TFT2.4寸彩屏是一款可以顯示字符、圖形及圖片的顯示屏,它與外部通訊是提供SPI接口。 SC95F8616核心板可以通過GPIO口來(lái)模擬SPI接口來(lái)驅(qū)動(dòng)TFT彩屏,為此所定義相關(guān)引腳輸出高低電平的語(yǔ)句如下: #define LCD_LED_High() GPIO_WriteHigh(GPIO2,GPIO_PIN_7); // P27
#define LCD_SCK_High() GPIO_WriteHigh(GPIO2,GPIO_PIN_4); // P24 #define LCD_SCK_Low() GPIO_WriteLow(GPIO2,GPIO_PIN_4); #define LCD_SDI_High() GPIO_WriteHigh(GPIO2,GPIO_PIN_5); // P25 #define LCD_SDI_Low() GPIO_WriteLow(GPIO2,GPIO_PIN_5); #define LCD_DC_High() GPIO_WriteHigh(GPIO2,GPIO_PIN_2); //P22 #define LCD_DC_Low() GPIO_WriteLow(GPIO2,GPIO_PIN_2); #define LCD_REST_High() GPIO_WriteHigh(GPIO2,GPIO_PIN_6); //P26 #define LCD_REST_Low() GPIO_WriteLow(GPIO2,GPIO_PIN_6); #define LCD_CS_High() GPIO_WriteHigh(GPIO2,GPIO_PIN_3); //P23 #define LCD_CS_Low() GPIO_WriteLow(GPIO2,GPIO_PIN_3);
配置相關(guān)引腳為輸出功能的函數(shù)為: - void GPIO_Configuration(void)
- GPIO_Init(GPIO2,GPIO_PIN_7,GPIO_MODE_OUT_PP);
- GPIO_Init(GPIO2,GPIO_PIN_6,GPIO_MODE_OUT_PP);
- GPIO_Init(GPIO2,GPIO_PIN_5,GPIO_MODE_OUT_PP);
- GPIO_Init(GPIO2,GPIO_PIN_4,GPIO_MODE_OUT_PP);
- GPIO_Init(GPIO2,GPIO_PIN_3,GPIO_MODE_OUT_PP);
- GPIO_Init(GPIO2,GPIO_PIN_2,GPIO_MODE_OUT_PP);
- LCD_LED_High();
TFT 彩屏的初始化函數(shù)為:- void Lcd_Init(void)
- LCD_REST_Low();
- mdelay(20);
- LCD_REST_High();
- mdelay(20);
- LCD_CS_Low();
- LCD_WR_REG(0xCB);
- LCD_WR_DATA8(0x39);
- LCD_WR_DATA8(0x2C);
- LCD_WR_DATA8(0x00);
- LCD_WR_DATA8(0x34);
- LCD_WR_DATA8(0x02);
- LCD_WR_REG(0xCF);
- LCD_WR_DATA8(0XC1);
- LCD_WR_DATA8(0X30);
- LCD_WR_REG(0xE8);
- LCD_WR_DATA8(0x85);
- LCD_WR_DATA8(0x78);
- LCD_WR_REG(0xEA);
- LCD_WR_REG(0xED);
- LCD_WR_DATA8(0x64);
- LCD_WR_DATA8(0x03);
- LCD_WR_DATA8(0X12);
- LCD_WR_DATA8(0X81);
- LCD_WR_REG(0xF7);
- LCD_WR_DATA8(0x20);
- LCD_WR_REG(0xC0); //Power control
- LCD_WR_DATA8(0x23); //VRH[5:0]
- LCD_WR_REG(0xC1); //Power control
- LCD_WR_DATA8(0x10); //SAP[2:0];BT[3:0]
- LCD_WR_REG(0xC5); //VCM control
- LCD_WR_DATA8(0x3e);
- LCD_WR_DATA8(0x28);
- LCD_WR_REG(0xC7); // VCM control2
- LCD_WR_DATA8(0x86); // --
- LCD_WR_REG(0x36); // Memory Access Control
- LCD_WR_DATA8(0x48); // C8
- LCD_WR_REG(0x3A);
- LCD_WR_DATA8(0x55);
- LCD_WR_REG(0xB1);
- LCD_WR_DATA8(0x18);
- LCD_WR_REG(0xB6); // Display Function Control
- LCD_WR_DATA8(0x08);
- LCD_WR_DATA8(0x82);
- LCD_WR_DATA8(0x27);
- LCD_WR_REG(0xF2); // 3Gamma Function Disable
- LCD_WR_REG(0x26); // Gamma curve selected
- LCD_WR_DATA8(0x01);
- LCD_WR_REG(0xE0); // Set Gamma
- LCD_WR_DATA8(0x0F);
- LCD_WR_DATA8(0x31);
- LCD_WR_DATA8(0x2B);
- LCD_WR_DATA8(0x0C);
- LCD_WR_DATA8(0x0E);
- LCD_WR_DATA8(0x4E);
- LCD_WR_DATA8(0xF1);
- LCD_WR_DATA8(0x37);
- LCD_WR_DATA8(0x07);
- LCD_WR_DATA8(0x09);
- LCD_WR_REG(0XE1); //Set Gamma
- LCD_WR_DATA8(0x14);
- LCD_WR_DATA8(0x11);
- LCD_WR_DATA8(0xC1);
- LCD_WR_DATA8(0x36);
- LCD_WR_REG(0x11); //Exit Sleep
- mdelay(120);
- LCD_WR_REG(0x29); //Display on
- LCD_WR_REG(0x2c);
實(shí)現(xiàn)色彩擦除屏幕的函數(shù)為:- void LCD_Clear(uint16_t Color)
- char VH,VL;
- uint16_t i,j;
- VH=Color>>8;
- VL=Color;
- Address_set(0,0,LCD_W-1,LCD_H-1);
- for(i=0;i<LCD_W;i++)
- for (j=0;j<LCD_H;j++)
- LCD_WR_DATA8(VH);
- LCD_WR_DATA8(VL);
實(shí)現(xiàn)顯示效果的函數(shù)為:- void xianshi()
- LCD_Clear(RED);
- BACK_COLOR=RED;
- POINT_COLOR=WHITE;
- LCD_ShowString(20,80,160,16,16,"SC95F8616 TEST");
- LCD_ShowString(20,120,200,16,16,"2.4 SPI_TFT 240*320");
- LCD_ShowString(20,240,160,16,16,"jinglxixi ");
- LCD_ShowString(20,280,200,16,16,"2020.6.22 ");
運(yùn)行的主程序?yàn)椋?/font>- void main(void)
- mdelay(200);
- GPIO_Configuration();
- Lcd_Init();
- LCD_Clear(RED);
- xianshi();
- while(1);
TFT2.4彩屏顯示效果
