查看: 7436|回復: 20
為什么我的51單片機+oled不顯示?求幫助
ID:761375 發(fā)表于 2020-7-13 18:38 | 顯示全部樓層 |閱讀模式
是哪里出問題了嘛
#include <reg52.h>
#include <intrins.h>
typedef unsigned char u8;
typedef unsigned int u16;
sbit SCL = P2^0;
sbit SDA = P2^1;
u8  dis_tab[] =
{0x00,0xE0,0x10,0x08,0x08,
0x10,0xE0,0x00,0x00,0x0F,
0x10,0x20,0x20,0x10,0x0F,0x00};/*"0",0*/
void delay(u16 num)
        u16 x,y;
        for(x = num;x > 0;x--)
        for(y = 110;y > 0;y--);
void delay5us()
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        _nop_();
void iic_start()
        SCL = 1;
        _nop_();
        SDA = 1;
        delay5us();
        SDA = 0;
        delay5us();
void iic_stop()
        SDA = 0;
        _nop_();
        SCL = 1;
        delay5us();
        SDA = 1;
        delay5us();
bit iic_ack()
        SCL = 1;
        delay5us();
        if(SDA)                   //SDA為高:非應答
                SCL = 0;
                _nop_();
                iic_stop();
                return 0;
        else                   //SDA為低:應答
                SCL = 0;
                _nop_();
                return 1;
void iic_send_1byte(u8 byte)
        u8 i;
        for(i = 0;i < 8;i++)
                SCL = 0;
                _nop_();
                if(byte & 0x80)
                        SDA = 1;
                        _nop_();
                        SDA = 0;
                        _nop_();
                SCL = 1;
                _nop_();
                byte <<= 1;
        SCL = 0;
        _nop_();
        SDA = 1;
        _nop_();
/*lcd寫命令
void LCD12864_write_command(u8 cmd)
        iic_start();
        iic_send_1byte(0x78);
        if(!iic_ack())
                iic_stop();
                return 0;
        iic_send_1byte(0x00);
                if(!iic_ack())
                iic_stop();
                return 0;
        iic_send_1byte(cmd);
        if(!iic_ack())
                iic_stop();
                return 0;
        _nop_();
        iic_stop();
/*lcd寫數據
void LCD12864_write_data(u8 *dat)
        iic_start();
        if(!iic_ack())
                iic_stop();
                return 0;
        iic_send_1byte(0x40);
           if(!iic_ack())
                iic_stop();
                return 0;
        iic_send_1byte(*dat);
        if(!iic_ack())
                iic_stop();
                return 0;
        iic_stop();
        _nop_();
/*尋址
void LCD12864_position(u8 i,u8 j)
        LCD12864_write_command(0xb0 + i);
        LCD12864_write_command(0x00 | (j >> 4));
        LCD12864_write_command(0x10 | (j & 0x0f));
/*初始化
void LCD12864_Initial()
        Delay(3);
        LCD12864_write_command(0x8d);
        LCD12864_write_command(0x14);
        LCD12864_write_command(0xaf);
        LCD12864_write_command(0xae);
        LCD12864_write_command(0x20);
        LCD12864_write_command(0x10);
        LCD12864_write_command(0xb0);
        LCD12864_write_command(0xc8);
        LCD12864_write_command(0x00);
        LCD12864_write_command(0x40);
        LCD12864_write_command(0x81);
        LCD12864_write_command(0xff);
        LCD12864_write_command(0xa1);
        LCD12864_write_command(0xa6);
        LCD12864_write_command(0xa8);
        LCD12864_write_command(0x3f);
        LCD12864_write_command(0xa4);
        LCD12864_write_command(0xd3);
        LCD12864_write_command(0xd5);
        LCD12864_write_command(0xf0);
        LCD12864_write_command(0xd9);
        LCD12864_write_command(0x22);
        LCD12864_write_command(0xda);
        LCD12864_write_command(0x12);
        LCD12864_write_command(0xdb);
/*lcd連續(xù)顯示
void LCD12864_more_show(u8 *dat)
        u8 i,j;
                for(j = 0;j < 128;j++)
                        LCD12864_position(i.j);
                        LCD12864_write_data(*dat++);
        LCD12864_Initial();
        LCD12864_position();
                LCD12864_more_show(dis_tab);
ID:789121 發(fā)表于 2020-7-13 23:14 | 顯示全部樓層
背光沒亮吧,電源是不是接錯了,只接電源試一下
ID:738987 發(fā)表于 2020-7-13 23:33 | 顯示全部樓層
電源問題
ID:761375 發(fā)表于 2020-7-14 09:37 | 顯示全部樓層
不要黑 發(fā)表于 2020-7-13 23:14
哪里出問題了嘛??我感覺我連的沒問題啊
ID:761375 發(fā)表于 2020-7-14 10:55 | 顯示全部樓層
請問該怎么解決啊???我重新接了下還是不顯示也沒有背光
ID:789121 發(fā)表于 2020-7-14 13:46 | 顯示全部樓層
wtryb 發(fā)表于 2020-7-14 10:55
有沒有萬用表,測一下兩個引腳電壓有沒有問題,如果電壓和接線都沒問題考慮換一個屏
ID:606956 發(fā)表于 2020-7-14 14:30 | 顯示全部樓層
先查一下電壓是不是正常,再搞個邏輯分析儀看下數據對不對
IIC有沒有接上拉啊
ID:761375 發(fā)表于 2020-7-14 20:31 | 顯示全部樓層
不要黑 發(fā)表于 2020-7-14 13:46
沒有萬用表啊我用的是單片機的DC電源模塊,請問還有什么方法嘛?我的代碼有什么問題嘛?
ID:282850 發(fā)表于 2020-7-15 10:16 | 顯示全部樓層
沙發(fā)回答是亂說的。OLED啊,要看清。
我的一個帖子里有IIC的程序及問題。注意硬件連線,特別是RST
ID:761375 發(fā)表于 2020-7-15 10:19 | 顯示全部樓層
f556 發(fā)表于 2020-7-15 10:16
我這個是四腳的oled貌似沒有RST這個腳
ID:789121 發(fā)表于 2020-7-15 16:34 | 顯示全部樓層
wtryb 發(fā)表于 2020-7-14 20:31
void LCD12864_write_data(u8 *dat)這個函數里為什么有return 0;能編譯通過么
ID:789121 發(fā)表于 2020-7-15 16:45 | 顯示全部樓層
程序還有一些其他小問題,編譯都會提示的,IIC程序參考屏幕賣家給的程序,
IIC程序可以優(yōu)化一下
ID:282850 發(fā)表于 2020-7-15 16:56 | 顯示全部樓層
wtryb 發(fā)表于 2020-7-15 10:19
我沒看仔細,模塊化的是不用關注RST。
程序執(zhí)行中SCL=1 后停止,用電壓表看SCL是否高電平,SCL=0后看是否低電平。SDA同理。所有clear不執(zhí)行,init完后停止幾秒,看有沒有雜亂的點顯示。
ID:789121 發(fā)表于 2020-7-21 13:41 | 顯示全部樓層
oled確實沒有背光,開始以為是普通led,問題解決沒有?
ID:676437 發(fā)表于 2020-7-27 17:48 來自觸屏版 | 顯示全部樓層
樓主搞好了嘛 我和你一樣,有解決辦法嘛
ID:761375 發(fā)表于 2020-9-22 16:31 | 顯示全部樓層
6998 發(fā)表于 2020-7-27 17:48
樓主搞好了嘛 我和你一樣,有解決辦法嘛
http://m.raoushi.com/bbs/dpj-113388-1.html 參照這個
ID:811284 發(fā)表于 2020-9-22 16:42 | 顯示全部樓層
可以用串口顯示數據比如6666,一行一行的網下放,模擬斷點調試,可以驗證是否是程序問題
ID:294296 發(fā)表于 2020-9-22 17:51 | 顯示全部樓層
連接開發(fā)板可能數據腳和板上其它器件芯片沖突了
ID:342822 發(fā)表于 2020-9-22 18:44 | 顯示全部樓層
換個其他成功的程序驗證i2c  oled
ID:342822 發(fā)表于 2020-9-22 18:49 | 顯示全部樓層
程序有問題慢慢找吧~~
