我從串口監(jiān)視器發(fā)送 數(shù)字123,arduino得到的是1,2,3,獨(dú)立的三個(gè)數(shù)字 。
如果需要發(fā)送一個(gè)字符串怎么發(fā)送?arduino又要怎樣接收字符串?
截圖:
代碼:
verify the function and serial port.
int isodd(int a )
if (a % 2 == 0)
return 1;
return 0;
void setup() {
// put your setup code here, to run once:
Serial.begin(9600);
pinMode(13, OUTPUT);
void loop() {
// put your main code here, to run repeatedly:
if (Serial.available())
int a = Serial.read() - '0';
if (isodd(a))
digitalWrite(13, HIGH);
Serial.print(a);
Serial.println(" 是偶數(shù)");
Serial.print(a);
Serial.println(" 是奇數(shù)");
digitalWrite(13, LOW);
