查看: 7654|回復: 8
請問大神們為什么最后一行顯示missing return value 怎么修改
ID:793358 發表于 2020-6-29 23:43 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
                    /*12Mhz晶振工作*/
#include <reg51.h>
sbit voice=P2^3;
uchar code sound[]={0xff,
                    0x2b,0x30,0x30,0x10,0x2b,0x30,0x30,0x10,0x2b,0x20,0x26,0x20,0x20,0x20,
                    0x26,0x20,0x2b,0x30,0x30,0x10,0x2b,0x30,0x30,0x10,0x2b,0x10,0x26,0x10,
                    0x2b,0x10,0x30,0x10,0x40,0x20,0x40,0x20,0x2b,0x30,0x30,0x10,0x2b,0x30,
                    0x30,0x10,0x2b,0x20,0x26,0x20,0x20,0x20,0x26,0x20,0x2b,0x30,0x26,0x10,
                    0x2b,0x20,0x30,0x20,0x2b,0x20,0x2b,0x20,0xff,0x20,0xff,0x20,0x2b,0x30,
                                        0x30,0x10,0x2b,0x30,0x30,0x10,0x2b,0x20,0x26,0x20,0x20,0x20,0x26,0x20,
                                        0x2b,0x30,0x26,0x10,0x2b,0x20,0x30,0x20,0x39,0x20,0x39,0x20,0x26,0x10,
                                        0x2b,0x10,0x30,0x10,0x2b,0x10,0x30,0x20,0x30,0x20,0x26,0x10,0x2b,0x10,
                                        0x30,0x10,0x2b,0x10,0x30,0x30,0x20,0x10,0x26,0x10,0x2b,0x10,0x30,0x10,
                                        0x2b,0x10,0x30,0x20,0x30,0x20,0x30,0x20,0x2b,0x20,0x26,0x20,0x30,0x20,0x1c,0x20,0x20,0x10,0x1c,0x10,
                    0x1c,0x30,0x30,0x10,0x19,0x20,0x1c,0x10,0x19,0x10,0x19,0x20,0x19,0x20,
                    0x1c,0x10,0x19,0x10,0x19,0x20,0x26,0x20,0x18,0x10,0x15,0x10,0x18,0x10,
                    0x19,0x10,0x1c,0x20,0x20,0x20,0x1c,0x20,0x20,0x10,0x1c,0x10,0x1c,0x10,
                    0x20,0x10,0x1c,0x10,0x20,0x10,0x1c,0x20,0x20,0x10,0x2b,0x10,0x2b,0x10,
                    0x20,0x20,0x20,0x10,0x26,0x20,0x26,0x20,0x30,0x20,0x2b,0x20,0x26,0x20,
                    0x30,0x20,0x1c,0x20,0x20,0x10,0x1c,0x10,0x1c,0x30,0x30,0x10,0x19,0x20,
                    0x1c,0x10,0x19,0x10,0x19,0x20,0x19,0x20,0x1c,0x10,0x19,0x10,0x19,0x20,
                    0x26,0x20,0x18,0x10,0x15,0x10,0x18,0x10,0x19,0x10,0x1c,0x20,0x20,0x20,
                    0x1c,0x20,0x13,0x10,0x13,0x10,0x13,0x20,0x20,0x20,0x1c,0x20,0x13,0x10,
                    0x13,0x10,0x13,0x10,0x20,0x20,0x1c,0x10,0x1c,0x20,0x1c,0x20,0x1c,0x20,
                    0x1c,0x20,0xff,0x20,0xff,0x20,  0x18,0x20,0x15,0x20,0x13,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,0x0e,0x10,
                    0x10,0x10,0x10,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,0x19,0x10,0x18,0x10,
                    0x18,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,
                    0x0e,0x10,0x10,0x10,0x10,0x10,0x13,0x30,0x15,0x20,0x18,0x10,0x1c,0x10,
                    0x1c,0x10,0x18,0x20,0x1c,0x10,0x15,0x10,0x18,0x10,0x1c,0x20,0x1c,0x10,
                    0x18,0x30,0x13,0x20,0x13,0x20,0x13,0x10,0x12,0x10,0x13,0x20,0x13,0x10,
                    0x15,0x20,0xff,0x20,0xff,0x20,0x18,0x20,0x15,0x20,0x13,0x20,0x0e,0x10,0x10,0x10,
                    0x10,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,
                    0x15,0x20,0x13,0x20,0x0e,0x10,0x10,0x10,0x10,0x20,0x0e,0x10,0x10,0x10,
                    0x10,0x20,0x0e,0x10,0x10,0x10,0x10,0x10,0x13,0x30,0x15,0x20,0x18,0x10,
                    0x1c,0x10,0x1c,0x10,0x13,0x30,0x15,0x20,0x18,0x10,0x1c,0x10,0x1c,0x10,
                    0x18,0x30,0x18,0x20,0x18,0x20,0xff,0x20,0xff,0x20,0x1c,0x10,0x13,0x10,
                    0x15,0x20,0x18,0x10,0x1c,0x10,0x1c,0x10,0x13,0x30,0x15,0x20,0x18,0x10,
                    0x1c,0x10,0x1c,0x10,0x18,0x30,0x18,0x20,0x18,0x20,0x18,0x20,0x18,0x20,0x00,
uchar zdjs=0, jp;
del(yj);
void main(void)
      uint dpjs=0;
      uchar yj;
      TMOD=0x01,IE=0x82;
      TH0=0xd8, TL0=0xef;
   TR0=1;
      zdjs=0;
      dpjs++; yj=sound[dpjs];
     dpjs++; jp=sound[dpjs];
   while(zdjs!=jp)
      if(yj!=0xff)
             if(yj!=0)
             voice=!voice;
                 del(yj);
          dpjs=0;
                      break;
        voice=0;
                 del(jp);
   time0() interrupt 1  using 1
         TH0=0xd8, TL0=0xef;
         zdjs++;
del(yj)
      uchar yj2=2;
       while(yj!=0)
               while(yj2!=0)
                     yj2--;
                  yj2=2;
             yj--;
ID:793358 發表于 2020-6-30 00:25 | 只看該作者
剛進這個網站,也不知道這樣合不合規
ID:584814 發表于 2020-6-30 07:54 | 只看該作者
void main(void) 改成 int main(void) 或 main(void) 試試
ID:592807 發表于 2020-6-30 08:25 | 只看該作者
錯誤標記在哪?missing return vaul一般是指函數忘記加return值了
ID:658665 發表于 2020-6-30 08:38 | 只看該作者
下次發帖的時候最好把代碼縮進搞一下,這個程序的問題是del(yj)前面沒有加void,只要改為void del(yj)就行了,下面是你的程序
project.zip
19.3 KB, 下載次數: 8
ID:744327 發表于 2020-6-30 08:39 | 只看該作者
直接修改return value的值,最后一行就有變化了。
ID:784974 發表于 2020-6-30 08:57 | 只看該作者
這個只是警告,和錯誤不同,錯誤的話不能生成HEX文件,警告可以生成HEX文件。
然后就是看你需要返回什么值,可以在del(yj)定義的函數最后面加一個return(),括號里看你需要添加返回什么吧。
希望有所幫助,如有錯誤也請指正,謝謝
ID:452950 發表于 2020-6-30 10:26 | 只看該作者
void del(yj)
      uchar yj2=2;
       while(yj!=0)
               while(yj2!=0)
                     yj2--;
                  yj2=2;
             yj--;
這個應該是延時函數,定義函數名前要加void
ID:793358 發表于 2020-6-30 11:11 來自觸屏版 | 只看該作者
黃youhui 發表于 2020-6-30 08:25
最后一行
