查看: 2496|回復(fù): 12
為什么這個代碼按鍵會有延時就是調(diào)時的時候會閃,但是按鍵要按2到3下才有響應(yīng)...
ID:787264 發(fā)表于 2020-6-26 23:59 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
   #include<reg51.h>
sbit LED=P3^1;
sbit BEEP=P3^2;
sbit PWM=P3^0;
sbit INA=P2^4;
sbit INB=P2^5;
sbit INC=P2^6;
sbit IND=P2^7;
unsigned char code led_mod[10]={0x3f,0x06,0x5b,0x4f,
          0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char code led_sel[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char DisplayCode[8]={0x00,0x00,0x00,0x3f,0x3f,0x40,0x3f,0x3f};
unsigned char code f_rotation[8]={0xfe,0xfd,0xfb,0xf7,0x7f,0xbf,0xdf,0xef};
unsigned char code b_rotation[4]={0X6F,0x3F,0x9F,0xCF }; typedef unsigned int u16; typedef unsigned char u8;
  bit king_flag=0 ;
bit Time_adjust=0;////????????????????????????
bit timer_1sec_flag=0;//???????????1???????????
bit alarm_flag=0;//?????????????????????????????
bit alarm_fen_flag=0;
bit alarm_h_flag=0;
bit led_flag=0;//????????????LED??10????
unsigned int motor=32;//?????????????????
bit dir=1;//???崠????????????????????????
bit r_run=0;    bit timer_1min_flag=0;     bit flag=0;
unsigned char min=0;
unsigned char h=0;               u8 Motor_Step=0;
unsigned char alarm_min=10;//????????
unsigned char alarm_h=0;//?????С?
unsigned char key_value;
unsigned char led_timer_counter;        double count=2;unsigned char ID;unsigned char kind;
sbit K1=P1^0;//????1
sbit K2=P1^1;
sbit K3=P1^2;
sbit K4=P1^3;
sbit K5=P1^4;
unsigned char  pre_sta[5]={1,1,1,1,1};//??????????????I/O????λ
unsigned char cur_sta[5]={1,1,1,1,1};//??????????????I/O????λ
unsigned char key_buff[5]={0xff,0xff,0xff,0xff,0xff};
void delay(unsigned int z)//??????
  unsigned int i,j;
for(i=0;i<z;i++)
  for(j=0;j<125;j++);
void led7seg_scan()//??????????
unsigned char i;
    for(i=0;i<4;i++)
   P2=led_sel[i];//λ????????????λ????????
   P0=DisplayCode[i];//????????????????????
   delay(1);//delay 1ms
   P0=0x00;//?????????
void Motor_Delay1ms(u16 c)   //??? 0us
for (; c>0; c--)
//   for (b=199;b>0;b--)
     void Motor_Run(bit dir)
      if(r_run){
    switch(Motor_Step)
      case 0: INA=1;INB=0;INC=0;IND=0;Motor_Step++;delay(12);break;
      case 1: INA=1;INB=0;INC=1;IND=0;Motor_Step++;delay(12);break;
      case 2: INA=0;INB=0;INC=1;IND=0;Motor_Step++;delay(12);break;
      case 3: INA=0;INB=1;INC=1;IND=0;Motor_Step++;delay(12);break;
      case 4: INA=0;INB=1;INC=0;IND=0;Motor_Step++;delay(12);break;
      case 5: INA=0;INB=1;INC=0;IND=0;Motor_Step++;delay(12);break;
      case 6: INA=0;INB=1;INC=1;IND=0;Motor_Step++;delay(12);break;
      case 7: INA=0;INB=0;INC=1;IND=0;Motor_Step++;delay(12);break;
      case 8: INA=1;INB=0;INC=0;IND=0;Motor_Step=0;delay(12);break;
     /* case 9: INA=0;INB=1;INC=1;IND=0;if(dir)Motor_Step++;else Motor_Step--;Motor_Delay1ms(20);break;
      case 10: INA=0;INB=0;INC=1;IND=0;if(dir)Motor_Step++;else Motor_Step--;Motor_Delay1ms(20);break;
      case 11: INA=0;INB=1;INC=1;IND=0;if(dir)Motor_Step++;else Motor_Step--;Motor_Delay1ms(20);break;
      case 12: INA=0;INB=1;INC=0;IND=0;if(dir)Motor_Step++;else Motor_Step--;Motor_Delay1ms(20);break;
      case 13: INA=0;INB=1;INC=0;IND=1;if(dir)Motor_Step++;else Motor_Step--;Motor_Delay1ms(20);break;
      case 14: INA=0;INB=0;INC=0;IND=1;if(dir)Motor_Step=0;else Motor_Step--;Motor_Delay1ms(20);break;   */
  } else INA=0;INB=0;INC=0;IND=0;
     delay(2);
void   timer0_init()
  TR0=1;//???????0
TMOD=0x11;//????????0??1????????????????????????1
EA=1;//???ж????ж?
ET0=1;//???????0???ж?
ET1=1;//???????1???ж?
TR1=0;//???????1
    TH0=(65536-4000)/256;//?????0????????
TL0=(65536-4000)%256;
  TH1=(65536-4000)/256; //?????1????????
TL1=(65536-4000)%256;
void key_action(unsigned char key_value)//???????????
if(key_value==1)
delay(100);//?????????????
if(key_value==1) {
  LED=~LED;  king_flag=~king_flag;
  TR1=~TR1; delay(100);
            else if(key_value==2)//?????????????
{        if(king_flag)
    {  if(K2==0)  {   delay(2); //????????????????????ж???????
  if(K2==0)  {   count+=1; //?????μ???????????0.5
     if(count>=8)     //???????????
   {  count=2; }  } while(!K1);  }  } }
else if(key_value==3 )//??3??????
{    if(king_flag) ID++;if(ID==3){
ID=0;
//Motor_Run(dir);               }
  else if(key_value==4)//????4????
{ if(king_flag){   kind++;if(kind==4){
kind=0; }    }
/* else if(key_value==5)
      delay(100);
  { if(key_value==5)if(king_flag) {
    if(alarm_fen_flag)//???????????????£??????????????
   alarm_min++;
    if(alarm_min==60) alarm_min=0;
   DisplayCode[3]=led_mod[alarm_min%10];
   DisplayCode[2]=led_mod[alarm_min/10];
  else  if(alarm_h_flag)//???????????????£??????????????
   alarm_h++;
    if(alarm_h==24) alarm_h=0;
   DisplayCode[1]=led_mod[alarm_h%10];
   DisplayCode[0]=led_mod[alarm_h/10];
} unsigned char key_scan(void)//???????
unsigned char i;
unsigned char key_value=0;
for(i=0;i<5;i++)
if(cur_sta[i]!=pre_sta[i])//??????????????????
   if(pre_sta[i]==1)//???????????,????????
     key_value=i+1;
    pre_sta[i]=cur_sta[i];//??????????????
  return (key_value);//?????????????????????????????????
void cur_sta_update()//???????????
unsigned char i;
  key_buff[0]=(key_buff[0]<<1)|K1;//??????????K1?????key_buff[0]?е?????λ
key_buff[1]=(key_buff[1]<<1)|K2;//??????????K2?????key_buff[1]?е?????λ
key_buff[2]=(key_buff[2]<<1)|K3;//??????????K3?????key_buff[2]?е?????λ
key_buff[3]=(key_buff[3]<<1)|K4;//??????????K4?????key_buff[3]?е?????λ
key_buff[4]=(key_buff[4]<<1)|K5;//??????????K4?????key_buff[3]?е?????λ
for(i=0;i<5;i++)
  if((key_buff[i]&0x0f)==0x00)//???????4?γ???????
   cur_sta[i]=0;//????μ????0
  else if((key_buff[i]&0x0f)==0x0f)//???????4?γ???????
  cur_sta[i]=1;//????μ????1
void DisplayCode_update_time()//??????????????
if(Time_adjust==0)//?????δ???????????£??????1????У????????????С?????
   if(timer_1sec_flag)//1 sec ?????
   timer_1sec_flag=0;
    min++;
      if(min==60)
      min=0;
      h++;
        if(h==24)
        h=0;
   if(alarm_flag==0)//????δ???????????????????????????
   {DisplayCode[3]=led_mod[min%10];
   DisplayCode[2]=led_mod[min/10];
   DisplayCode[1]=led_mod[h%10];
   DisplayCode[0]=led_mod[h/10];
   } delay(1);
} void DisplayCode_update_time25()//??????????????
if(flag)//?????δ???????????£??????1????У????????????С?????
   if(timer_1min_flag)//1 sec ?????
   timer_1min_flag=0;
    alarm_min--;
      if(alarm_min==0)
     {    alarm_min=10;
    kind=0;  ID=0;LED=~LED;PWM=0;TR1=~TR1;
{     unsigned char i,j;
    unsigned char k=0;
unsigned char key_value;LED=0;r_run=0;dir=0;
timer0_init(); IT0=1;
  led7seg_scan();
  key_value=key_scan();
  key_action(key_value);
  DisplayCode_update_time();
  DisplayCode_update_time25();
      if(key_value!=0)
  {    delay(2);
  while(key_value==0);
  if(key_value!=0)
  for(i=10;i>0;i--){
  for(j=5;j>0;j--){
  BEEP=0;
  delay(1);
  BEEP=1;
  delay(1);
  BEEP=1;
   switch(ID)
         case 0: r_run=0; break;    //??/??
         case 1: r_run=1; break;    //???
        if(r_run) Motor_Run(dir);
   switch(kind)
         case 0: alarm_flag=0; break;    //??/??
         case 1: alarm_flag=1;alarm_fen_flag=1; break;    //???
         case 2:  alarm_flag=1;alarm_h_flag=1;alarm_fen_flag=0;DisplayCode[3]=led_mod[alarm_min%10];
    DisplayCode[2]=led_mod[alarm_min/10];      break;  //???
         case 3: alarm_flag=1;alarm_h_flag=0;alarm_fen_flag=0;flag=1;DisplayCode[1]=led_mod[alarm_h%10];
    DisplayCode[0]=led_mod[alarm_h/10];  DisplayCode[3]=led_mod[alarm_min%10];
  if(key_value==5)
      delay(100);if(key_value==5){if(king_flag) {
   alarm_min++;
   DisplayCode[2]=led_mod[alarm_min/10];while(key_value!=5);}
   alarm_h++;
   DisplayCode[0]=led_mod[alarm_h/10];}}delay(100); while(key_value!=5);} }
void timer0_4ms() interrupt 1
static unsigned char timer_count=0; static unsigned char count=0;static unsigned char count_timer=0;static unsigned char timer_count12=0;
    timer_count++;
if(timer_count==250)//1 sec
    timer_count=0;
  timer_1sec_flag=1;
    if(alarm_flag)
if(alarm_fen_flag){if(count_timer==100)  DisplayCode[3]=led_mod[alarm_min%10];
  if(count_timer==100)  DisplayCode[2]=led_mod[alarm_min/10];
    count_timer++;
    if(count_timer==170){  count_timer=0;
   DisplayCode[3]=0x00;
    DisplayCode[2]=0x00;
  }}if(alarm_h_flag)//???????????????£??????????????
  {if(count==100)  DisplayCode[1]=led_mod[alarm_h%10];
  if(count==100)  DisplayCode[0]=led_mod[alarm_h/10];
    count++;
    if(count==170){  count=0;
   DisplayCode[1]=0x00;
    DisplayCode[0]=0x00;
  }  if(flag)
  timer_count12++;
  if(timer_count12==250)
  timer_count=0;
  timer_1min_flag=1;
  cur_sta_update();  {
}void timer1_1ms() interrupt 3
  static unsigned char led_timer_counter=0;
     TR1=0;
          TR1=1;
      led_timer_counter++;
  if(led_timer_counter<count)   //count?????
PWM=1;    //???????
PWM=0;
  if(led_timer_counter>8)
ID:787264 發(fā)表于 2020-6-27 00:21 | 只看該作者
請大神們給點思路
ID:394424 發(fā)表于 2020-6-27 08:16 | 只看該作者
按鍵掃描沒那么復(fù)雜 你需要做處理 比如說按下去觸發(fā)   只觸發(fā)一次
ID:94031 發(fā)表于 2020-6-27 09:23 | 只看該作者
中斷里不應(yīng)該處理那么多事情,中斷只設(shè)標(biāo)志,處理在外邊。
ID:787264 發(fā)表于 2020-6-27 12:17 | 只看該作者
可是我還像這樣子設(shè)是按下去觸發(fā)一次
ID:787264 發(fā)表于 2020-6-27 13:57 | 只看該作者
可是去掉了還是會延遲
ID:110606 發(fā)表于 2020-6-27 17:04 | 只看該作者
我建議你這樣做,不一定管用,你可以試試
ID:110606 發(fā)表于 2020-6-27 17:09 | 只看該作者
不要把按鍵檢測和按鍵動作函數(shù)放在while循環(huán)中,因為這個時間是不一定的,你這樣做很有可能是導(dǎo)致按鍵不相應(yīng),while中做定時器時間判斷,比如1S檢測一次按鍵是否按下,同時進(jìn)行按鍵動作相應(yīng),這樣不好用的話,在這個時間判斷里面做一個led燈閃爍的語句,看看是否什么地方延時過長,導(dǎo)致while循環(huán)時間過長,或者把按鍵檢測函數(shù)扔到定時器里面(正常不能這樣寫,為了找出問提),你可以這樣試試
ID:787264 發(fā)表于 2020-6-28 03:19 | 只看該作者
青龍書生 發(fā)表于 2020-6-27 17:09
不要把按鍵檢測和按鍵動作函數(shù)放在while循環(huán)中,因為這個時間是不一定的,你這樣做很有可能是導(dǎo)致按鍵不相 ...
謝謝大神,我把按鍵檢測函數(shù)放進(jìn)去就不會有延時了謝謝
ID:787264 發(fā)表于 2020-6-28 03:27 | 只看該作者
謝謝大神,我把按鍵檢測放到定時器里就不會延時了
ID:636538 發(fā)表于 2020-6-28 09:20 | 只看該作者
我自己也菜,每次看到上面這種代碼,就沒有看下去的欲望,太亂
ID:787264 發(fā)表于 2020-6-28 19:27 | 只看該作者
怎么刪帖子
ID:787264 發(fā)表于 2020-6-29 01:54 | 只看該作者
能不能看看怎么實現(xiàn)按鍵長按加1
