我打開我的例程,然后編譯,卻顯示這樣
*** Please review the installed ARM Compiler Versions:
'Manage Project Items - Folders/Extensions' to manage ARM Compiler Versions.
'Options for Target - Target' to select an ARM Compiler Version for the target.
*** Rebuild aborted
然后按照網(wǎng)上的要求,換了個編譯器.就是keil5那個魔法棒里targe里的ARM compiler 換到了第二個,結果例程居然都出現(xiàn)錯誤。害
