2013-6-20 23:31 上傳
2013-6-20 23:31 上傳
2013-6-20 23:31 上傳
2013-6-20 23:31 上傳
2013-6-20 23:31 上傳
2013-6-20 23:31 上傳
源代碼:
// STC 1T @ 12MHz
// P1.0 測量端
// P1.1 接基準源2.5V(TL431)
#include <STC15F204EA.H>
sbit IO_4 = P0^0; //接LCD1602的引腳D4
sbit IO_E = P0^1; //接LCD1602的引腳E
#define Set_xy(x,y) Send(0,(y<<6)|(x&15)|0x80)
uint8c ASC[]={
0x04,0x1F,0x15,0x1F,0x15,0x1F,0x04,0x07, //0:電
0x0F,0x08,0x0A,0x0A,0x0F,0x0A,0x13,0x0F, //1:壓
0x0f,0x09,0x09,0x0f,0x09,0x09,0x0f,0x00, //2:
0x10,0x06,0x09,0x08,0x08,0x09,0x06,0x00, //3:
0x08,0x0f,0x12,0x0f,0x0a,0x1f,0x02,0x00, //4:
0x0f,0x09,0x0f,0x09,0x0f,0x09,0x11,0x00, //5:
0x0f,0x09,0x09,0x0f,0x09,0x09,0x0f,0x00, //6:
0x10,0x06,0x09,0x08,0x08,0x09,0x06,0x00 //7:
void YS14520us(void)
uint8 a,b,c;
for(c=2;c>0;c--)
for(b=238;b>0;b--)
for(a=90;a>0;a--);
void YS660us(void)
uint8 a,b,c;
for(c=2;c>0;c--)
for(b=94;b>0;b--)
for(a=9;a>0;a--);
void YS30us(void)
uint8 a;
for(a=87;a>0;a--);
void YSms(uint8 n)
uint8 a,b;
while(n)
for(b=222;b>0;b--)
for(a=12;a>0;a--);
n--;
void Send(uint8 RS, uint8 dat)
uint8 i;
for(i=2;i;i--)
if(dat & 0x80)IO_4 = 1; else IO_4 = 0;
YS14520us(); //14520us (5V,2.2KΩ,2.2uF,4.751065V)
if(RS)IO_E = 1;
if(dat & 0x40)IO_4 = 1; else IO_4 = 0;
YS660us(); //660us (5V,2.2KΩ,100nF,4.751065V)
if(dat & 0x20)IO_4 = 1; else IO_4 = 0;
YS30us(); //30us (5V,2.2KΩ,4.7nF,4.725256V)
IO_E = 1;
if(dat & 0x10)IO_4 = 1; else IO_4 = 0;
NOP12(); //0.5us < t < 1.36us
IO_E = 0;
dat <<= 4;
void Send_S(uint8 *p)
while(*p) Send(1,*p++);
void Init_1602(void)
uint8 i = 3;
P0M0 = 0x03; //P0.0、P0.1推挽輸出
IO_4 = 0;
IO_E = 0;
YSms(40);
Send(0,0x33); YSms(1);
Send(0,0x32); YSms(1);
Send(0,0x28); YSms(1);
Send(0,0x0C); YSms(1);
Send(0,0x06); YSms(1);
Send(0,0x01); YSms(1);
// 裝入CGRAM //
Send(0,0x06); // CGRAM 地址自動加1
Send(0,0x40); // CGRAM 地址設為 00處
for(i=0;i<64;i++)Send(1,ASC); // 按數組寫入數據
/* ADC操作『ADC_CONTR寄存器』常量定義 */
#define ADC_POWER 0x80 //ADC 電源控制位
#define ADC_FLAG 0x10 //ADC 完成標志
#define ADC_START 0x08 //ADC 啟動控制位
#define ADC_speed_LL 0x00 //540 時鐘
#define ADC_speed_L 0x20 //360 時鐘
#define ADC_speed_H 0x40 //180 時鐘
#define ADC_speed_HH 0x60 // 90 時鐘
函數:A/D轉換初始化
初次使用和更換 A/D 轉換通道要適當延時(20uS~200uS), 使輸入電壓穩定。
以后如果不更換 A/D 轉換通道的話, 不需要加延時。
如果輸入電壓信號源的內阻在10K以下,可不加延時。
void AD_Init()
P1M0 |= 0x03; //P1.0、P1.1高阻模式
P1M1 |= 0x03;
ADC_RES = 0;
P1ASF = 0x03; // P1.0、P1.1口作為模擬功能A/D使用
ADC_CONTR = ADC_POWER | ADC_speed_H ; //打開A/D電源 ,轉換1次/270時鐘,默認P1.0通道
YS14520us(); //開電源后延時
函數:A/D轉換程序
輸入:通道號0~7
返回:8位轉換值
說明:更換 A/D 轉換通道要適當延時(20uS~200uS)
uint8 ADC(uint8 CHa)
s_uint8 CHb;
if(CHa != CHb) //檢測是否更換通道號
ADC_CONTR &= 0xF8; //清通道
ADC_CONTR |= CHa; //更換通道
YS660us(); //更換 A/D 轉換通道要適當延時(20uS~200uS)
CHb = CHa; //保存此次通道號
ADC_CONTR |= ADC_START; //ADC_START = 1啟動 AD 轉換,轉換結束ADC_START = 0
NOP12(); //經過4個時鐘延時后,才能夠正確讀到ADC_CONTR控制寄存器的值
while(!(ADC_CONTR & 0x10));
ADC_CONTR &= ~ADC_FLAG; //清0 ADC_FLAG 位, 停止A/D轉換
return ADC_RES; //返回轉換結果
void main(void)
uint8 Value,TL431;
uint16 Voltage;
Init_1602();
Send(0,0x01); //清屏
AD_Init();
Value = ADC(0);
TL431 = ADC(1);
Voltage = 250*Value/TL431;
// 顯示 測量電壓值
Set_xy(0,0);
Send(1,0);
Send(1,1);
Send(1,':');
Send(1,' ');
Send(1,'0'+ Voltage/100);
Send(1,'.');
Send(1,'0'+ Voltage/10%10);
Send(1,'0'+ Voltage%10);
Send_S("V");
// 顯示 測量轉換值 : 基準源轉換值
Set_xy(9,1);
Send(1,'0'+ Value/100);
Send(1,'0'+ Value/10%10);
Send(1,'0'+ Value%10);
Send(1,':');
Send(1,'0'+ TL431/100);
Send(1,'0'+ TL431/10%10);
Send(1,'0'+ TL431%10);
YSms(10);
