只需一步,快速開(kāi)始
查看: 7016|回復(fù): 3
在keil里面運(yùn)行出現(xiàn)*** WARNING L1: UNRESOLVED EXTERNAL SYMBOL警告該怎么解決,....
ID:796820 發(fā)表于 2020-7-3 21:43 | 顯示全部樓層 |閱讀模式
#include ”regx51.h"
unsigned char a,b,c,d;
unsigned char code disaplay []= {0x3f, 0x06, 0x5b, 0x4f, 0x66,0x6d, 0x7d, 0x07, 0x7f, 0x6f} ;
long counter=0; //旋轉(zhuǎn)編碼 器的脈沖
long position=0; //旋轉(zhuǎn) 編碼器的當(dāng)前位置
long degree=0;
TMOD=0x06;
TH0=0xff;
TL0=0xff;
TH1= (65536-1000)/256;
TL1= (65536-1000)%256;
IE=0x0f;
EA = 1; //開(kāi)總中斷
r=0;
while(1)  //主程序循環(huán)顯示位置
a=degree%10;  //計(jì)算參數(shù)的個(gè)十百千位
b= (degree/10)%10; .
c= (degree/100)%10;
d= (degree/1000)%10;
p2_3=0;//顯示position值
p0=diaplay[a];
p2_3=1;
p2_2=0;
p0=diaplay[b];
p2_ 2=1;
p2_ 1=0;
p0=diaplay[c];
p2_1=1;
p2_0=0;
p0=diaplay[d];
p2_0=1;
void int0() interrupt 0   //A 相中斷
if(p2_7)position++;         //判斷2_7 為高則正向,為低則反向
else position;
counte++ ;      //累計(jì)脈沖
void int1()
interrupt 1   //Z相中斷
position=0;   //使位置參數(shù)置零
void tl_ () interrupt 2    //定時(shí)0. ls刷新一次轉(zhuǎn)速和角
//度參數(shù)
THO= (65536-1000) /256;
TL0= (65536-1000) %256;
r=600*counter/ 300;   //假設(shè)編碼器每轉(zhuǎn)300個(gè)脈沖
degree=1. 2*position; //把脈沖數(shù)轉(zhuǎn)換為 角度數(shù)
if(! degree)  //角度為負(fù)時(shí)加360度轉(zhuǎn)為正
degree+=360}
void t0_ () interrupt 3  //計(jì)數(shù)器T0中斷顯示速度
unsigned char i
i=100;
a=r%10;
b=(r/10)%10;
c=(r/100)%10;
d= (r/1000)%10;
while(i)
//中斷產(chǎn)生后循環(huán)100次顯示一段時(shí)間
p2_ 3=0;
p0=diaplay[a];
p2_ 3=1;
p2_ 2=0;
p0=diaplay[b];
p2_ 2=1;
p2_ 1=0;
p0=diap1ay[c];
p2_ 1=1;
p2_ _0=0;
p0=diaplay[d];
p2_ 0=1;
i-- ;
ID:57657 發(fā)表于 2020-7-3 23:30 | 顯示全部樓層
else position; 這行有問(wèn)題
ID:213173 發(fā)表于 2020-7-4 08:13 | 顯示全部樓層
樓主代碼錯(cuò)誤占一半以上,主要是書寫錯(cuò)誤:大小寫錯(cuò)誤、中英符號(hào)錯(cuò)誤、空格缺/多錯(cuò)誤,符號(hào)缺/多錯(cuò)誤及變量忘記賦值。
#include <AT89X51.H>
unsigned char a,b,c,d,r;
unsigned char code disaplay[]= {0x3f, 0x06, 0x5b, 0x4f, 0x66,0x6d, 0x7d, 0x07, 0x7f, 0x6f} ;
long degree=0;
        TMOD=0x06;
        TH0=0xff;
        TL0=0xff;
        IE=0x0f;
        EA = 1; //開(kāi)總中斷
        r=0;
                b= (degree/10)%10;
                c= (degree/100)%10;
                P2_3=0;//顯示position值
                P0=disaplay[a];
                P2_3=1;
                P2_2=0;
                P0=disaplay[b];
                P2_2=1;
                P2_1=0;
                P0=disaplay[c];
                P2_1=1;
                P2_0=0;
                P0=disaplay[d];
                P2_0=1;
        if(P2_7)position++;         //判斷2_7 為高則正向,為低則反向
        else position=0;/////
        counter++;      //累計(jì)脈沖
void int1() interrupt 1   //Z相中斷
void tl_() interrupt 2    //定時(shí)0. ls刷新一次轉(zhuǎn)速和角
{//度參數(shù)
        TH0=(65536-1000) /256;
        TL0=(65536-1000) %256;
        degree=1.2*position; //把脈沖數(shù)轉(zhuǎn)換為 角度數(shù)
        if(!degree)  //角度為負(fù)時(shí)加360度轉(zhuǎn)為正
        degree+=360;
void t0_() interrupt 3  //計(jì)數(shù)器T0中斷顯示速度
        unsigned char i;
        i=100;
        a=r%10;
        b=(r/10)%10;
        c=(r/100)%10;
        d=(r/1000)%10;
        while(i)
                P2_3=0;
                P0=disaplay[a];
                P2_3=1;
                P2_2=0;
                P0=disaplay[b];
                P2_2=1;
                P2_1=0;
                P0=disaplay[c];
                P2_1=1;
                P2_0=0;
                P0=disaplay[d];
                P2_0=1;
                i-- ;
ID:452950 發(fā)表于 2020-7-4 10:44 | 顯示全部樓層
void main()后面少一個(gè)大括號(hào){
