查看: 2277|回復(fù): 3
求修改程序,大致上就是將八位數(shù)碼管改成這樣
ID:797839 發(fā)表于 2020-7-5 16:10 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
sbit S1=P3^4;
sbit dula=P2^6;
sbit wela=P2^7;
uchar k;
void delay_ms(uchar z)
        uchar i,j;
        for(i=z;i>0;i--)
                for(j=110;j>0;j--);
void keyscan()
        S1=1;
        if(S1==0)
                delay_ms(10);
                if(S1==0)
                        k++;
                        if(k==5)
                                k=1;
                        while(!S1);
void display()
        P0=0x36;
        dula=1;
        dula=0;
        if(k==1)
                P0=0xe7;
                wela=1;
                wela=0;
                delay_ms(10);
        if(k==2)
                P0=0xc3;
                wela=1;
                wela=0;
                delay_ms(10);
        if(k==3)
                P0=0x81;
                wela=1;
                wela=0;
                delay_ms(10);
        if(k==4)
                P0=0x00;
                wela=1;
                wela=0;
                delay_ms(10);
        uchar i,count;
        P0=0x00;
        dula=1;
        dula=0;
        P0=0xff;
        wela=1;
        wela=0;
                keyscan();
                display();
ID:332444 發(fā)表于 2020-7-5 17:29 | 顯示全部樓層
也就是一個(gè)數(shù)碼管顯示||這樣的符號(hào),送給數(shù)碼管的信號(hào)是固定的,只要控制點(diǎn)亮的個(gè)數(shù)就可以了?還是要顯示對(duì)稱的,若顯示對(duì)稱的則一個(gè)數(shù)碼管顯示右|一個(gè)顯示左|這樣的話送給數(shù)碼管的值就有變化了,不過也就是2個(gè)值而已。
ID:568565 發(fā)表于 2020-7-5 20:09 | 顯示全部樓層
ID:213173 發(fā)表于 2020-7-5 21:45 | 顯示全部樓層
  1. #include<reg51.h>
  3. sbit S1=P3^4;
  4. sbit dula=P2^6;
  5. sbit wela=P2^7;
  6. uchar code table[9][8]={
  7. 0x00,0x00,0x00,0x80,0x00,0x00,0x00,0x00,
  8. 0x00,0x00,0x00,0x06,0x30,0x00,0x00,0x00,
  9. 0x00,0x00,0x00,0x36,0x36,0x00,0x00,0x00,
  10. 0x00,0x00,0x06,0x36,0x36,0x30,0x00,0x00,
  11. 0x00,0x00,0x36,0x36,0x36,0x36,0x00,0x00,
  12. 0x00,0x06,0x36,0x36,0x36,0x36,0x30,0x00,
  13. 0x00,0x36,0x36,0x36,0x36,0x36,0x36,0x00,
  14. 0x06,0x36,0x36,0x36,0x36,0x36,0x36,0x30,
  15. 0x36,0x36,0x36,0x36,0x36,0x36,0x36,0x36};
  16. uchar code weia[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
  17. uchar i,j,k;
  18. void delay_ms(uchar z)
  19. {
  20.         uchar i,j;
  21.         for(i=z;i>0;i--)
  22.                 for(j=110;j>0;j--);
  23. }
  24. void keyscan()
  25. {
  26.         if(S1==0)
  27.         {
  28.                 if(++j>10)
  29.                         j=11;
  30.                 if(j==10)
  31.                 {
  32.                         k++;
  33.                         if(k>8)
  34.                                 k=0;
  35.                 }
  36.         }
  37.         else j=0;
  38. }
  39. void display()
  40. {
  41.         P0=0x00;dula=1;dula=0;
  42.         P0=weia[i];wela=1;wela=0;
  43.         P0=table[k][i];dula=1;dula=0;
  44.         i++;i%=8;
  45. }
  46. void main()
  47. {
  48.         while(1)
  49.         {
  50.                 keyscan();
  51.                 display();
  52.                 delay_ms(1);
  53.         }
  54. }
