查看: 3898|回復: 1
at89c52單片機+8位數碼管實現秒表程序
有重啟,終止,停表功能。(復位電路及外部晶振忽略)
protues8仿真圖如下:
程及仿真在附件中下載
  1. #include <REGX52.H>
  2. char code seg7cat[18] = {0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xf8,
  3.                         0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,0xBF,0x7F};//'-'
  4. void delayms(unsigned int td);
  5. void seg7x8_display(unsigned char *p);
  6. void clock_refresh(void);
  7. void stop_2(void);
  8. void Int0Init();
  9. unsigned char T0CNT,M,S,SD2;
  10. unsigned int stop1=0,stop2=1;
  11. unsigned char dis_buf[9];
  12. sbit k1=P3^2;  //定義獨立按鍵K1
  13. sbit k2=P3^3;  //定義獨立按鍵K2
  14. sbit k3=P3^4;  //定義獨立按鍵K3
  15. void main(void)
  16. {
  17.                 unsigned char i;
  18.     Int0Init();
  19.                 T0CNT = M = SD2 = S = 0;
  20.     for(i=0;i<8;i++)  dis_buf[ i ] = 0;  //清除顯示緩存
  21.     TH0  = (65536-500)/256;
  22.     TL0   = (65536-500)%256;     //定時時間50ms,0.5ms
  23.     TMOD = 0x11;
  24.     ET0  = 1;
  25.     EA   = 1;
  26.     TR0  = 1;
  27.     for(;;)
  28.                 {
  29.                         stop_2();
  30.                         seg7x8_display(dis_buf);
  31.                 }
  32. }
  33. void  timer0_isr(void)   interrupt   1
  34. {  TH0  = (65536-500)/256;
  35.     TL0  = (65536-500)%256;
  36.     if( ++T0CNT >=20)
  37.     {   T0CNT  =   0;   P1 = ~P1;
  38.          clock_refresh();
  39.     }
  40. }
  41. //        設置外部中斷0
  42. void Int0Init()
  43. {
  44.         //設置INT0,外部中斷0
  45.         IT0=1;
  46.         EX0=1;
  47.         //設置INT0,外部中斷1
  48.         IT1=1;
  49.         EX1=1;
  50.         EA=1;
  51. }
  52. //延時子程序
  53. void delayms(unsigned int td)
  54. {    unsigned int i,j;
  55.      for(i=0;i<td;i++)
  56.      for(j=0;j<120;j++){}
  57. }
  58. //顯示子程序
  59. void seg7x8_display(unsigned char *p)
  60. {    unsigned char i;
  61.      for(i=0;i<8;i++)
  62.      {
  63.                          if(i==5)
  64.                          {P0 = (127&(int)seg7cat[dis_buf[8]]);}
  65.                          else
  66.                          {P0 = seg7cat[p[i]];}
  67.        P2 = ~(1<<i);           delayms(4);
  68.        P2 = 0xFF;               delayms(1);
  69.   }
  70. }
  71. void clock_refresh(void)
  72. {
  73.         if(++SD2 >= 100)
  74.         {
  75.                 SD2=0;
  76.                 if(++S>=60)
  77.                 {
  78.                         S = 0;
  79.             if(++M>=60)
  80.               M = 0;
  81.                 }
  82.    }
  83.         if(stop2)
  84.         {
  85.       dis_buf[0] = M/10;
  86.       dis_buf[1] = M%10;
  87.       dis_buf[2] = 16;
  88.       dis_buf[3] = 16;  //'-’
  89.       dis_buf[4] = S/10;
  90.       dis_buf[5] = 17;  //'.’
  91.       dis_buf[6] = SD2/10;
  92.       dis_buf[7] = SD2%10;
  93.                         dis_buf[8] = S%10;
  94.         }
  95. }
  96. //歸零
  97. void Int0()        interrupt 0                //外部中斷0的中斷函數
  98. {
  99.         unsigned char i;
  100.         if(k1==0)
  101.         {
  102.
  103.                 for(i=0;i<100;i++)
  104.                 {
  105.                         if(k1==0){i=0;}
  106.                 }
  107.                 T0CNT = M = SD2 = S = 0;
  108.         }
  109. }
  110. //暫停,停表
  111. void Int1()        interrupt 2                //外部中斷1的中斷函數
  112. {
  113.         unsigned char i;
  114.         if(k2==0)
  115.         {
  116.                 for(i=0;i<10;i++)
  117.                 {
  118.                         if(k2==0){i=0;}
  119.                 }
  120.                 stop1 = !stop1;
  121.                 while(stop1)
  122.                 {
  123.                         if(k2==0)
  124.                         {
  125.                                 for(i=0;i<10;i++)
  126.                                 {
  127.                                         if(k2==0){i=0;}
  128.                                 }
  129.                                 stop1 = !stop1;
  130.                         }
  131.                         seg7x8_display(dis_buf);
  132.                 }
  133.         }
  134. }
  135. //停表
  136. void stop_2(void)
  137. {
  138.         unsigned char i;
  139.         if(k3==0)
  140.         {
  141.                 for(i=0;i<10;i++)
  142.                 {
  143.                         if(k3==0){i=0;}
  144.                 }
  145.                 stop2 = !stop2;
  146.         }
  147. }
秒表.zip (35.47 KB, 下載次數: 24)
ID:448260 發表于 2020-10-24 10:31 | 只看該作者
仿真嘞
