查看: 4617|回復: 10
單片機時鐘程序 為什么秒到了60,分不會加一?
ID:786338 發表于 2020-6-23 15:53 | 顯示全部樓層 |閱讀模式
20黑幣
我的程序在下面,可以幫我看看為什么秒到了60,分不會加一?可以教教我怎么改嗎?謝謝
#include<regx51.h>
#define TIME=1200
sbit K1=P1^0;
sbit K2=P1^1;
sbit K3=P1^2;
sbit K4=P1^3;
sbit K5=P1^4;
unsigned int cnt=0;
unsigned char i=0;
unsigned long sec=0;
unsigned char second = 0;
unsigned char minute = 0;
unsigned char hour = 0;
unsigned char code segment_code[10] = {0x3f, 0x06, 0x5b, 0x4f,0x66, 0x6d, 0x7d, 0x07,0x7f, 0x6f};
unsigned char digital_tube[8]={0x3f,0x3f,0x3f,0x3f,0x3f,0x39,0x38};
void ScanLed()
        static unsigned char display_bit = 0;
        switch (display_bit)
        case 0:
                P2=0xfe;
                break;
        case 1:
                P2=0xfd;
                break;
        case 2:
                P2=0xfb;
                break;
        case 3:
                P2=0xf7;
                break;
        case 4:
                P2=0xef;
                break;
        case 5:
                P2=0xdf;
                break;
        case 6:
                P2=0xbf;
                break;
        case 7:
                P2=0x7f;
                break;
        default:
                break;
        P0=digital_tube[display_bit];
                display_bit++;
        if (display_bit == 8)
                display_bit = 0;
        TMOD = 0x01;
    TH0 = 64536 / 256;
    TL0 = 64536 % 256;
    EA = 1;
    ET0 = 1;
    TR0 = 1;
        while (1)
void delay(unsigned int xms)
        unsigned int i,j;
        for(i=xms;i>0;i--)
                for(j=100;j>0;j--);
void Timer0() interrupt 1
        static int index = 0;
        TH0 = 64536 / 256;
   TL0 = 64536 % 256;
        index++;
        ScanLed();
        if (index == 1000)
                index = 0;
                second++;
        if (second == 60)
                second = 0;
                minute++;
        if (minute == 60)
                minute = 0;
                hour++;
        if (hour == 24)
                hour = 0;
        if(K4==0)
  delay(10);
   if(K4==0)
hour++;
if(hour==24)        hour=0;
  while(!K4);
if(K3==0)
  delay(10);
  if(K3==0)
  minute++;
  if(minute==60)        minute=0;
while(!K3);
if(K2==0)
delay(10);
if(K2==0)
second++;
if(second==24)       second=0;
while(!K2);
if(K1==0)
delay(10);
if(K1==0)
hour=0;
minute=0;
second=0;
while(!K1);
digital_tube[0] = segment_code[hour / 10];
digital_tube[1] = segment_code[hour % 10]+0x80;
digital_tube[2] = segment_code[minute / 10];
digital_tube[3] = segment_code[minute % 10]+0x80;
digital_tube[4] = segment_code[second / 10];
digital_tube[5] = segment_code[second % 10]+0x80;
digital_tube[6] = 0x39;
digital_tube[7] = 0x38;
最佳答案
查看完整內容
給你一個程序小函數參考,希望對你有幫助 //-----------------------計時---秒-分-時----------------------------------- if(js == 2) //判斷是否是計數2次500ms即是1秒 { js = 0; Sec ++; if(Sec == 60) { Sec = 0; min ++; if(min == 60) { min = 0; hour ++; if(hour == 24) { hour = 0; } } } }
ID:65956 發表于 2020-6-23 15:53 | 顯示全部樓層
給你一個程序小函數參考,希望對你有幫助
                        js = 0;
                        Sec ++;
                        if(Sec == 60)
                                Sec = 0;
                                min ++;
                                if(min == 60)
                                        min = 0;
                                        hour ++;
                                        if(hour == 24)
                                                hour = 0;
ID:548551 發表于 2020-6-23 17:22 | 顯示全部樓層
void Timer0() interrupt 1 .你這個中斷程序不知道定時是多久, 如果可以建議更改一下定時的時長, 改成4MS一個定時;這樣好計算一點. 下面是一個參考.
下面的幾個變量你自己定義全部是unchar類型的.你以后寫程序,定時的時候不要用if(mmm==60)這樣的.
        //前面的定時你自己設定,4MS一個定時就可以了
        time_1s++;                                //4ms開始加加到250時1s時間到了清零再開始加.
        if(time_1s>=250)                        //1s到
                time_1s=0;                        //清零1S計數
                time_1m++;                        //1M開始計數
                if(time_1m>59)                //1M到
                        time_1m=0;                //清零1M計數
                        time_1h++;                //1H開始計數
                        if(time_1h>59)                //1H到
                                time_1h=0;                //清零1H計數
                                time_24h++;                //24H開始計數
                                if(time_24h>23)                //24H到
                                        time24h=0;        //清零24小時計數
ID:584814 發表于 2020-6-23 17:36 | 顯示全部樓層
關注一下中斷里的這個 static int index = 0;
ID:213173 發表于 2020-6-23 20:19 | 顯示全部樓層
ID:786338 發表于 2020-6-23 22:32 | 顯示全部樓層
aking991 發表于 2020-6-23 17:18
給你一個程序小函數參考,希望對你有幫助
//-----------------------計時---秒-分-時------------------ ...
好的,謝謝
ID:636538 發表于 2020-6-24 09:40 | 顯示全部樓層
給你一個程序小函數參考,希望對你有幫助
if (second == 60)
                second = 0;
                minute++;
if (minute> 59)
                minute = 0;
                hour++;
這么寫有問題嗎?
我一般是你寫的這樣,但是這個這么寫我也不覺得有問題
ID:636538 發表于 2020-6-24 09:45 | 顯示全部樓層
man1234567 發表于 2020-6-23 17:36
為什么關注這,看著沒有問題啊,
ID:636538 發表于 2020-6-24 09:51 | 顯示全部樓層
整體看完邏輯沒有問題,但是為什么沒有加1,我認為是你的中斷定時設置時間太短,按照你index=1000;說明你定時時間是1MS,而你1MS的時間太短沒有處理完你的中斷程序就結束了,因此建議你將定時時間設置為10ms試試,將定時時間延長,這樣在我看來沒有問題了。而且不建議你把按鍵也放在中斷里處理,
ID:744327 發表于 2020-6-24 09:58 | 顯示全部樓層
寫一個定時模塊給你
void SystemInit(void)
TMOD=0x01;
TH0=(65536-45872)/256;//定時50ms//晶振:11.0592MHZ
TL0=(65536-45872)%256;
ET0=1;
TR0=1;
EA=1;
ID:65956 發表于 2020-6-28 08:19 | 顯示全部樓層
SKYLAR123 發表于 2020-6-24 09:40
if (second == 60)
                second = 0;
這樣寫是你的邏輯沒有搞對,你的目的是在計一秒后要對另外兩個變量進行判斷,如果你不放在鉗套中去判斷,當你定時器一中斷可能會影響到它的另外變量判斷,這樣就會出現某個變量不動的原因。
