查看: 3496|回復: 6
求助:STC12C5A60S2單片機的片內EEPROM為何寫不進去?
ID:356610 發表于 2020-8-4 16:22 | 顯示全部樓層 |閱讀模式
STC12C5A60S2的片內EEPROM卡了一周了,請高手幫忙看下,感激不盡!
為了方便閱讀,我只把關于EEPROM的代碼貼出來。
#define CMD_READ                                1
#define CMD_PROGRAM                        2
#define CMD_ERASE                                3
#define ENABLE_IAP                                0x83
#define IAP_ADDRESS_1                         0x0000
void Initialization()
        DehumiTimeSet = IAP_Read_Byte(IAP_ADDRESS_1);
        if(DehumiTimeSet > 99 || DehumiTimeSet < 1)
                DehumiTimeSet = 48;
        DehumiTimeSetBak = DehumiTimeSet;
        Initialization();
                if(bit_Timer100ms)                //中斷2ms,計數器累加50次就是100ms
                        bit_Timer100ms = 0;
                        Display();
                        KeyDispose();
void KeyDispose()
        if(Key_Value == 0)                        //60秒內無按鍵按下則顯示DHT11溫濕度
                if(bit_NoKeyPress)
                        NoKeyPressDelayCnt++;
                        if(NoKeyPressDelayCnt >= 600)
                                NoKeyPressDelayCnt = 0;
                                if(DehumiTimeSetBak != DehumiTimeSet)
                                        EEPROM_WriteDehumiTimeSet();
void EEPROM_WriteDehumiTimeSet()                    //先擦除扇區,再寫入數據
        IAP_Erase_Sector(IAP_ADDRESS_1);
        IAP_Write_Byte(IAP_ADDRESS_1,DehumiTimeSet);
void IAP_Idle()
        IAP_CONTR = 0;
        IAP_CMD = 0;
        IAP_TRIG = 0;
        IAP_ADDRH = 0x80;
        IAP_ADDRL = 0;
unsigned char IAP_Read_Byte(unsigned int addr)
        unsigned char dat;
        IAP_CONTR = ENABLE_IAP;                                //允許IAP功能,Clock<12MHz
        IAP_CONTR = CMD_READ;                                        //讀
        IAP_ADDRL = addr;
        IAP_ADDRH = addr >> 8;
        IAP_TRIG = 0x5a;
        IAP_TRIG = 0xa5;
        _nop_();_nop_();_nop_();
        dat = IAP_DATA;
        IAP_Idle();
        return dat;
void IAP_Write_Byte(unsigned int addr,unsigned char dat)
        IAP_CMD = CMD_PROGRAM;                                //寫
        IAP_ADDRL = addr;
        IAP_DATA = dat;
        IAP_TRIG = 0x5a;
        IAP_TRIG = 0xa5;
        IAP_Idle();
void IAP_Erase_Sector(unsigned int addr)
        IAP_CMD = CMD_ERASE;                                        //擦除
        IAP_ADDRL = addr;
        IAP_TRIG = 0x5a;
        IAP_TRIG = 0xa5;
        IAP_Idle();
ID:636538 發表于 2020-8-4 16:31 | 顯示全部樓層
首先你想寫入進入參數,那這個函數EEPROM_WriteDehumiTimeSet(形參)要有個形參吧,要不然你想寫入的東西,怎么放入這個EEPROM
ID:356610 發表于 2020-8-4 16:39 | 顯示全部樓層
SKYLAR123 發表于 2020-8-4 16:31
首先你想寫入進入參數,那這個函數EEPROM_WriteDehumiTimeSet(形參)要有個形參吧,要不然你想寫入的東西, ...
DehumiTimeSet就是要寫入的數據(1個字節)。
ID:636538 發表于 2020-8-4 17:34 | 顯示全部樓層
zsj1984 發表于 2020-8-4 16:39
        IAP_Erase ...
哦,那你這個DehumiTimeSet是全局變量是嗎,
ID:636538 發表于 2020-8-4 17:47 | 顯示全部樓層
        IAP_Erase ...
我意識到你是STC12C5A60S2,你有沒有看官方的數據手冊,建議你參考官方測試用例,有寫這個EEPROM至少我看到的延時是一個_nop_();
ID:804115 發表于 2020-8-4 17:51 | 顯示全部樓層
建議在EEPROM_WriteDehumiTimeSet();處加入調試信息,看看到底有么有走到這里,可以用uart打印log也可以通過屏disp一些信息。
ID:213173 發表于 2020-8-4 20:18 | 顯示全部樓層
STC單片機EEPROM讀寫其實還是很簡單的。單以這段程序片段無法判斷問題所在,懷疑KeyDispose()里4個if條件不能全部滿足。比如NoKeyPressDelayCnt的數據類型等等。
