自定義字符寫進(jìn)DDRAM內(nèi)存地址0x06,供LCD12864點(diǎn)陣型液晶顯示器讀取顯示。
- while(1);//固定循環(huán)
評(píng)分
查看全部評(píng)分
