查看: 2623|回復(fù): 3
請問單片機(jī)戶外運(yùn)動監(jiān)測系統(tǒng)程序如何設(shè)置脈搏進(jìn)行聲光報警?
回帖獎勵 50 黑幣 回復(fù)本帖可獲得 50 黑幣獎勵! 每人限 1 次
ID:792691 發(fā)表于 2020-7-8 22:08 | 顯示全部樓層 |閱讀模式
單片機(jī)源程序如下:
  • #include <reg52.h>
  • #include <intrins.h>
  • #include "LCD1602.h"
  • #include "DHT11.h"
  • #include "Delay.h"
  • sbit Xintiao =P1^0 ;                                         //脈搏檢測輸入端定義
  • sbit speaker =P2^1;                                                 //蜂鳴器引腳定義
  • sbit LED_RED = P1^2;                   //紅燈
  • sbit LED_GREED = P1^3;                   //綠燈
  • uchar xiaoting_num = 0;                  //心跳值
  • void delay5ms(void);   //誤差 0us
  • void Tim_Init();
  • uchar Xintiao_Change=0;           //
  • uint  Xintiao_Jishu;
  • uchar stop;
  • uchar View_Change;
  • uchar View_Data[3];
  • uchar View_L[3];
  • uchar View_H[3];
  • uchar Xintiao_H=100;        //脈搏上限
  • uchar Key_Change;
  • uchar Key_Value;                //按鍵鍵值
  • uchar View_Con;                        //設(shè)置的位(0正常工作,1設(shè)置上限,2設(shè)置下限)
  • void Dispaly_Xintiao(void);
  • void main( void )          //主函數(shù)
  • InitLcd();
  • Tim_Init();
  • ShtConnectReset();
  • LED_RED = 0;
  • LED_GREED = 0;
  • TR0=1;
  • TR1=1;                                  //打開定時器
  • while(1)                          //進(jìn)入循環(huán)
  •     Display_STH11();                  //顯示溫濕度
  •         Dispaly_Xintiao();                  //顯示心跳值
  •         if( Key_Value == 2 )           //心跳值設(shè)置 加
  •                 Xintiao_H++;
  •                 if( Xintiao_H >= 160 )
  •                         Xintiao_H = 160;
  •                 Key_Value = 10;
  •         if( Key_Value == 3 )                 //心跳值設(shè)置 減
  •                 Xintiao_H--;
  •                 if( Xintiao_H <= 60 )
  •                         Xintiao_H = 60;
  •                 Key_Value = 10;
  •         if( Xintiao_H > xiaoting_num )
  •                 LED_RED = 1;
  •                 LED_GREED = 0;
  •         else
  •                 LED_RED = 0;
  •                 LED_GREED = 1;
  • //心跳顯示
  • void Dispaly_Xintiao( void )
  •   LCD_WriteCom( 0x80 + 0x40 );
  •   LCD_WriteData( 'R' );
  •   LCD_WriteData( ':' );
  •   LCD_WriteData( View_Data[0] );
  •   LCD_WriteData( View_Data[1] );
  •   LCD_WriteData( View_Data[2] );
  •   xiaoting_num = View_Data[0]*100 + View_Data[1]*10 + View_Data[3];
  •   LCD_WriteData( ' ' );
  •   LCD_WriteData( 'S' );
  •   LCD_WriteData( Xintiao_H/100 + 0x30 );
  •   LCD_WriteData( Xintiao_H%100/10 + 0x30 );
  •   LCD_WriteData( Xintiao_H%10 + 0x30 );
  • void Time1() interrupt 3                //定時器1服務(wù)函數(shù)
  •         static uchar Key_Con,Xintiao_Con;
  •         TH1=0xd8;                   //10ms
  •         TL1=0xf0;                   //重新賦初值
  •         switch(Key_Con)   //無按鍵按下時此值為0
  •                 case 0:                   //每10ms掃描此處
  •                         if((P3&0x07)!=0x07)//掃描按鍵是否有按下
  •                                 Key_Con++;                  //有按下此值加1,值為1
  •                         break;
  •                 case 1:                                          //10ms后二次進(jìn)入中斷后掃描此處(Key_Con為1)
  •                         if((P3&0x07)!=0x07)//第二次進(jìn)入中斷時,按鍵仍然是按下(起到按鍵延時去抖的作用)
  •                                 Key_Con++;                  //變量加1,值為2
  •                                 switch(P3&0x07)  //判斷是哪個按鍵按下
  •                                         case 0x06:Key_Value=1;break;         //判斷好按鍵后將鍵值賦值給變量Key_Value
  •                                         case 0x05:Key_Value=2;break;
  •                                         case 0x03:Key_Value=3;break;
  •                         else        //如果10ms時沒有檢測到按鍵按下(按下時間過短)
  •                                 Key_Con=0;                                                 //變量清零,重新檢測按鍵
  •                         break;
  •                 case 2:        //20ms后檢測按鍵
  •                         if((P3&0x07)==0x07)                                 //檢測按鍵是否還是按下狀態(tài)
  •                                 Key_Change=1;                                         //有按鍵按下使能變量,(此變量為1時才會處理鍵值數(shù)據(jù))
  •                                 Key_Con=0;                                                //變量清零,等待下次有按鍵按下
  •                         break;
  •         switch (Xintiao_Con)//此處與上面按鍵的檢測類似
  •                 case 0:                         //默認(rèn)Xintiao_Con是為0的
  •                         if(!Xintiao)//每10ms(上面的定時器)檢測一次脈搏是否有信號
  •                                 Xintiao_Con++;//如果有信號,變量加一,程序就會往下走了
  •                         break;
  •                 case 1:
  •                         if(!Xintiao)           //每過10ms檢測一下信號是否還存在
  •                                 Xintiao_Con++;//存在就加一
  •                         else
  •                                 Xintiao_Con=0;//如果不存在了,檢測時間很短,說明檢測到的不是脈搏信號,可能是其他干擾,將變量清零,跳出此次檢測
  •                         break;
  •                 case 2:
  •                         if(!Xintiao)
  •                         else
  •                         break;
  •                 case 3:
  •                         if(!Xintiao)
  •                         else
  •                         break;
  •                 case 4:
  •                         if(Xintiao)//超過30ms一直有信號,判定此次是脈搏信號,執(zhí)行以下程序
  •                                 if(Xintiao_Change==1)//心率計原理為檢測兩次脈沖間隔時間計算心率,變量Xintiao_Change第一次脈沖時為0的,所有走下面的else,第二次走這里
  •                                         View_Data[0]=(6000/Xintiao_Jishu)/100+0x30;
  •                                         View_Data[1]=(6000/Xintiao_Jishu)%100/10+0x30;
  •                                         View_Data[2]=(6000/Xintiao_Jishu)%10+0x30;
  •                                         View_Change=1;           //計算出心率后啟動顯示
  •                                         Xintiao_Jishu=0;           //心跳計數(shù)清零
  •                                         Xintiao_Change=0;   //計算出心率后該變量清零,準(zhǔn)備下次檢測心率
  •                                         stop=0;                           //計算出心率后stop清零
  •                                    TR0=0;
  •                                 //   wendu=ReadTemperature();
  •                                 //   TR1=0;
  •                                 else//第一次脈沖時Xintiao_Change為0
  •                                         Xintiao_Jishu=0;        //脈沖計時變量清零,開始計時
  •                                         Xintiao_Change=1;//Xintiao_Change置1,準(zhǔn)備第二次檢測到脈沖時計算心率
  •                                         TR0=1;
  •                                 Xintiao_Con=0;        //清零,準(zhǔn)備檢測下一次脈沖
  •                                 break;
  • /**定時器T0工作函數(shù)**/
  • void Time0() interrupt 1
  • TH0=0xfc;                   //1ms
  • TL0=0x18;                   //重新賦初值
  • Xintiao_Jishu++;  //心跳計數(shù)加
  • if(Xintiao_Jishu==5000)//心跳計數(shù)大于5000
  •    Xintiao_Jishu=0;                //數(shù)據(jù)清零
  •    View_Change=1;                //顯示位置1
  •    Xintiao_Change=0;        //置零,準(zhǔn)備再次檢測
  •    stop=1;           //心跳計數(shù)超過5000后說明心率不正常或者沒有測出,stop置1
  •    speaker=1;  //關(guān)閉蜂鳴器
  • /**定時器初始化函數(shù)**/
  • void Tim_Init()
  • EA=1;                          //打開中斷總開關(guān)
  • ET0=1;                          //打開T0中斷允許開關(guān)
  • ET1=1;                          //打開T1中斷允許開關(guān)
  • TMOD=0x11;                  //設(shè)定定時器狀態(tài)
  • TH0=0xfc;                   //1ms
  • TL0=0x18;                   //賦初值
  • TH1=0xd8;                   //10ms
  • TL1=0xf0;                   //賦初值
戶外運(yùn)動.zip
1.05 MB, 下載次數(shù): 7
ID:584814 發(fā)表于 2020-7-9 08:04 | 顯示全部樓層
這個值戶外運(yùn)動監(jiān)測合適么 ?還有用DHT11、1602這類的不方便戶外罷
ID:792691 發(fā)表于 2020-7-9 08:23 來自觸屏版 | 顯示全部樓層
man1234567 發(fā)表于 2020-7-9 08:04
這個值戶外運(yùn)動監(jiān)測合適么 ?還有用DHT11、1602這類的不方便戶外 ...
其實(shí)就是把溫濕度和心跳值顯示在lcd屏幕上,心跳值超過限度報警
ID:235954 發(fā)表于 2020-7-12 07:06 | 顯示全部樓層
我用OLED屏幕寫過,檢測用心率檢測傳感器,溫濕度傳感器,讀數(shù)據(jù)再處理,打印到OLED屏幕上,數(shù)值超過設(shè)定值,會進(jìn)行聲光報警,語音報警的話,還有買個模塊,進(jìn)行搭建。
