查看: 3887|回復: 8
單片機LCD1602字符液晶滾動演示程序問題
ID:668004 發表于 2020-7-28 18:15 | 顯示全部樓層 |閱讀模式
uchar code Prompt[]="Press K1 - K3 To Start Demo Prog";--------------這條語句有作用不
while((Busy_Check()&0x80)==0x80);------------一個變量與上一個十六進制數,啥東東
void ShowString(uchar,uchar,uchar *);----------------這個是定義一個指針變量?
//main.c
/*        名稱:LCD1602字符液晶滾動演示程序
        說明:K1~K3按鈕分別實現液晶垂直或水平滾動顯示及暫停與繼續控制。
#include<reg51.h>
#include<string.h>
void Initialize_LCD();
void DelayMS(uint ms);
sbit K1=P3^0;
sbit K2=P3^1;
sbit K3=P3^2;
//待滾動顯示的信息段落,每行不超過80個字符,共6行
uchar const Line_Count=6;
uchar code Msg[][80]=
        "Many CAD users dismiss schematic capture as a necessary evil in the ",
        "process of creating PCB layout but we have always disputed this point ",
        "of view. With PCB layout now offering automation of both component ",
        "can often be the most time consuming element of the exercise.",
        "And if you use circuit simulation to develop your ideas, ",
        "you are going to spend even more time working on the schematic."
//顯示緩沖(2行)
uchar Disp_Buffer[32];
//垂直滾動顯示
void V_Scroll_Display()
        uchar i,j,k=0;
        uchar *p=Msg[0];
        uchar *q=Msg[Line_Count]+strlen(Msg[Line_Count]);
        //以下僅使用顯示緩沖的前16字節空間
        while(p<q)
                for(i=0;i<16&&p<q;i++)
                {        //消除顯示緩沖中待顯示行首尾可能出現的空格
                        if((i==0||i==15)&&*p==' ') p++;
                        if(*p!='\0')
                                Disp_Buffer[ i]=*p++;
                                if(++k>Line_Count) break;
                                p=Msg[k];                                        //p指向下一串的首地址
                //不足16個字符時空格補充
                for(j=i;j<16;j++) Disp_Buffer[j]=' ';
                //垂直滾動顯示
                while(F0) DelayMS(5);
                ShowString(0,0,"                 ");
                DelayMS(150);
                ShowString(0,1,Disp_Buffer);
                DelayMS(150);
                ShowString(0,0,Disp_Buffer);
                ShowString(0,1,"                 ");
                DelayMS(150);
        //最后清屏
//水平滾動顯示
void H_Scroll_Display()
        uchar i,j,k=0,L=0;
        uchar *p=Msg[0];
        //將32個字符的顯示緩沖前16個字符設為空格
        for(i=0;i<16;i++) Disp_Buffer[ i]=' ';
        while(p<q)
                //忽略緩沖中首尾可能出現的空格
                if((i==16||i==31)&&*p==' ') p++;
                for(i=16;i<32&&p<q;i++)
                        if(*p!='\0')
                //不足32個字符時空格補充
                for(j=i;j<32;j++) Disp_Buffer[j]=' ';
                //水平滾動顯示
                for(i=0;i<=16;i++)
                        ShowString(0,L,Disp_Buffer+i);
                        DelayMS(20);
                L=(L==0)?1:0;                //行號在0,1間交替
                DelayMS(300);
        //如果顯示結束時停留在第0行,則清除第1行的內容
        if(L==1) ShowString(0,1,"                 ");
//外部中斷0,由K3控制暫停與繼續顯示
void EX_INT0() interrupt 0
        F0=!F0;                //暫停與繼續顯示控制標志位
//主程序
        uint Count=0;
        IE=0x81;                //允許外部中斷0
        IT0=1;                        //下降沿觸發
        F0=0;                        //暫停與繼續顯示控制標志位
        Initialize_LCD();
        ShowString(0,0,Prompt);
        ShowString(0,1,Prompt+16);
                if(K1==0)
                        V_Scroll_Display();
                        DelayMS(300);
                if(K2==0)
                        H_Scroll_Display();
                        DelayMS(300);
//LCD1602.c
/*        名稱:液晶控制與顯示程序
        說明:本程序是通用的1602液晶控制程序。
#include<reg51.h>
#include<intrins.h>
sbit RS=P2^0;
sbit RW=P2^1;
sbit EN=P2^2;
//延時
        uchar i;
        while(ms--) for(i=0;i<120;i++);
//忙檢查
uchar Busy_Check()
        uchar LCD_Status;
        RS=0;                                //寄存器選擇
        RW=1;                                //讀狀態寄存器
        EN=1;                                //開始讀
        DelayMS(1);
        LCD_Status=P0;
        EN=0;
        return LCD_Status;
//寫LCD命令
void Write_LCD_Command(uchar cmd)
        while((Busy_Check()&0x80)==0x80);        //忙等待
        RS=0;                //選擇命令寄存器
        RW=0;                //寫
        EN=0;
        P0=cmd;EN=1;DelayMS(1);EN=0;
//發送數據
void Write_LCD_Data(uchar dat)
        RS=1;RW=0;EN=0;P0=dat;EN=1;DelayMS(1);EN=0;
//LCD初始化
        Write_LCD_Command(0x38);DelayMS(1);
        Write_LCD_Command(0x01);DelayMS(1);        //清屏
        Write_LCD_Command(0x06);DelayMS(1);        //字符進入模式:屏幕不動,字符后移
        Write_LCD_Command(0x0c);DelayMS(1);        //顯示開,光標關
//顯示字符串
void ShowString(uchar x,uchar y,uchar *str)
        uchar i=0;
        if(y==0) Write_LCD_Command(0x80|x);        //設置顯示起始位置
        if(y==1) Write_LCD_Command(0xc0|x);
        for(i=0;i<16;i++)                                        //輸出字符串
                Write_LCD_Data(str[ i]);
ID:804115 發表于 2020-7-28 19:38 | 顯示全部樓層
本帖最后由 1692483014 于 2020-7-28 19:40 編輯
答:有用,main函數進入后調用了
用于將"Press K1 - K3 To Start Demo Prog"字符串顯示到屏幕上。
答:這個是檢測Busy_Check()函數返回值的最高位BIT7是否為1,如果為1,那么就在這里死等,直到它為0再運行下面的代碼,那BIT7什么時候會等于0呢?當LCD_Status不忙的時候就會為0了。
整個這一行是為了保證LCD處理完了上一條指令后才能進行后面的LCD指令的操作,要不可能出錯。
答:這是聲明一個函數,聲明函數要求必須列出參數的類型,但不一定非要列出變量。這個聲明類似于.h文件的聲明,只不過這是局部聲明,只能在聲明之后的函數里調用ShowString函數。
ID:668004 發表于 2020-7-29 14:44 | 顯示全部樓層
1692483014 發表于 2020-7-28 19:38
答:有用,mai ...
非常的幫  給你點贊  專業
ID:668004 發表于 2020-7-29 14:55 | 顯示全部樓層
答:有用,mai ...
這里有個*號是啥意思
ID:668004 發表于 2020-7-29 14:57 | 顯示全部樓層
答:有用,mai ...
與上1000 0000就是為了判斷最高位是不是1 對嗎?為什么是這一位進行判斷就可以
ID:668004 發表于 2020-7-30 10:10 | 顯示全部樓層
答:有用,mai ...
你是軟硬件通吃的大牛。。。。原來
ID:804115 發表于 2020-8-1 02:44 | 顯示全部樓層
QWE4562012 發表于 2020-7-29 14:55
這里有個*號是啥意思
你說這個*嗎?這不就是指針嗎?
把C語言那本書再看幾遍吧!
ID:804115 發表于 2020-8-1 02:46 | 顯示全部樓層
QWE4562012 發表于 2020-7-29 14:57
是的,這一位對應P0口的P0.7引腳,這個腳為高電平,說明LCD在忙,你要等,等他變低,LCD就忙完了,所以要檢測這個bit。
ID:804115 發表于 2020-8-1 02:51 | 顯示全部樓層
QWE4562012 發表于 2020-7-30 10:10
你是軟硬件通吃的大牛。。。。原來
我來這里回答問題,是為了學習的,但是我發現更多的是新手提問題,能提出難一點兒問題的不多,我很期待有難度而且我很感興趣的問題,這樣我就可以百度它,思考它,解決它,從而增長知識,順便還能賺點兒金幣,哈哈。
你要努力呀!希望再過幾個月能提出更深一點兒的問題。
