本任務(wù)是用單片機(jī)實(shí)現(xiàn)液晶顯示演示效果如圖所示。通過編程,學(xué)會在單片機(jī)上實(shí)現(xiàn)液晶顯示控制方法,以及不同數(shù)據(jù)顯示的程序編寫方法。
2020-7-31 15:42 上傳
單片機(jī)源程序如下:
- #include "LCD_12864.h"
- #include <stdio.h>
- extern void cls();
- extern uchar LCD_Initialise();
- extern uchar LCD_Write_Command(uchar cmd);
- extern uchar LCD_Write_Command_P2(uchar cmd,uchar para1,uchar para2);
- extern uchar LCD_Write_Data(uchar dat);
- extern void Set_LCD_POS(uchar row,uchar col);
- extern uchar code LCD_WIDTH;
- extern uchar code LCD_HEIGHT;
- sbit S1 = P1^0;
- sbit S2 = P1^1;
- uchar code ImageX[] =
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
- void main()
- uchar i,j,m;
- uint k,x;
- LCD_Initialise();
- Set_LCD_POS(0,0);
- cls();
- while(1)
- if(S1!=0)
- LCD_Write_Command_P2(LC_GRH_STP,0,0);
- for(i=0;i<LCD_HEIGHT;i++)
- Set_LCD_POS(i,0);
- LCD_Write_Command(LC_AUT_WR);
- for(j=0;j<LCD_WIDTH;j++)
- m = ImageX[i*LCD_WIDTH + j];
- if(S2 == 0)
- m = ~m;
- LCD_Write_Data(m);
- LCD_Write_Command(LC_AUT_OVR);
- else
- k = 0;
- while(k!=128/8*LCD_HEIGHT)
- LCD_Write_Command_P2(LC_GRH_STP,k%256,k/256);
- for(x=0;x<5000;x++);
- k+=LCD_WIDTH;
- for(x=0;x<40000;x++);
2020-7-31 15:44 上傳
12864LCD圖形滾動演示.zip
(99.85 KB, 下載次數(shù): 58)
2020-7-31 10:42 上傳
點(diǎn)擊文件名下載附件
12864顯示圖片 下載積分: 黑幣 -5
