查看: 2067|回復: 1
請問下我16*16點陣顯示一個漢字的程序有問題嗎?
ID:710261 發(fā)表于 2020-6-26 14:05 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
50黑幣
1個74154驅動陰極,2個74595驅動陽級,為什么我仿真出來的“二”這個字的上下兩橫反復跳?速度一會快一會兒慢程序如下:
#include <reg52.h>
//#include <intrins.h>
sbit DS=P2^4;
sbit SH=P2^5;
sbit ST=P2^6;
sbit A_port=P1^0;
sbit B_port=P1^1;
sbit C_port=P1^2;
sbit D_port=P1^3;
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xF8,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xC0,0x01,0xFF,0xFF,
*///二
uchar dian_H[]={
0xF8,0xFF,0xFF,0xFF,
0xFF,0xFF,0xC0,0xFF,
0xFF,0xFF,0xFF,0xFF
};//列碼高8位
uchar dian_L[]={
0xFF,0xFF,0x01,0xFF,
0xFF,0xFF,0xFF,0xFF
};//列碼低8位
/*列選函數*/
void Sendbyte(uint dat1,uint dat2)//dat1為列碼低八位,dat2為高八位
        uchar i;
        ST=0;
                        for(i=0;i<8;i++)//將列碼低八位發(fā)送至595的移位寄存器
                                SH=0;
                                        if(dat1&0x01)
                                                DS=1;
                                                DS=0;//取列碼的最低位,若為1則DS輸入1,若為0則DS輸入0
                                SH=1;
                                dat1=dat1>>1;
                        for(i=0;i<8;i++)//將列碼高八位發(fā)送至595的移位寄存器
                                SH=0;
                                        if(dat2&0x01)
                                                DS=1;
                                                DS=0;
                                SH=1;
                                dat2=dat2>>1;
        ST=1;
/*行選函數*/
void HX(uchar hang)
        switch (hang)
  case 0:
   D_port = 0; C_port = 0; B_port = 0; A_port = 0;//選第1行
   break;
  case 1:
   D_port = 0; C_port = 0; B_port = 0; A_port = 1;//選第2行
   break;
  case 2:
   D_port = 0; C_port = 0; B_port = 1; A_port = 0;//選第3行
   break;
  case 3:
   D_port = 0; C_port = 0; B_port = 1; A_port = 1;//選第4行
   break;
  case 4:
   D_port = 0; C_port = 1; B_port = 0; A_port = 0;//選第5行
   break;
  case 5:
   D_port = 0; C_port = 1; B_port = 0; A_port = 1;//選第6行
   break;
  case 6:
   D_port = 0; C_port = 1; B_port = 1; A_port = 0;//選第7行
   break;
  case 7:
   D_port = 0; C_port = 1; B_port = 1; A_port = 1;//選第8行
   break;
  case 8:
   D_port = 1; C_port = 0; B_port = 0; A_port = 0;//選第9行
   break;
  case 9:
   D_port = 1; C_port = 0; B_port = 0; A_port = 1;//選第10行
   break;
  case 10:
   D_port = 1; C_port = 0; B_port = 1; A_port = 0;//選第11行
   break;
  case 11:
   D_port = 1; C_port = 0; B_port = 1; A_port = 1;//選第12行
   break;
  case 12:
   D_port = 1; C_port = 1; B_port = 0; A_port = 0;//選第13行
   break;
  case 13:
   D_port = 1; C_port = 1; B_port = 0; A_port = 1;//選第14行
   break;
  case 14:
   D_port = 1; C_port = 1; B_port = 1; A_port = 0;//選第15行
   break;
  case 15:
   D_port = 1; C_port = 1; B_port = 1; A_port = 1;//選第16行
   break;
/*主函數*/
  uchar j;
                for(j=0;j<16;j++)
                        Sendbyte(dian_L[j],dian_H[j]);
                        HX(j);
ID:710261 發(fā)表于 2020-6-26 14:33 | 只看該作者
是不是頻率的問題啊嗎,怎么通過編程設置他動態(tài)掃描的頻率啊
