查看: 6978|回復: 5
給大家分享下單片機步進電機程序,ULN2003A驅動,可控制正反轉,啟停加減速
ID:259898 發表于 2020-7-13 10:19 | 顯示全部樓層 |閱讀模式
給大家分享下步進電機,用ULN2003A驅動,可控制正反轉,加速和減速
仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)全部資料下載地址:
  1. #include "reg52.h"
  2. #include<lcd1602.h>
  3. #include "delay.h"
  4. #include "motor4B.h"
  5. sbit K1 = P3^2;//加速
  6. sbit K2 = P3^3;//減速
  7. sbit K3 = P3^4;//正傳
  8. sbit K4 = P3^5;//反轉
  9. sbit K5 = P3^6;//啟動
  10. sbit K6 = P3^7;//停止
  11. void main( )
  12. {
  13.         bit         fangxiang         =                 1;//0是逆時針
  14.         bit         kaiqi                         =                 0;//0是停止
  15.         int          sudu                                =                4;//每次步進間隔時間為 1ms * sudu,也就是最快每秒25轉
  16.         char str_buff[] = { "00.00" };
  17.         int speed = 0;
  18.         init_lcd();
  19.         lcd( 0, 0, "LCD_INIT" );
  20.         delay( 100 );
  21.         lcd( 0, 0, "        " );
  22.         Init_Motor();
  23.         Set_Motor(kaiqi, fangxiang, sudu);
  24.         lcd( 1, 0, "    reversal    " );
  25.         lcd( 0, 0, "Speed: " );
  26.         lcd( 0, 12, "r/s" );
  27.         speed = 1000 / ( 1.0 * 8.0 * sudu ) * 1000;
  28.         str_buff[0] = speed / 10000 % 10 + '0';
  29.         str_buff[1] = speed / 1000 % 10 + '0';
  30.         str_buff[3] = speed / 100 % 10 + '0';
  31.         str_buff[4] = speed % 10 + '0';
  32.         lcd( 0, 6, str_buff );
  33.         while(1)
  34.         {
  35.                 //////////////////////////////////////////////////////////////////////加速
  36.                 if( K1 == 0 )
  37.                 {
  38.                         delay( 50 );
  39.                         if( K1 == 0 )
  40.                         {
  41.                                 sudu--;
  42.                                 if( sudu <= 3 )
  43.                                 {
  44.                                         sudu = 4;
  45.                                 }
  46.                                 speed = 1000 / ( 1.0 * 8.0 * sudu ) * 1000;
  47.                                 str_buff[0] = speed / 10000 % 10 + '0';
  48.                                 str_buff[1] = speed / 1000 % 10 + '0';
  49.                                 str_buff[3] = speed / 100 % 10 + '0';
  50.                                 str_buff[4] = speed % 10 + '0';
  51.                                 lcd( 0, 6, str_buff );
  52.                                 Set_Motor(kaiqi, fangxiang, sudu);
  53. //                                while( K1 == 0 );
  54.                         }
  55.                 }
  56.                 //////////////////////////////////////////////////////////////////////減速
  57.                 if( K2 == 0 )
  58.                 {
  59.                         delay( 50 );
  60.                         if( K2 == 0 )
  61.                         {
  62.                                 sudu++;
  63.                                 if( sudu >= 60000 )
  64.                                 {
  65.                                         sudu = 60000;
  66.                                 }
  67.                                 speed = 1000 / ( 1.0 * 8.0 * sudu ) * 1000;
  68.                                 str_buff[0] = speed / 10000 % 10 + '0';
  69.                                 str_buff[1] = speed / 1000 % 10 + '0';
  70.                                 str_buff[3] = speed / 100 % 10 + '0';
  71.                                 str_buff[4] = speed % 10 + '0';
  72.                                 lcd( 0, 6, str_buff );
  73.                                 Set_Motor(kaiqi, fangxiang, sudu);
  74. //                                while( K1 == 0 );
  75.                         }
  76.                 }
  77.                 //////////////////////////////////////////////////////////////////////正
  78.                 if( K3 == 0 )
  79.                 {
  80.                         delay( 50 );
  81.                         if( K3 == 0 )
  82.                         {
  83.                                 fangxiang = 1;
  84.                                 lcd( 1, 0, "Forward rotation" );
  85.                                 Set_Motor(kaiqi, fangxiang, sudu);
  86.                                 while( K3 == 0 );
  87.                         }
  88.                 }
  89.                 //////////////////////////////////////////////////////////////////////反
  90.                 if( K4 == 0 )
  91.                 {
  92.                         delay( 50 );
  93.                         if( K4 == 0 )
  94.                         {
  95.                                 fangxiang = 0;
  96.                                 lcd( 1, 0, "    reversal    " );
  97.                                 Set_Motor(kaiqi, fangxiang, sudu);
  98.                                 while( K4 == 0 );
  99.                         }
  100.                 }
  101.                 //////////////////////////////////////////////////////////////////////啟
  102.                 if( K5 == 0 )
  103.                 {
  104.                         delay( 50 );
  105.                         if( K5 == 0 )
  106.                         {
  107.                                 kaiqi = 1;
  108.                                 Set_Motor(kaiqi, fangxiang, sudu);
  109.                                 while( K6 == 0 );
  110.                         }
  111.                 }
  112.                 //////////////////////////////////////////////////////////////////////停
  113.                 if( K6 == 0 )
  114.                 {
  115.                         delay( 50 );
  116.                         if( K6 == 0 )
  117.                         {
  118.                                 kaiqi = 0;
  119.                                 Set_Motor(kaiqi, fangxiang, sudu);
  120.                                 while( K6 == 0 );
  121.                         }
  122.                 }
  123.         }
  124. }
所有資料51hei提供下載(Proteus仿真程序):
電機.rar (180.8 KB, 下載次數: 203)
ID:815667 發表于 2020-9-8 10:30 | 顯示全部樓層
提問步進電機速度是怎么算的
ID:815667 發表于 2020-9-8 10:50 | 顯示全部樓層
大佬,電機速度咋算的
ID:728202 發表于 2020-9-24 21:18 | 顯示全部樓層
proteus里的ULN2003A是不是有問題,為什么我一直無法用來驅動不進電機
ID:808093 發表于 2020-10-2 10:41 | 顯示全部樓層
為什么一開始就會轉?不應該按了開啟后才轉嗎?
ID:342954 發表于 2020-10-3 14:40 | 顯示全部樓層
這個只能6線電機,4線電機用不了
