查看: 2722|回復: 0
1602字符液晶工作于8位模式直接驅動顯示Proteus仿真+單片機程序
1602字符液晶工作于8位模式直接驅動顯示,有仿真文件,附件找
  1. //-----------------------------------------------------------------
  2. //  名稱: 1602字符液晶工作于8位模式直接驅動顯示
  3. //-----------------------------------------------------------------
  4. //  說明: 本例液晶實現了四項演示功能,分別為水平滾動,帶光標顯示隨機
  5. //        算術式,全碼表字符顯示,CGRAM自定義字符顯示.
  6. //
  7. //-----------------------------------------------------------------
  8. #include <reg51.h>
  9. #include <string.h>
  10. #include <stdlib.h>
  11. #include <stdio.h>
  12. #define INT8U  unsigned char
  13. #define INT16U unsigned int
  14. sbit SW1 = P3^0;                //水平水平滾動顯示
  15. sbit SW2 = P3^1;                //帶光標顯示隨機算術式
  16. sbit SW3 = P3^2;                //全碼表字符顯示
  17. sbit SW4 = P3^3;                //CGRAM自定義字符顯示
  18. INT8U code msg[] =                //待滾動顯示的字符串(字符串最前面加了16個空格)
  19. "                you are going to spend even more time working on the schematic ?";
  20. //-----------------------------------------------------------------
  21. extern delay_ms(INT16U x);
  22. extern void Initialize_LCD();
  23. extern void Write_LCD_Data(INT8U dat);
  24. extern void Write_LCD_Command(INT8U cmd);
  25. extern void Busy_Wait();
  26. extern void LCD_ShowString(INT8U,INT8U,INT8U *);
  27. //-----------------------------------------------------------------
  28. //自定義CGRAM字符及圖標點陣數據(共兩組,每組字符不超過8個)
  29. INT8U code CGRAM_Dat1[][8] = //7個圖標符號(高度由1~7橫遞增的矩形)
  30. {        {0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x00},        //1橫
  31.         {0x00,0x00,0x00,0x00,0x00,0x1F,0x1F,0x00},        //2橫
  32.         {0x00,0x00,0x00,0x00,0x1F,0x1F,0x1F,0x00},        //3橫
  33.         {0x00,0x00,0x00,0x1F,0x1F,0x1F,0x1F,0x00},        //4橫
  34.         {0x00,0x00,0x1F,0x1F,0x1F,0x1F,0x1F,0x00},        //5橫
  35.         {0x00,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x00},        //6橫
  36.         {0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x1F,0x00}         //7橫
  37. };
  38. INT8U code CGRAM_Dat2[][8] = //5個漢字字符
  39. {        {0x08,0x0F,0x12,0x0F,0x0A,0x1F,0x02,0x00},        //年
  40.         {0x0F,0x09,0x0F,0x09,0x0F,0x09,0x13,0x00},        //月
  41.         {0x0F,0x09,0x09,0x0F,0x09,0x09,0x0F,0x00},        //日
  42.         {0x1F,0x0A,0x1F,0x0A,0x0A,0x0A,0x12,0x00},        //開
  43.         {0x0A,0x1F,0x04,0x1F,0x04,0x0A,0x11,0x00}         //關
  44. };
  45. //-----------------------------------------------------------------
  46. // 將自定義字符點陣寫入CGRAM
  47. //-----------------------------------------------------------------
  48. void Write_CGRAM(INT8U g[][8], INT8U n)
  49. {
  50.         INT8U i,j;
  51.     Write_LCD_Command(0x40);                   //設置CGRAM地址為0x40
  52.     for (i = 0; i < n; i++)                           //n個自定義字符
  53.     for (j = 0; j < 8; j++)                           //每個字符8字節點陣數據
  54.     Write_LCD_Data(g[i][j]);                   //寫入CGRAM
  55. }
  56. //-----------------------------------------------------------------
  57. // SW1: 水平滾動顯示字符串
  58. //-----------------------------------------------------------------
  59. void H_Scroll_Display()
  60. {
  61.         INT16U i;
  62.     Write_LCD_Command (0x0C);                              //開顯示,關光標
  63.     LCD_ShowString(0,0,"LCD1602 DEMO - 1") ;          //第0行顯示標題
  64.     LOOP1:
  65.     for (i = 0; i <= strlen(msg); i++)              //滾動輸出所有字符
  66.     {   LCD_ShowString(1,0,msg + i);                //msg+i實現取字符指針遞增
  67.         delay_ms(50);if (SW1) return;                                //未置于SW1位置時立即返回
  68.     }
  69.         delay_ms(1000); goto LOOP1;                                        //顯示完所有字符后暫停1s然后繼續
  70. }
  71. //-----------------------------------------------------------------
  72. // SW2: 帶光標顯示隨機算術式
  73. //-----------------------------------------------------------------
  74. void Cursor_Display()
  75. {
  76.     INT8U i; int a,b; char disp_buff[17];
  77.     Write_LCD_Command (0x0C);                                                         //開顯示,關光標
  78.     LCD_ShowString(0,0,"LCD1602 DEMO - 2");              //第0行顯示標題
  79.     LCD_ShowString(1,0,"              ");                //清空第1行(輸出16個空格)
  80.     Write_LCD_Command(0x0F);                                                         //開顯示,開光標,光標閃爍
  81.     srand(TH0);        //用THO作為隨機種子
  82.     while (1)
  83.     {   if (SW2) return;        //未置于SW2位置時立即返回
  84.         a = rand() % 100;        //產生不超過100的隨機數a,b;
  85.         b = rand() % 100;
  86.                 sprintf(disp_buff,        // 生成算術式及運算結果字符串
  87.             "%2d + %2d = %2d",a,b,a+b);
  88.         Write_LCD_Command(0xC0);                                                 //顯示位置定位于第1行開始位置
  89.         for (i = 0; i < 16; i++)                                                 //循環逐個輸出算術式字符
  90.         {   if (disp_buff[i])  Write_LCD_Data(disp_buff[i]);
  91.             else                           Write_LCD_Data(' ');
  92.             delay_ms(100);
  93.         }
  94.                 delay_ms(200);        //顯示完一個算術式后暫停200ms
  95.         LCD_ShowString(1,0,"                         ");             //清空該行(輸出16個空格)
  96.         }
  97. }
  98. //-----------------------------------------------------------------
  99. // SW3: 全碼表字符顯示
  100. //-----------------------------------------------------------------
  101. void Show_All_Inter_Chars()
  102. {
  103.         INT8U i,j = 0;
  104.         Write_LCD_Command(0x0C);                                   //開顯示,關光標
  105.         LCD_ShowString(0,0,"LCD1602 DEMO - 3");    //第 0行顯示標題
  106.         LCD_ShowString(1,0,"                ");       //第1 行清空(輸出16個空格)
  107.         LOOP3:
  108.         Write_LCD_Command(0xC0);                                        //顯示位置定位于第1行開始位置
  109.     //從全碼表顯示,范圍為0x20~0xFF,超過0xFF后溢出為0x00,循環結束
  110.         for (i = 0x20; i != 0x00; i++)
  111.         {   if (i >= 0x80 && i <= 0x9F) continue; //跳過空白區字符
  112.             if ((++j) % 16 == 0)                                                //判斷是否顯示滿一行
  113.             {   delay_ms(500);                                                //滿一行時延時500ms
  114.                 LCD_ShowString(1,0,"                "); //清空該行
  115.                 Write_LCD_Command(0xC0);                        //顯示位置定位于第1行開始位置
  116.                 j=0;        //顯示字符計數變量清零
  117.         }
  118.                 Write_LCD_Data(i);                                        //在當前位置顯示編碼為i的字符
  119.                 delay_ms(20);                                                        //顯示一個字符后短延時40ms
  120.                 if (SW3) return;                                                 //未置于SW3位置時立即返回
  121.         }
  122.         delay_ms(500);                                                //一趟演示后延時500ms
  123.         goto LOOP3;        //繼續全碼表字符顯示
  124. }
  125. //-----------------------------------------------------------------
  126. // SW4: CGRAM自定義字符顯示
  127. //-----------------------------------------------------------------
  128. void Display_CGRAM_Chars()
  129. {
  130.         INT8U i,j = 0;
  131.         Write_LCD_Command(0x0C);                            //開顯示,關光標
  132.         LCD_ShowString(0,0,"LCD1602 DEMO - 4");            //第0行顯示標題
  133.         LOOP4:        //第1組自定義CGRAM字符演示
  134.         LCD_ShowString(1,0,"                ");         //第1行清空(輸出16個空格)
  135.         Write_CGRAM(CGRAM_Dat1,7);                                    //第1組自定義字符點陣寫入CGRAM
  136.         Write_LCD_Command(0xC0 | 1);                                //顯示位置定位于第1行1列位置
  137.         for (i = 6; i != 0xFF; i--)                                        //7線~1線式方塊逐個顯示
  138.         {   Write_LCD_Data(i);                                                    //在當前位置顯示編碼為i的字符
  139.                 delay_ms(50); if (SW4) return;              //未置于SW4位置時立即返回
  140.         }
  141.         for(i = 0; i <= 6; i++)                                                //1線~7線式方塊逐個顯示
  142.         {   Write_LCD_Data(i);                                                //在當前位置顯示編碼為i的字符
  143.             delay_ms(50); if (SW4) return;             //未置于 SW4位置時立即返回
  144.         }
  145.         delay_ms (500);                                                        //第1組自定義字符演示后延時1s
  146.         //第2組自定義CGRAM字符演示
  147.         LCD_ShowString(1,0, "                ");   //第1行清空(輸出16個空格)
  148.         Write_CGRAM(CGRAM_Dat2,5);                   //第2組自定義字符點陣寫入CGRAM
  149.         Write_LCD_Command(0xC0 | 4);                   //顯示位置定位于第1行4列位置
  150.         for (i = 0; i <= 4; i++)                                   //5個自定義漢字字符顯示
  151.         {    Write_LCD_Data(i);                                           //在當前位置顯示編碼為i的字符
  152.                  Write_LCD_Data(' ');                                   //每顯示一個自定義字符后加一一 空格
  153.                  delay_ms(100);if (SW4) return;                   //未置于SW4位置時立即返回
  154.         }
  155.         delay_ms(1000);                                           //第2組自定義字符演示后延時1s
  156.         goto LOOP4;                                                           //繼續
  157. }
  158. //-----------------------------------------------------------------
  159. // 主程序
  160. //-----------------------------------------------------------------
  161. void main()
  162. {
  163.         P3 = 0xFF;                                                //P3端口置為0xFF
  164.         Initialize_LCD();                                //初始化LCD
  165.         TR0  = 1;                                                //啟動定時器,提供隨機種子
  166.         while(1)                                                //主循環控制實現各類演示
  167.         {        if (SW1 == 0) H_Scroll_Display();
  168.                 if (SW2 == 0) Cursor_Display();
  169.                 if (SW3 == 0) Show_All_Inter_Chars();
  170.                 if (SW4 == 0) Display_CGRAM_Chars();
  171.         }
  172. }
1602字符液晶工作于8位模式直接驅動顯示.zip (60.12 KB, 下載次數: 8)
